Hello, I am running into an issue with a Broken Pipe error on one of my two Orange Pi devices, even with the --fix option.
The two Orange Pis (dns1 and dns2) are nearly identical, both are running PiHole. The only difference is dns1 has an extra package (Nebula, and its dependencies) to sync PiHole information over to dns2.
When I run shrink-backup on dns2, and back it up to /mnt/backups/PhHole (an NFS mount back to my NAS), it works perfectly.
When I run the same command on dns1, it terminates with a Broken Pipe error:
root@dns1:/home/orangepi# /root/shrink-backup/shrink-backup --fix /mnt/backups/PiHole/dns1.img
(Snip lots of unneeded output)
var/lib/snapd/cache/
var/lib/snapd/cache/027a50a18054f65e1f36334c4246c44f5f2f7d037608419191b2c83a58e5afda831a4a1096e878f6b91e5cbb3d49d08b
4.03G 75% 10.82MB/s 0:05:55 (xfr#120880, to-chk=1043/148245)
var/lib/snapd/cache/56bd390cd391c0d702651d6489bfa8b61ed4c096b604c14e5d10fd99020e3cdf8fb4467b6f9703aacf0609dcd55b26b0
4.11G 77% 10.92MB/s 0:05:58 (xfr#120881, to-chk=1041/148245)
var/lib/snapd/cache/c1c16377ccf539e6292263cd0a579cdf04956110104909a72c492677c30b017542f1f4683a220fd895b68d600e14bceb
4.18G 78% 11.00MB/s 0:06:02 (xfr#120882, to-chk=1037/148245)
var/lib/snapd/cache/f60dc4c9c0a8f6f7ddefb04334e5eb74d9bc31305a09911f71deee520569742e40edd137c876b8be67ddfe94afb97266
4.19G 78% 19.53MB/s 0:00:56 rsync: [receiver] write failed on "/tmp/backup-SbW/var/lib/snapd/cache/f60dc4c9c0a8f6f7ddefb04334e5eb74d9bc31305a09911f71deee520569742e40edd137c876b8be67ddfe94afb97266": No space left on device (28)
rsync error: error in file IO (code 11) at receiver.c(381) [receiver=3.2.7]
rsync: [sender] write error: Broken pipe (32)
var/lib/snapd/assertions/asserts-v0/snap-revision/wcFjd8z1OeYpImPNClec3wSVYRAQSQmnLEkmd8MLAXVC8fRoOiIP2JW2jWAOFLzr/active
3.96G 74% 10.72MB/s 0:05:52 (xfr#120879, to-chk=1047/148245)
var/lib/snapd/assertions/private-keys-v1/
var/lib/snapd/auto-import/
!! RSYNC FAILED!!!
!! Cleanup function called with non zero exit code, something went wrong!!!
## Exiting and cleaning up...
## Please stand by...
## Done.
## Elapsed time: 06.56
Are you able to help me troubleshoot / diagnose this issue, please? The SD card is 32 GB, there should be plenty of free space, and the NAS itself has plenty of space as well.
Thank you!
