Thanks alot @BipBip1981
Changing the values at FCTEMPS from `/dev/thermal-cpu/temp1_input` to `/sys/class/thermal/thermal_zone0/temp` fixed it.
My dumb ass then updated the system via OVM and after a reboot the fan started spinning non-stop again, this time:
root@helios64:~# systemctl status fancontrol.service
● fancontrol.service - fan speed regulator
Loaded: loaded (/lib/systemd/system/fancontrol.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2024-10-06 10:49:39 UTC; 6s ago
Docs: man:fancontrol(8)
man:pwmconfig(8)
Process: 1653 ExecStartPre=/usr/sbin/fancontrol --check (code=exited, status=0/SUCCESS)
Process: 1773 ExecStart=/usr/sbin/fancontrol (code=exited, status=1/FAILURE)
Main PID: 1773 (code=exited, status=1/FAILURE)
Oct 06 10:49:39 helios64 fancontrol[1773]: MINSTOP=40
Oct 06 10:49:39 helios64 fancontrol[1773]: MINPWM=0
Oct 06 10:49:39 helios64 fancontrol[1773]: MAXPWM=255
Oct 06 10:49:39 helios64 fancontrol[1773]: Error: file /dev/fan-p6/pwm1 doesn't exist
Oct 06 10:49:39 helios64 fancontrol[1773]: Error: file /dev/fan-p7/pwm1 doesn't exist
I somehow pieced the new value together via:
https://community.clearlinux.org/t/fancontrol-and-pwmconfig-hwmon3-pwm1-and-hwmon3-fan1-input-not-found/7516/5
https://bbs.archlinux.org/viewtopic.php?id=243169
https://www.reddit.com/r/linuxquestions/comments/n7lwga/fancontrol_error_file_doesnt_exist_or_isnt/
Fan is silent now and fancontrol.service is active (running) with:
root@helios64:~# cat fancontrol/fancontrol
INTERVAL=10
FCTEMPS=/sys/devices/platform/p6-fan/hwmon/hwmon5/pwm1=/sys/class/thermal/thermal_zone0/temp /sys/devices/platform/p7-fan/hwmon/hwmon4/pwm1=/sys/class/thermal/thermal_zone1/temp
MINTEMP=/sys/devices/platform/p6-fan/hwmon/hwmon5/pwm1=40 /sys/devices/platform/p7-fan/hwmon/hwmon4/pwm1=40
MAXTEMP=/sys/devices/platform/p6-fan/hwmon/hwmon5/pwm1=110 /sys/devices/platform/p7-fan/hwmon/hwmon4/pwm1=110
MINSTART=/sys/devices/platform/p6-fan/hwmon/hwmon5/pwm1=60 /sys/devices/platform/p7-fan/hwmon/hwmon4/pwm1=60
MINSTOP=/sys/devices/platform/p6-fan/hwmon/hwmon5/pwm1=40 /sys/devices/platform/p7-fan/hwmon/hwmon4/pwm1=40
MINPWM=20
This is working on:
root@helios64:~# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
root@helios64:~# uname -r
6.6.47-current-rockchip64
