Bjoern12345
  1. Hello, I wanted widivine in kodi, after some fails it found a solution. Maybe this helps you to get widevine working on arm aarch64 in web browser, too. First I used widevine-installer (needs squashfs-tools package) from here https://github.com/AsahiLinux/widevine-installer This should already work with chromium or firefox, didn't work in my case. I did not try further to solve web brower issue, cause I wanted to use kodi. I installed kodi via flatpak and setup widivine with inputstream-helper plugin. And again it failed and was not working 😞 Final solution was to copy libwidevinecdm.so created by widevine-installer (/var/lib/widevine/libwidevinecdm.so) to kodi cdm folder (/home/user/.var/app/tv.kodi.Kodi/data/cdm/libwidevinecdm.so) So should be possible to get widevine working in chrome or firefox, too !!! Good luck ! Bjoern
