BillyBlaze
  1. I was able to find a UART module to read out the boot. See the file attached of the full log I was able to capture. It seems to fail on this part: Starting kernel ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=0a0755af-1936-4167-9d26-9ca9a87a9103 does not exist. Dropping to a shell! U-Boot SPL 2025.10-rc3-armbian-2025.txt
  2. None of the images are no longer working for me, no matter which recent image I take, the A5E board just remains stuck with a solid blue light (with some green light flickering). I even tried compiling armbian myself, but that also didn't work. The only image working for me is the 25.02 version from earlier this year. I am using the Radxa A5E v1.2 version with 4gb ram. I also mounted the SD card to a linux machine and looked into /var/log for a boot file or reading the journal but I don't see any logs written. Have somebody stumbled unto a solution or does somebody have advice me how I can get the logs to find the culprit?
  3. Thank you, I can confirm I got wifi working. It seems it's not using its full capabilities yet, I believe M8800DS2 can reach 600Mbps? root@radxa-cubie-a5e:~# speedtest -I wlan0 (5Ghz) Speedtest by Ookla Server: Odido - Amsterdam (id: -) ISP: Odido Netherlands Idle Latency: 4.23 ms (jitter: 17.23ms, low: 4.14ms, high: 38.60ms) Download: 98.09 Mbps (data used: 74.8 MB) 21.69 ms (jitter: 3.98ms, low: 4.55ms, high: 30.03ms) Upload: 95.48 Mbps (data used: 43.1 MB) 39.30 ms (jitter: 2.27ms, low: 10.70ms, high: 43.91ms) Packet Loss: 0.0% Result URL: - root@radxa-cubie-a5e:~# speedtest -I wlan0 (2.4Ghz) Speedtest by Ookla Server: Odido - Amsterdam (id: -) ISP: Odido Netherlands Idle Latency: 6.20 ms (jitter: 1.25ms, low: 5.49ms, high: 8.00ms) Download: 8.57 Mbps (data used: 13.6 MB) 244.00 ms (jitter: 64.45ms, low: 11.59ms, high: 793.78ms) Upload: 2.13 Mbps (data used: 3.9 MB) 343.91 ms (jitter: 74.53ms, low: 20.12ms, high: 2764.11ms) Packet Loss: 0.0% Result URL: - root@radxa-cubie-a5e:~# speedtest -I end0 Speedtest by Ookla Server: Odido - Amsterdam (id: -) ISP: Odido Netherlands Idle Latency: 3.23 ms (jitter: 0.29ms, low: 2.83ms, high: 3.36ms) Download: 745.43 Mbps (data used: 741.8 MB) 31.46 ms (jitter: 38.90ms, low: 3.39ms, high: 397.61ms) Upload: 834.05 Mbps (data used: 397.4 MB) 41.68 ms (jitter: 44.13ms, low: 2.73ms, high: 459.89ms) Packet Loss: 0.0% Result URL: -
  4. _ _ _ __ __ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ ___ _ _ _ _ ___ / _|/ _(_)__(_)__ _| | / _ \| '_| ' \| '_ \ / _` | ' \___| || | ' \/ _ \ _| _| / _| / _` | | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| \_,_|_||_\___/_| |_| |_\__|_\__,_|_| v25.02 rolling for radxa cubie a5e running Armbian Linux 6.12.12-edge-sun55iw3 Packages: Debian stable (bookworm) Support: DIY (custom image) IP addresses: (LAN) IPv4: *.*.*.* IPv6: *::*:*:*:* (WAN) *.*.*.* Performance: Load: 1% Up time: 10 min Memory usage: 3% of 3.83G Usage of /: 4% of 29G Commands: Configuration : armbian-config Monitoring : htop Thank you for the hard work! I was also able to run the image with your latest changes. Things that didn't work for me yet (but of course expected at this time): - WLAN/bluetooth - NVME SSD
