After apt-get update and upgrade DTB files was damaged :((
How its recovery, dont know
rkdeveloptool dont working
rkdeveloptool reboot-maskrom
Reset Device quit, creating comm object failed!
It's log from console interface(COM port)
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x40040000 ... sha256(1d13f803de...) + OK
## Checking uboot 0x40200000 ... sha256(ad96202f45...) + OK
## Checking fdt 0x4033dd80 ... sha256(6d0c8a3eca...) + OK
## Checking atf-2 0x400f0000 ... sha256(2f297c059b...) + OK
## Checking atf-3 0x3fe70000 ... sha256(9d9e1b461e...) + OK
## Checking optee 0x48400000 ... sha256(31c3421ab3...) + OK
Jumping to U-Boot(0x40200000) via ARM Trusted Firmware(0x40040000)
Total: 94.153/238.645 ms
INFO: Preloader serial: 0
NOTICE: BL31: v2.3():v2.3-749-g30018b771:derrick.huang, fwver: v1.04
NOTICE: BL31: Built : 09:43:01, Apr 16 2024
INFO: ext 32k is not detected
INFO: ARM GICv2 driver initialized
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-791-g185dc3c92 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Tue Apr 16 11:05:25 CST 2024 aarch64, fwver: v1.01
I/TC: OP-TEE memory: TEEOS 0x200000 TA 0xc00000 SHM 0x200000
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x40200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-armbian-2017.09-S57b8-P9d8d-H8c72-V8051-Bda0a-R448a (Sep 13 2024 - 04:56:59 +0000)
Model: Rockchip RK3576 Evaluation board
MPIDR: 0x0
PreSerial: 0, raw, 0x2ad40000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: bda21000
Relocation fdt: fb9f9a70 - fb9fecf0
CR: M/C/I
Using default environment
DM: v2
mmc@2a310000: 1, mmc@2a330000: 0
Bootdev(atags): mmc 0
MMC0: HS400 Enhanced Strobe, 200Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
Failed to load DTB, ret=-19
No valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
download key pressed... entering download mode...
RKUSB: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x3a3e000
\usb device is high-speed
