lovenemesis
6 -
Sorry for the late feedback. I was waiting for a new kernel update (6.12.54-bcm2711) to confirm it was all right. Just as what @Werner said, in the `/etc/initramfs/post-update.d/z50-raspi-firmware` contains snippets of the code that prints out the error. And it's indeed no actual harm. Also, without setting on-hold of the `raspi-firmware`, kernel updates works just fine. We are good. Thank you all!
Thanks for your sharing! While I was trying to perform the upgrade for a Pine64, I happily notice that the latest release of armbian-config actually have an option for the distro upgrade. By following the wizard, Debian was upgrade to trixie.
Recently, when I run `armbian-upgrade`, I was greeted with an update to raspi-firmware. However, this version of firmware doesn't seem to work with the corresponding intramfs with kernel 6.12.44. sudo armbian-upgrade Hit:1 https://mirrors.ustc.edu.cn/armbian trixie InRelease Hit:2 https://mirrors.ustc.edu.cn/debian trixie InRelease Hit:3 https://mirrors.ustc.edu.cn/debian trixie-updates InRelease Hit:4 https://mirrors.ustc.edu.cn/debian-security trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Get:6 https://apt.syncthing.net syncthing InRelease [24.2 kB] Fetched 24.2 kB in 2s (14.8 kB/s) 2 packages can be upgraded. Run 'apt list --upgradable' to see them. The following packages will be upgraded: armbian-config raspi-firmware Summary: Upgraded: 2, Newly installed: 0, To remove: 0, Not upgraded: 0 Download size: 13.2 MB Space required/available: 272 kB / 553 GB Get:1 https://mirrors.ustc.edu.cn/armbian trixie/trixie-utils arm64 raspi-firmware all 1:1.20250915-1~bookworm [13.0 MB] Get:2 https://github.armbian.com/configng stable/main arm64 armbian-config all 25.11.0-trunk.234.0923.175957 [157 kB] Fetched 13.2 MB in 2s (5,967 kB/s) (Reading database ... 46602 files and directories currently installed.) Preparing to unpack .../raspi-firmware_1%3a1.20250915-1~bookworm_all.deb ... Unpacking raspi-firmware (1:1.20250915-1~bookworm) over (1:1.20250430-4~bookworm) ... Preparing to unpack .../armbian-config_25.11.0-trunk.234.0923.175957_all.deb ... Unpacking armbian-config (25.11.0-trunk.234.0923.175957) over (25.11.0-trunk.192.0915.191809) ... Setting up armbian-config (25.11.0-trunk.234.0923.175957) ... Setting up raspi-firmware (1:1.20250915-1~bookworm) ... Installing new version of config file /etc/initramfs/post-update.d/z50-raspi-firmware ... Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ... WARNING: Unsupported kernel version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Processing triggers for initramfs-tools (0.148.3) ... update-initramfs: Generating /boot/initrd.img-6.12.44-current-bcm2711 WARNING: Unsupported initramfs version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Summary: Upgraded: 0, Newly installed: 0, To remove: 0, Not upgraded: 0 How exactly should I do in this case? In the past, I normally invoke update-intramfs to perform the the intramfs update. Thanks,
Failed to boot after trying to manually upgrade kernel
lovenemesis replied to lovenemesis's topic in Raspberry Pi
Many thanks for the reply! Good news is that with your guideline and a bit more information from qwen-code, I managed to chroot to it. It's a bit more complicated to do from a Ryzen Linux machine. A translation layer called "qemu-aarch64-static" is required. It's far more straightforward on a PineBook Pro due to the same architecture. Not so good ones is that reinstalling the old RPi5 specific 6.6 kernel still fails to boot. update-intramfs was automatically run during reinstalling the old kernel and uinitrd in /boot was updated by some scripts(according to last modified time stamp), with symlink as described in armbianEnv.txt. Everything seems to be at the right place and wired in the expected way. Quite confused. Great news is that despite the unsuccesful to restore the kernel, the chroot provide me an enough environment to utilize calcardbackup to extract the personal data from NextCloud database. Better news is that I took this opportunity to start fresh with Armbian 25.8.1 Debian Trixie with Kernel 6.12.44. So far it works beautifully on RPi5. -
Upon reading the content of RPi5 about 6.12 from this and this , I was under the impression that it's okay to upgrade the Armbian 24.11 based NextCloudPi to a 6.12 kernel. Well, I was wrong and the RPi5 current stuck in the RPi Logo on a black page. Net address seems to be 0.0.0.0. I could really use some advice on how to restore this, perhaps some `chroot` method from another Linux machine to get the right kernel package and intramfs. Here are the steps that got me to the current situation. Maybe a hint on how to restore? 1. Mark `raspi-firmware`, like what was recommended in 1st post. sudo apt-mark hold raspi-firmware [sudo] password for pi: raspi-firmware set on hold. 2. Remove the old bsp for RPi5b specific package? pi@nextcloudpi:~$ sudo dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi5b-current dpkg: warning: ignoring request to remove libraspberrypi0 which isn't installed (Reading database ... 