notheld
  1. Thank you very much for your reply, Werner. Everything is working now. It was necessary to copy the /boot of the SD card to the /boot of the nvme as you suggested. By doing this and changing the UUID to the correct one everything worked. Thank you very much for your help!!! Now I can use armbian on my nvme as I always wanted. But only one strange behavior remained, if I perform a reboot I am redirected to the BusyBox again and running a blkid does not show the UUID of the nvme. It seems that nvme is not recognized. But if I remove the power cable and put it back in, everything is back to normal. I just found this behavior very curious but it won't affect my use, I just always have to turn it off and on again if I need to reboot.
  2. Hello everyone. this is my first post so please forgive me if I need to create a new post or if it makes sense to use this tread. I have a pi 5 plus 16gb and I managed to install the image Armbian_24.8.1_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop.img on the SD card and emmc. But it doesn't work on the pcie, I'm using the wd black SN750 SE. I can't understand why this is happening. I can run Joshua's ubuntu-24.04-preinstalled-desktop-arm64-orangepi-5-plus.img.xz image in nvme and it works perfectly, but I wanted to be able to run the armbian image because I really like the project. So using SD crad I ran the commands to delete /dev/mtd0 and ran the armbian-install command to install it on nvme. But it didn't work in the same way and now Joshua's image has also stopped working.Armbian starts to run but doesn't finish booting and is stuck waiting for some action. This is the boot log: done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Loading, please wait... Starting systemd-udevd version 255.4-1ubuntu8.4 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... BusyBox v1.36.1 (Ubuntu 1:1.36.1-6ubuntu3.1) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) To get Joshua's image working again, I had to redo the manufacturer's SPI flush using the files from this link https://drive.google.com/drive/folders/19SMZHj1Y8l_Vvr6_SMDHYdJHi41hMgsI. I'm applying the rk3588_linux_pcie.cfg and MiniLoaderAll.bin configuration and putting rkspi_loader in uboot. By doing this, nvme worked again with the Joshua image and Armbian did not. Whenever I delete the contents of /dev/mtd0 everything stops working, only the SD card works, emmc and nvme stop working, not just the armbian images but any image I try to use. I tried to use only the option update MTD boot-loader and then Install it to NVME I invested a whole day trying to solve this but I was unsuccessful, I tried several different ways but the result is always the same. Please, would anyone have any different ideas or tell me what I'm doing wrong? I've run out of ideas.
