Jon M
  1. I have decompiled the dtb file but am unable to incorporate the patch. How do i incorporate the patch or change it? In terms for a newbie please! I should say it is for debian 12 Cinnamon 6.12.
  2. Thanks I saw that patch but have no idea how to apply it or what to do with it or if it even works in this version? If someone could help that would be great!
  3. Why does HDMI Audio work on Debian 12 Bookworm 6.1 version and not on Debian 12 Bookworm 6.12? I have updated to latest version and still no HDMI audio. Is there a patch or something i can do to fix this?
  4. I have tried to used apt update and upgrade to update latest Mesa driver but keep getting error 'file has unexpected size' so therefore fails as unable to fetch the archive! the file is available after apt update but unable to install. How can i fix this please?
  5. Thanks for the info but I am not using a rolling release. I f this update/patch can be applied to the version I am using how do I go about that? Failing that, where can I get the latest version of Debian cinnamon with the patch included? The software has been fully updated as of today but still no hdmi audio. Is there a simple fix? Thanks for your help update. I have gone into Armbian-config and changed from stable to rolling updates but still not working!
  6. Hi I have just installed this version of Armbian on Rock 5b but there is no wifi! I have wifi module installed and works fine on the latest Gnome build but not on Cinnamon. Can anyone help please? I have also found that there is no sound through hdmi. Only option is for headphones! How can I change this? Note: just started up again and option for wifi has appeared, good news! But still no sound.
  7. I have been trying for days now to update my device and all goes well until i get to 'beta.armbian.com:80 (130.185.239.78)' and then it will not update and stays at 0%. i have tried on different! installations and on different devices even a new installation but the same problem occurs. It used to work fine until a couple of days ago! I have even tried turning off all security on my router but no change. Is there a reason for this , if so is there anything i can do to correct it?
  8. I have been trying for days now to update my device and all goes well until i get to 'beta.armbian.com:80 (130.185.239.78)' and then it will not update and stays at 0%. i have tried on different! installations and on different devices even a new installation but the same problem occurs. It used to work fine until a couple of days ago! I have even tried turning off all security on my router but no change. Is there a reason for this , if so is there anything i can do to correct it?
  9. Just in case this is of interest to anyone I found a solution which was to install Armbian-firmware-full
  10. Hi 'may', i followed your instructions on RPi5 everything seemed to go ok but still no option for built in wifi adapter. You say in your next post to install Armbian firmware i am not sure how to do this, perhaps that is why it is not working! could you please explain?
  11. Hi I am new to this forum and to Armbian but am enjoying the work of all those who have contributed. having installed Armbian for the first time could someone please confirm or otherwise if WiFi is supposed to be working on the RPI5 internal adapter? my install does not even see it at all it’s like it does not exist can it be turned on in simple terms for a noob?
