Having a simular issue to the one in this thread, however, slightly different, I believe.
	We experienced a power outage this morning.  Luckily the OMV server is on battery backup, so I was able to shut the server down.  Once power was restored, I restarted the server and the RAID drive is Missing.
	From what I can tell, during the reboot, a BIOS autorecovery setting applied GPT to 3 of my RAID drives, as seen in the blkid output below.
	Looking for options to recover this system.
	Thanks in advance for any assistance.
	lsblk
	NAME        MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
	sda           8:0    0  10.9T  0 disk
	└─md0         9:0    0     0B  0 raid6
	sdb           8:16   0  10.9T  0 disk
	sdc           8:32   0  10.9T  0 disk
	sdd           8:48   0  10.9T  0 disk
	sde           8:64   0  10.9T  0 disk
	sdf           8:80   0  10.9T  0 disk
	sdg           8:96   0  10.9T  0 disk
	sdh           8:112  0  10.9T  0 disk
	sdi           8:128  0  10.9T  0 disk
	sdj           8:144  0  10.9T  0 disk
	sdk           8:160  0  10.9T  0 disk
	nvme0n1     259:0    0 476.9G  0 disk
	├─nvme0n1p1 259:1    0   512M  0 part  /boot/efi
	├─nvme0n1p2 259:2    0 475.5G  0 part  /var/folder2ram/var/cache/samba
	│                                      /var/folder2ram/var/lib/monit
	│                                      /var/folder2ram/var/lib/rrdcached
	│                                      /var/folder2ram/var/spool
	│                                      /var/lib/containers/storage/overlay
	│                                      /var/folder2ram/var/lib/openmediavault/rrd
	│                                      /var/folder2ram/var/tmp
	│                                      /var/folder2ram/var/log
	└─nvme0n1p3 259:3    0   976M  0 part  [SWAP]
	blkid
	/dev/sdf: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="bde193d0-b68d-c1d5-11ed-5f8275a4a220" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/nvme0n1p3: UUID="2bb7348b-aa0a-42a1-af4b-f4ee684c78ba" TYPE="swap" PARTUUID="d804df87-8bf9-45bd-9cb5-da32f39fee2a"
	/dev/nvme0n1p1: UUID="4647-262F" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="8aa9ef68-1a9f-4d0e-a27b-afc72cc70946"
	/dev/nvme0n1p2: UUID="82bb97eb-6acc-4de0-8361-09b220ad4041" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="537d3034-7576-44ea-a8e8-ccce3d33c1b8"
	/dev/sdd: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="3017eba0-37a3-83ff-202c-dd24668b7223" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/sdb: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="792c5ef1-7fb7-335c-6f63-b5a835548740" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/sdi: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="ee6cdfb3-c66c-013a-0918-1573a1f32bfd" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/sdg: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="711a8d42-424e-f6f6-9ff4-60cc2bee0cb9" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/sde: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="8955e286-76c7-a860-7421-928527ed2f2e" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/sdc: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="04f481c7-5f9f-d02b-a759-61d0b880c975" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/sda: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="8440a728-ed6c-82a2-bbcf-2b533cc73f22" LABEL="omvnas:0" TYPE="linux_raid_member"
	/dev/sdk: PTUUID="5066a101-8bc4-412b-8c31-9989f6114efe" PTTYPE="gpt"
	/dev/sdj: PTUUID="0543fe2c-2926-4428-a9bb-4d8478340340" PTTYPE="gpt"
	/dev/sdh: PTUUID="bed11372-978a-482f-8eff-9d94f18c9b61" PTTYPE="gpt"
	mdadm --detail /dev/md0
	/dev/md0:
	           Version : 1.2
	     Creation Time : Sun Sep  3 15:35:48 2023
	        Raid Level : raid6
	     Used Dev Size : 18446744073709551615
	      Raid Devices : 11
	     Total Devices : 8
	       Persistence : Superblock is persistent
	       Update Time : Thu Feb  6 05:21:31 2025
	             State : active, FAILED, Not Started
	    Active Devices : 8
	   Working Devices : 8
	    Failed Devices : 0
	     Spare Devices : 0
	            Layout : left-symmetric
	        Chunk Size : 512K
	Consistency Policy : unknown
	              Name : omvnas:0  (local to host omvnas)
