So a clean install of "Armbian 25.2.1 Noble Gnome" with the vendor kernel (6.1.99) fails to boot when installed on an nvme SSDwith the armbian-install script, when btrfs is chosen as the partition type.
	I am not sure if the files are copied over correctly, since the ~6GB image on the SD card is copied as 2.9GB on the btrfs partition, but there are no errors occuring as far as I can see. The bootloader is up-to-date, and I can access the btrfs drive when booted from the SD card, so the kernel supports btrfs I guess?
	However, I think there are some things going "wrong", since the armbianEnv.txt file on the nvme SSD has ext4 instead of btrfs as the rootfs? This is basically my first install of armbian so I don't know that much about the installation procedure, but I just followed the official guide (which is also somehow out of date afaik, the images seem wrong...)
	(Additionally, apt update + upgrade don't work right now, erroring out with "Mirror sync in progress", so I don't know if this failure is happening because of out of date packages...)
