MatthewB
  1. I can confirm that the DT overlay method mentioned above also works for an Odroid M1 (Rockchip rk3568), with slight modifications: the ethernet0 alias is already created in the 'parent' dtb, no need to repeat that here the target is called gmac0 instead of emac Create /tmp/rk3568-eth0-stable-mac.dts: /dts-v1/; /plugin/; / { compatible = "rockchip,rk3568"; fragment@0 { target = <&gmac0>; __overlay__ { local-mac-address = [00 00 00 00 00 00]; }; }; }; Execute: armbian-add-overlay /tmp/rk3568-eth0-stable.mac.dts And reboot. I tested on two identical Odroid M1 devices, they each got a different MAC address, which stayed stable over reboots. I'm not sure about the T6. It has an rk3588, so at least the same SoC family. But its on-chip Gigabit network interface is not wired on the T6. Instead, two external 2.5Gbps Ethernet chips are added, each of which are connected via a PCIE lane. As such, it could maybe require a different solution.