	              UUID : cbcc5712:da6b1419:139ade97:57c7348b
	            Events : 260594
	    Number   Major   Minor   RaidDevice State
	       -       0        0        0      removed
	       -       0        0        1      removed
	       -       0        0        2      removed
	       -       0        0        3      removed
	       -       0        0        4      removed
	       -       0        0        5      removed
	       -       0        0        6      removed
	       -       0        0        7      removed
	       -       0        0        8      removed
	       -       0        0        9      removed
	       -       0        0       10      removed
	       -       8       64        2      sync   /dev/sde
	       -       8       32        0      sync   /dev/sdc
	       -       8        0        1      sync   /dev/sda
	       -       8       80        9      sync   /dev/sdf
	       -       8       48        4      sync   /dev/sdd
	       -       8       16        3      sync   /dev/sdb
	       -       8      128        5      sync   /dev/sdi
	       -       8       96        7      sync   /dev/sdg
	cat /etc/mdadm/mdadm.conf
	# This file is auto-generated by openmediavault (https://www.openmediavault.org)
	# WARNING: Do not edit this file, your changes will get lost.
	# mdadm.conf
	# Please refer to mdadm.conf(5) for information about this file.
	# by default, scan all partitions (/proc/partitions) for MD superblocks.
	# alternatively, specify devices to scan, using wildcards if desired.
	# Note, if no DEVICE line is present, then "DEVICE partitions" is assumed.
	# To avoid the auto-assembly of RAID devices a pattern that CAN'T match is
	# used if no RAID devices are configured.
	DEVICE partitions
	# auto-create devices with Debian standard permissions
	CREATE owner=root group=disk mode=0660 auto=yes
	# automatically tag new arrays as belonging to the local system
	HOMEHOST <system>
	# definitions of existing MD arrays
	ARRAY /dev/md0 metadata=1.2 name=omvnas:0 UUID=cbcc5712:da6b1419:139ade97:57c7348b
	cat /proc/mdstat
	Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
	md0 : inactive sdi[5](S) sde[2](S) sdg[6](S) sdf[7](S) sdd[4](S) sda[1](S) sdc[0](S) sdb[3](S)
	      93750140928 blocks super 1.2
	unused devices: <none>
	mdadm --examine /dev/sd[a-k]
	/dev/sda:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Array UUID : cbcc5712:da6b1419:139ade97:57c7348b
	     Raid Level : raid6
	   Raid Devices : 11
	 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB)
	     Array Size : 105468811776 KiB (98.23 TiB 108.00 TB)
	  Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB)
	    Data Offset : 235520 sectors
	   Super Offset : 8 sectors
	   Unused Space : before=235440 sectors, after=21504 sectors
	          State : clean
	    Device UUID : 8440a728:ed6c82a2:bbcf2b53:3cc73f22
	Internal Bitmap : 8 sectors from superblock
	  Bad Block Log : 512 entries available at offset 56 sectors
	       Checksum : aa6cf6bd - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 1
	   Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing)
	/dev/sdb:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Raid Level : raid6
	   Raid Devices : 11
	          State : clean
	    Device UUID : 792c5ef1:7fb7335c:6f63b5a8:35548740
	       Checksum : a0a64df4 - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 3
	/dev/sdc:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Raid Level : raid6
	   Raid Devices : 11
	          State : clean
	    Device UUID : 04f481c7:5f9fd02b:a75961d0:b880c975
	       Checksum : a3552017 - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 0
	/dev/sdd:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Raid Level : raid6
	   Raid Devices : 11
	          State : clean
	    Device UUID : 3017eba0:37a383ff:202cdd24:668b7223
	       Checksum : 52962446 - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 4
	/dev/sde:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Raid Level : raid6
	   Raid Devices : 11
	          State : clean
	    Device UUID : 8955e286:76c7a860:74219285:27ed2f2e
	       Checksum : 524ddf1 - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 2
	/dev/sdf:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Raid Level : raid6
	   Raid Devices : 11
	          State : clean
	    Device UUID : bde193d0:b68dc1d5:11ed5f82:75a4a220
	       Checksum : b32fb355 - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 9
	/dev/sdg:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Raid Level : raid6
	   Raid Devices : 11
	          State : clean
	    Device UUID : 711a8d42:424ef6f6:9ff460cc:2bee0cb9
	       Checksum : 28c8fdd9 - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 7
	/dev/sdh:
	   MBR Magic : aa55
	Partition[0] :   4294967295 sectors at            1 (type ee)
	/dev/sdi:
	          Magic : a92b4efc
	        Version : 1.2
	    Feature Map : 0x1
	     Raid Level : raid6
	   Raid Devices : 11
	          State : clean
	    Device UUID : ee6cdfb3:c66c013a:09181573:a1f32bfd
	       Checksum : c7f997b8 - correct
	         Events : 260594
	     Chunk Size : 512K
	   Device Role : Active device 5
	/dev/sdj:
	   MBR Magic : aa55
	/dev/sdk:
	   MBR Magic : aa55
