How to get a headphone or simple mic to work on a ct as recording device?
In vanilla armbian for ct capture_use and playback_use are undefined in script.bin and
# arecord -l
does not list any devices.
According to http://www.cubieforums.com/index.php/topic,2211.msg20637.html#msg20637
I changed both values with bin2fex / fex2bin to "1", rebooted and now I get
**** List of CAPTURE Hardware Devices **** card 0: sunxicodec [sunxi-CODEC], device 0: M1 PCM [sunxi PCM] Subdevices: 1/1 Subdevice #0: subdevice #0
But any try to capture noise from different microphones or headsets does not work. Playback is not an issue (speaker-test works as expected). Every try with
# arecord -vvv -c 2 /tmp/my.wav
produces a file with silence.
Did I miss anything?
TIA
-- output of amixer contents
numid=1,iface=MIXER,name='Master Playback Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=63,step=0 : values=51 numid=14,iface=MIXER,name='Master Capture Mute' ; type=BOOLEAN,access=rw------,values=1 : values=on numid=13,iface=MIXER,name='Line output Volume' ; type=BOOLEAN,access=rw------,values=1 : values=on numid=5,iface=MIXER,name='LineL Switch' ; type=BOOLEAN,access=rw------,values=1 : values=on numid=6,iface=MIXER,name='LineR Switch' ; type=BOOLEAN,access=rw------,values=1 : values=on numid=17,iface=MIXER,name='Linein Pre-AMP' ; type=INTEGER,access=rw------,values=1,min=0,max=7,step=0 : values=4 numid=10,iface=MIXER,name='Mic Input Mux' ; type=INTEGER,access=rw------,values=1,min=0,max=15,step=0 : values=9 numid=24,iface=MIXER,name='Mic Power' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=23,iface=MIXER,name='Mic1 Boost' ; type=BOOLEAN,access=rw------,values=1 : values=on numid=27,iface=MIXER,name='Mic1 gain Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=3,step=0 : values=2 numid=22,iface=MIXER,name='Mic2 Boost' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=26,iface=MIXER,name='Mic2 gain Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=7,step=0 : values=0 numid=20,iface=MIXER,name='MicL Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=3,step=0 : values=1 numid=21,iface=MIXER,name='MicR Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=3,step=0 : values=1 numid=25,iface=MIXER,name='ADC Input Mux' ; type=INTEGER,access=rw------,values=1,min=0,max=7,step=0 : values=2 numid=19,iface=MIXER,name='Capture Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=7,step=0 : values=5 numid=2,iface=MIXER,name='Playback Switch' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=12,iface=MIXER,name='Fm output Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=7,step=0 : values=3 numid=3,iface=MIXER,name='FmL Switch' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=4,iface=MIXER,name='FmR Switch' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=18,iface=MIXER,name='LINEIN APM Volume' ; type=INTEGER,access=rw------,values=1,min=0,max=7,step=0 : values=3 numid=7,iface=MIXER,name='Ldac Left Mixer' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=9,iface=MIXER,name='Ldac Right Mixer' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=16,iface=MIXER,name='Left Capture Mute' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=11,iface=MIXER,name='MIC output volume' ; type=INTEGER,access=rw------,values=1,min=0,max=7,step=0 : values=3 numid=8,iface=MIXER,name='Rdac Right Mixer' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=15,iface=MIXER,name='Right Capture Mute' ; type=BOOLEAN,access=rw------,values=1 : values=off
