6 -
apt-get update fails with public key errors
Claudio Calazans replied to flot010's topic in Beginners
UPGRADE SOLVED The EASIEST & CLEANEST way to update from makerbase skipr git img (buster based to bookworm) was starting it from scratch! 1) Format eMMC 2) Download Armbian 6.6 iot version img from community 3) Install KIAUH (as recommended at the GIT) and from it all other software and updates Klipper, Mainsail, Mobileraker and update system! Now I'm moving to next steps now on MCU and CAN setup. Keep you posted. Too early for celebrations... after system requested update to trunk203 and KlipperScreen (5-37 - which I don´t think caused the error I am now unable to open mainsail via browser) Igor & Werner Thank youl. -
Thank you Werner once again... I've set up the unattended updates. I think for now major issue seems to be these errors. 3.467670] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) gpio-syscon ff100000.syscon:gpio: can't read the data register offset! [ 4.449038] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.498915] genpd_dev_pm_attach: return 0 [ 4.499250] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.498915] genpd_dev_pm_attach: return 0 [ 4.499250] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned Then I'll probably reed to reflash mcu to try to have rpi updated. -
Still need help on to fix the last error after upgrade rebooting. Appreciate any help. rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'hevc', val=0x88220 [ 3.467670] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) gpio-syscon ff100000.syscon:gpio: can't read the data register offset! [ 4.449038] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.498915] genpd_dev_pm_attach: return 0 [ 4.499250] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.498915] genpd_dev_pm_attach: return 0 [ 4.499250] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned Fluidd also throwing same error messages befor this whole journey started at: MCU Protocol error This is frequently caused by running an older version of the firmware on the MCU(s). Fix by recompiling and flashing the firmware. Your Klipper version is: v0.12.0-401-g383b83d78 MCU(s) which should be updated: rpi: Current version v0.11.0-121-ga5fb2076 Up-to-date MCU(s): mcu: Current version v0.12.0-401-g383b83d78 Once the underlying issue is corrected, use the "RESTART" command to reload the config and restart the host software. mcu 'rpi': Command format mismatch: query_adxl345 oid=%c rest_ticks=%u vs query_adxl345 oid=%c clock=%u rest_ticks=%u I did decide to moved ahead and would like to register steps and important actions to willing to do the same to take care on buster to bookworm upgrade on mks skipr to an error and correction found /adapted to this architecture... Error faced /usr/bin/perl: error while loading shared libraries: libcrypt.so.1: cannot open shared object file: No such file or directory Error: Timeout was reached root@mkspi:/tmp# sr/bin/dpkg returned an error code (1) Correction found (with my updates commented) Steps: 1 )cd /tmp 2) apt -y download libcrypt1 3) dpkg-deb -x libcrypt1_1%3a4.4.25-2_amd64.deb . (substitute for correct download version using the -X parameter to check yours*) 4) cp -av lib/x86_64-linux-gnu/* /lib/x86_64-linux-gnu/ (for mks skipr might change dor aarch64-linux-gnu) 5) apt -y --fix-broken install *root@mkspi:/tmp# dpkg-deb -X libcrypt1_1%3a4.4.33-2_arm64.deb . ./ ./lib/ ./lib/aarch64-linux-gnu/ ./lib/aarch64-linux-gnu/libcrypt.so.1.1.0 ./usr/ ./usr/share/ ./usr/share/doc/ ./usr/share/doc/libcrypt1/ ./usr/share/doc/libcrypt1/changelog.Debian.gz ./usr/share/doc/libcrypt1/changelog.gz ./usr/share/doc/libcrypt1/copyright ./lib/aarch64-linux-gnu/libcrypt.so.1 Then I got an error during the update process in which the only option was to click OK in the GUI... "failure restarting gnu libc upgrade you will need to start these manually by running invoke-rc.d <service> restart" Version Check root@mkspi:~# uname -mrs Linux 5.16.20-rockchip64 aarch64 root@mkspi:~# lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm -
