王类
  1. I bricked my original H96MAX TV box while tinkering with it, so I bought a new one. The new unit works fine with both wireless and wired networks on Android, but after flashing the firmware Armbian_26.2.0-trunk.302_H96-tvbox-3566_forky_current_6.18.6_minimal.img, the wired network stops working and only the wireless network is functional. Please help me fix this issue, thank you!
  2. @WINEDS@Hqnicolas Thank you for your help. I will try to see if it can run normally.
  3. I have changed it to public。 https://drive.google.com/file/d/1vyQGR8kgzhCzmwuXhb8q5j707U9IXFob/view?usp=sharing And images of my board: https://drive.google.com/drive/folders/1mKd1T83COy1KDLsmb9PbNnlm5FhdrBbV?usp=sharing
  4. https://drive.google.com/file/d/1vyQGR8kgzhCzmwuXhb8q5j707U9IXFob/view?usp=sharing The file in this shared link is the image file provided by the manufacturer for my Android device. I hope it will be useful, and thank you for your help! I can't compile a custom Armbian image and hope to get help from the community.@Hqnicolas
  5. Could you please tell me in detail how to use these files? My knowledge of Linux is very limited. Do I need to recompile a custom image suitable for myself, or how should I use these files to carry out specific operations to solve my problem? Thank you.
  6. root@h96-tvbox-3566:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.12.57-current-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Sun Nov 2 13:15:23 UTC 2025 [ 0.000000] KASLR enabled [ 0.000000] Machine model: h96 TVbox 3566 [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0x1ff7650c0-0x1ff76783f] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 0.000000] node 0: [mem 0x00000001f0000000-0x00000001ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x00000000e3a00000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 34 pages/cpu s99416 r8192 d31656 u139264 [ 0.000000] pcpu-alloc: s99416 r8192 d31656 u139264 alloc=34*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=02d6f139-439e-4f03-b522-ea8c640bdf2c rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=981ba9e7-9a6c-4e13-8b12-c3374087ba24 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u dwmac-rk.phy_addr=1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=981ba9e7-9a6c-4e13-8b12-c3374087ba24 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1048064 [ 0.000000] Policy zone: Normal [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000dfa00000-0x00000000e3a00000] (64MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 320 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [296:319] [ 0.000000] GICv3: Using MBI frame 0x00000000fd410000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001281] Console: colour dummy device 80x25 [ 0.001303] printk: legacy console [tty1] enabled [ 0.001519] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001546] pid_max: default: 32768 minimum: 301 [ 0.001667] LSM: initializing lsm=capability,yama,apparmor [ 0.001762] Yama: becoming mindful. [ 0.002092] AppArmor: AppArmor initialized [ 0.002255] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002291] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.006553] rcu: Hierarchical SRCU implementation. [ 0.006578] rcu: Max phase no-delay instances is 1000. [ 0.007050] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.008342] EFI services will not be available. [ 0.008880] smp: Bringing up secondary CPUs ... [ 0.009999] Detected VIPT I-cache on CPU1 [ 0.010105] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.010168] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.011420] Detected VIPT I-cache on CPU2 [ 0.011515] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.011570] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.012992] Detected VIPT I-cache on CPU3 [ 0.013094] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.013149] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.013348] smp: Brought up 1 node, 4 CPUs [ 0.013378] SMP: Total of 4 processors activated. [ 0.013387] CPU: All CPU(s) started at EL2 [ 0.013396] CPU features: detected: 32-bit EL0 Support [ 0.013403] CPU features: detected: 32-bit EL1 Support [ 0.013414] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.013423] CPU features: detected: Common not Private translations [ 0.013431] CPU features: detected: CRC32 instructions [ 0.013447] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.013454] CPU features: detected: LSE atomic instructions [ 0.013462] CPU features: detected: Privileged Access Never [ 0.013468] CPU features: detected: RAS Extension Support [ 0.013479] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.013568] alternatives: applying system-wide alternatives [ 0.018533] Memory: 3851236K/4192256K available (16832K kernel code, 2934K rwdata, 11432K rodata, 5248K init, 790K bss, 205556K reserved, 131072K cma-reserved) [ 