d1nuc0m
  1. Disclaimer: I know it's not a good idea XD Is it possible somehow to upgrade the prebuilt image Armbian 12/OpenMediaVault 7 to Armbian 13/OpenMediaVault 8? Is there a guide?
  2. Hi all, I just installed Armbian Linux v6.12 with OpenMediaVault (build date 2025/09/23) on a Odroid HC4. When I try to use apt update I get these errors Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Is this expected and related to Armbian setup or should I ask on OMV forum?
  3. Hi all, I just installed Armbian with OpenMediaVault on a Odroid HC4 (v25.8.2 for Odroid HC4 running Armbian Linux 6.12.48-current-meson64), when I tried to disable automatic updates in armbian-config it purged a lot of packages including openmediavault. Guess this is a bug, in case where should I report it?