Many Thanks Werner & Igor... By Werner link Its seems it ´s not available so far.... Debian Backports does not support LTS [1], therefore buster-backports is unsupported since August 1st 2022. Despite of the documentation buster-backport was still available on the mirrors, that changed recently with the archival of buster-backports. Unfortunately we missed to create an announcement in 2022 which led so some surprise. Please take this as the missing announcement. Following Igor recommendations... Note: although Fluid says: Your Klipper version is: v0.12.0-401-g383b83d78 MCU(s) which should be updated: rpi: Current version v0.11.0-121-ga5fb2076 Up-to-date MCU(s): mcu: Current version v0.12.0-401-g383b83d78 The commands below shows (buster) root@mkspi:/etc/apt# lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster root@mkspi:/etc/apt# root@mkspi:/etc/apt# uname -mrs Linux 5.16.20-rockchip64 aarch64 root@mkspi:/etc/apt# cat /etc/debian_version 10.13 root@mkspi:/etc/apt# sudo apt-mark showhold | more linux-dtb-edge-rockchip64 linux-image-edge-rockchip64 linux-u-boot-mkspi-edge Updated sources.list as follow: deb http://deb.debian.org/debian bookworm main contrib non-free #deb-src http://deb.debian.org/debian buster main contrib non-free deb http://deb.debian.org/debian bookworm-updates main contrib non-free #deb-src http://deb.debian.org/debian buster-updates main contrib non-free deb http://deb.debian.org/debian bookworm-backports main contrib non-free #deb-src http://deb.debian.org/debian buster-backports main contrib non-free deb http://security.debian.org/ bookworm/updates main contrib non-free #deb-src http://security.debian.org/ buster/updates main contrib non-free when trying to run update I got the following... root@mkspi:/etc/apt/sources.list.d# sudo apt update Get:1 http://deb.debian.org/debian bookworm InRelease [151 kB] Ign:2 http://security.debian.org bookworm/updates InRelease Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB] Get:4 http://deb.debian.org/debian bookworm-backports InRelease [59.0 kB] Hit:5 https://github.armbian.com/configng stable InRelease Err:6 http://security.debian.org bookworm/updates Release 404 Not Found [IP: 2a04:4e42:2a::644 80] Get:7 http://deb.debian.org/debian bookworm/main arm64 Packages [11.9 MB] Hit:8 http://fi.mirror.armbian.de/apt buster InRelease Get:9 http://deb.debian.org/debian bookworm/main armhf Packages [11.7 MB] Get:10 http://deb.debian.org/debian bookworm/main armhf Contents (deb) [10.3 MB] Get:11 http://deb.debian.org/debian bookworm/main all Contents (deb) [33.9 MB] Get:12 http://deb.debian.org/debian bookworm/main arm64 Contents (deb) [11.2 MB] Get:13 http://deb.debian.org/debian bookworm/contrib arm64 Packages [54.7 kB] Get:14 http://deb.debian.org/debian bookworm/contrib armhf Packages [50.7 kB] Get:15 http://deb.debian.org/debian bookworm/contrib armhf Contents (deb) [34.5 kB] Get:16 http://deb.debian.org/debian bookworm/contrib all Contents (deb) [98.6 kB] Get:17 http://deb.debian.org/debian bookworm/contrib arm64 Contents (deb) [37.9 kB] Get:18 http://deb.debian.org/debian bookworm/non-free arm64 Packages [93.6 kB] Get:19 http://deb.debian.org/debian bookworm/non-free armhf Packages [68.4 kB] Get:20 http://deb.debian.org/debian bookworm/non-free all Contents (deb) [839 kB] Get:21 http://deb.debian.org/debian bookworm/non-free arm64 Contents (deb) [44.0 kB] Get:22 http://deb.debian.org/debian bookworm/non-free armhf Contents (deb) [15.2 kB] Get:23 http://deb.debian.org/debian bookworm-updates/main armhf Packages [8,292 B] Get:24 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [8,844 B] Get:25 http://deb.debian.org/debian bookworm-updates/main arm64 Contents (deb) [82.1 kB] Get:26 http://deb.debian.org/debian bookworm-updates/main armhf Contents (deb) [76.1 kB] Get:27 http://deb.debian.org/debian bookworm-updates/main all Contents (deb) [40.1 kB] Get:28 