waba
  1. sudo apt update sudo apt install code Armbian_23.5.2_Orangepiplus2e_jammy_current_6.1.30_xfce_desktop.img.xz root@orangepiplus2e:~# sudo apt install code Reading package lists... Done Building dependency tree... Done Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: code : Depends: libasound2 (>= 1.0.17) Depends: libatk-bridge2.0-0 (>= 2.5.3) but it is not installable Depends: libatk1.0-0 (>= 2.2.0) but it is not installable Depends: libatspi2.0-0 (>= 2.9.90) but it is not installable Depends: libcurl3-gnutls but it is not installable or libcurl3-nss but it is not installable or libcurl4 but it is not installable or libcurl3 but it is not installable Depends: libglib2.0-0 (>= 2.37.3) but it is not installable Depends: libgtk-3-0 (>= 3.9.10) but it is not installable E: Unable to correct problems, you have held broken packages.