50983 files and directories currently installed.) Removing armbian-bsp-cli-rpi5b-current (24.11.1) ... Armbian 'armbian-bsp-cli-rpi5b-current' for '1-PC980a-V32ae-H032a-B6e44-R7697': 'postrm' starting. Armbian 'armbian-bsp-cli-rpi5b-current' for '1-PC980a-V32ae-H032a-B6e44-R7697': 'postrm' finishing. Processing triggers for initramfs-tools (0.142+deb12u3) ... update-initramfs: Generating /boot/initrd.img-6.6.63-current-bcm2712 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152 3. Install the newer RPI4b bsp package, which guessing from the 2nd post, including everything from 3b to 5b. pi@nextcloudpi:~$ sudo apt install armbian-bsp-cli-rpi4b-current Reading package lists... Done Building dependency tree... Done Reading state information... Done The following NEW packages will be installed: armbian-bsp-cli-rpi4b-current 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 1,515 kB of archives. After this operation, 5,411 kB of additional disk space will be used. Get:1 https://mirrors.ustc.edu.cn/armbian bookworm/main arm64 armbian-bsp-cli-rpi4b-current arm64 25.8.1 [1,515 kB] Fetched 1,515 kB in 2s (1,008 kB/s) Selecting previously unselected package armbian-bsp-cli-rpi4b-current. (Reading database ... 50867 files and directories currently installed.) Preparing to unpack .../armbian-bsp-cli-rpi4b-current_25.8.1_arm64.deb ... Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'preinst' starting. Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'preinst' finishing. Unpacking armbian-bsp-cli-rpi4b-current (25.8.1) ... Setting up armbian-bsp-cli-rpi4b-current (25.8.1) ... Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'postinst' starting. Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'postinst' finishing. Processing triggers for initramfs-tools (0.142+deb12u3) ... update-initramfs: Generating /boot/initrd.img-6.6.63-current-bcm2712 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152 4. I notice the initrd was still generated for the old kernel image, which is understandable based what is currently installed pi@nextcloudpi:~$ uname -a Linux nextcloudpi 6.6.63-current-bcm2712 #2 SMP PREEMPT Wed Nov 27 10:28:46 UTC 2024 aarch64 GNU/Linux pi@nextcloudpi:~$ dpkg -l | grep linux-image ii linux-image-current-bcm2712 24.11.1 arm64 Armbian Linux current kernel image 6.6.63-current-bcm2712 5. Therefore, I went ahead to install the new 6.12 kernel package pi@nextcloudpi:~$ sudo apt install linux-image-current-bcm2711 Reading package lists... Done Building dependency tree... Done Reading state information... Done The following NEW packages will be installed: linux-image-current-bcm2711 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 34.5 MB of archives. After this operation, 212 MB of additional disk space will be used. Get:1 https://mirrors.ustc.edu.cn/armbian bookworm/main arm64 linux-image-current-bcm2711 arm64 25.8.1 [34.5 MB] Fetched 34.5 MB in 5s (7,198 kB/s) Selecting previously unselected package linux-image-current-bcm2711. (Reading database ... 51028 files and directories currently installed.) Preparing to unpack .../linux-image-current-bcm2711_25.8.1_arm64.deb ... Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'preinst' starting. Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'preinst' finishing. Unpacking linux-image-current-bcm2711 (25.8.1) ... Setting up linux-image-current-bcm2711 (25.8.1) ... Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'postinst' starting. update-initramfs: Generating /boot/initrd.img-6.12.44-current-bcm2711 Armbian: update last-installed kernel symlink to 'Image'... '/boot/Image' -> 'vmlinuz-6.12.44-current-bcm2711' Armbian: Debian compat: linux-update-symlinks install 6.12.44-current-bcm2711 boot/vmlinuz-6.12.44-current-bcm2711 I: /vmlinuz is now a symlink to boot/vmlinuz-6.12.44-current-bcm2711 I: /initrd.img is now a symlink to boot/initrd.img-6.12.44-current-bcm2711 Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'postinst' finishing. 6. Everything looked right to me as there are no errors like before got reported during update-initramfs: pi@nextcloudpi:~$ sudo apt remove linux-image-current-bcm2712 Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be REMOVED: linux-image-current-bcm2712 0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded. After this operation, 155 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 54440 files and directories currently installed.) Removing linux-image-current-bcm2712 (24.11.1) ... Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'prerm' starting. Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'prerm' finishing. Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'postrm' starting. update-initramfs: Deleting /boot/initrd.img-6.6.63-current-bcm2712 Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'postrm' finishing. 7. As a final check, I ran the upgrade script again pi@nextcloudpi:~$ sudo armbian-upgrade Hit:1 https://mirrors.ustc.edu.cn/debian bookworm InRelease Hit:2 https://mirrors.ustc.edu.cn/debian bookworm-updates InRelease Hit:3 https://mirrors.ustc.edu.cn/debian bookworm-backports InRelease Hit:4 https://mirrors.ustc.edu.cn/debian-security bookworm-security InRelease Hit:5 https://mirrors.ustc.edu.cn/armbian bookworm InRelease Hit:6 https://github.armbian.com/configng stable InRelease Hit:7 https://packages.sury.org/php bookworm InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 8. That's it. After rebooting, I was greeted with a RPi logo on a black page, with some messaging scrolling (trying to attach a photo but failed). It never got to the point to boot the kernel image or systemd booting sequence.