http://deb.debian.org/debian bookworm-updates/contrib arm64 Packages [768 B] Get:29 http://deb.debian.org/debian bookworm-updates/contrib arm64 Contents (deb) [222 B] Get:30 http://deb.debian.org/debian bookworm-updates/non-free armhf Packages [492 B] Get:31 http://deb.debian.org/debian bookworm-updates/non-free arm64 Packages [12.0 kB] Get:32 http://deb.debian.org/debian bookworm-updates/non-free arm64 Contents (deb) [14.9 kB] Get:33 http://deb.debian.org/debian bookworm-updates/non-free armhf Contents (deb) [165 B] Get:34 http://deb.debian.org/debian bookworm-backports/main armhf Packages [264 kB] Get:35 http://deb.debian.org/debian bookworm-backports/main arm64 Packages [263 kB] Get:36 http://deb.debian.org/debian bookworm-backports/main armhf Contents (deb) [1,948 kB] Get:37 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) [6,097 kB] Get:38 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) [2,169 kB] Get:39 http://deb.debian.org/debian bookworm-backports/contrib arm64 Packages [4,968 B] Get:40 http://deb.debian.org/debian bookworm-backports/contrib armhf Packages [4,744 B] Get:41 http://deb.debian.org/debian bookworm-backports/contrib arm64 Contents (deb) [17.6 kB] Get:42 http://deb.debian.org/debian bookworm-backports/contrib all Contents (deb) [23.2 kB] Get:43 http://deb.debian.org/debian bookworm-backports/contrib armhf Contents (deb) [17.5 kB] Get:44 http://deb.debian.org/debian bookworm-backports/non-free armhf Packages [1,516 B] Get:45 http://deb.debian.org/debian bookworm-backports/non-free arm64 Packages [10.1 kB] Get:46 http://deb.debian.org/debian bookworm-backports/non-free arm64 Contents (deb) [11.1 kB] Get:47 http://deb.debian.org/debian bookworm-backports/non-free armhf Contents (deb) [165 B] Get:48 http://deb.debian.org/debian bookworm-backports/non-free all Contents (deb) [32.5 kB] ^C root@mkspi:/etc/apt/sources.list.d# Traceback (most recent call last): File "/usr/lib/cnf-update-db", line 26, in <module> col.create(db) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 94, in create self._fill_commands(con) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 132, in _fill_commands self._parse_single_contents_file(con, f, fp.stdout) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 229, in _parse_single_contents_file if not (l.startswith('usr/sbin') or l.startswith('usr/bin') or KeyboardInterrupt sudo apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://deb.debian.org/debian bookworm-backports InRelease Hit:4 https://github.armbian.com/configng stable InRelease Ign:5 http://security.debian.org bookworm/updates InRelease Err:7 http://security.debian.org bookworm/updates Release 404 Not Found [IP: 2a04:4e42:2a::644 80] Hit:6 http://fi.mirror.armbian.de/apt buster InRelease Reading package lists... Done E: The repository 'http://security.debian.org bookworm/updates Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. So the question is: it safe to move ahead? Not sure if its important but want to highlight that mks skipr is 32 bits. Super appreciate. -
Igor steps are great and eliminated the NO_PUBKEY 93D6889F9F0E78D5 message but I am still facing theses messages when trying to update/upgrade my mks/skipr rpi armibian: root@mkspi:~# sudo apt-get update && sudo apt-get upgrade -y Hit:1 http://deb.debian.org/debian buster InRelease Hit:2 http://deb.debian.org/debian buster-updates InRelease Ign:3 http://deb.debian.org/debian buster-backports InRelease Hit:4 http://security.debian.org buster/updates InRelease Hit:5 https://github.armbian.com/configng stable InRelease Err:6 http://deb.debian.org/debian buster-backports Release 404 Not Found [IP: 2a04:4e42:2a::644 80] Hit:7 http://fi.mirror.armbian.de/apt buster InRelease Reading package lists... Done E: The repository 'http://deb.debian.org/debian buster-backports Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Appreciate any help! -
Public key not available... when apt update
Claudio Calazans replied to Wilson Wilson's topic in Beginners