0.020380] devtmpfs: initialized [ 0.045281] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.045339] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.049748] 23408 pages in range for non-PLT usage [ 0.049777] 514928 pages in range for PLT usage [ 0.050149] pinctrl core: initialized pinctrl subsystem [ 0.051202] DMI not present or invalid. [ 0.055961] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.058258] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.059446] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.060691] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.060779] audit: initializing netlink subsys (disabled) [ 0.061164] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1 [ 0.062444] thermal_sys: Registered thermal governor 'fair_share' [ 0.062457] thermal_sys: Registered thermal governor 'bang_bang' [ 0.062467] thermal_sys: Registered thermal governor 'step_wise' [ 0.062474] thermal_sys: Registered thermal governor 'user_space' [ 0.062575] cpuidle: using governor menu [ 0.063005] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.063244] ASID allocator initialised with 32768 entries [ 0.063588] Serial: AMBA PL011 UART driver [ 0.079115] /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.079248] /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000 [ 0.104599] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.105237] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [ 0.105729] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.106137] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [ 0.106815] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.107233] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [ 0.107690] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.108077] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [ 0.108521] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.108914] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [ 0.111037] /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con [ 0.111179] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.118988] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.119013] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.119024] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.119032] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.119042] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.119049] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.119060] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.119067] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.121318] cryptd: max_cpu_qlen set to 1000 [ 0.187082] raid6: neonx8 gen() 1406 MB/s [ 0.255225] raid6: neonx4 gen() 1436 MB/s [ 0.323369] raid6: neonx2 gen() 1319 MB/s [ 0.391507] raid6: neonx1 gen() 1073 MB/s [ 0.459650] raid6: int64x8 gen() 912 MB/s [ 0.527787] raid6: int64x4 gen() 1045 MB/s [ 0.595931] raid6: int64x2 gen() 936 MB/s [ 0.664082] raid6: int64x1 gen() 691 MB/s [ 0.664097] raid6: using algorithm neonx4 gen() 1436 MB/s [ 0.732214] raid6: .... xor() 1100 MB/s, rmw enabled [ 0.732228] raid6: using neon recovery algorithm [ 0.733556] iommu: Default domain type: Translated [ 0.733576] iommu: DMA domain TLB invalidation policy: strict mode [ 0.734901] SCSI subsystem initialized [ 0.735254] libata version 3.00 loaded. [ 0.735625] usbcore: registered new interface driver usbfs [ 0.735699] usbcore: registered new interface driver hub [ 0.735755] usbcore: registered new device driver usb [ 0.736511] pps_core: LinuxPPS API ver. 1 registered [ 0.736525] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.736551] PTP clock support registered [ 0.736611] EDAC MC: Ver: 3.0.0 [ 0.737162] scmi_core: SCMI protocol bus registered [ 0.738840] NetLabel: Initializing [ 0.738854] NetLabel: domain hash size = 128 [ 0.738864] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.738962] NetLabel: unlabeled traffic allowed by default [ 0.739240] vgaarb: loaded [ 0.740044] clocksource: Switched to clocksource arch_sys_counter [ 0.745226] VFS: Disk quotas dquot_6.6.0 [ 0.745299] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.746518] AppArmor: AppArmor Filesystem Enabled [ 0.762179] NET: Registered PF_INET protocol family [ 0.762589] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.836463] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.836699] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.836818] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.837411] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.838375] TCP: Hash tables configured (established 32768 bind 32768) [ 0.838600] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.838728] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.839096] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.839150] NET: Registered PF_XDP protocol family [ 0.839175] PCI: CLS 0 bytes, default 64 [ 0.839616] Trying to unpack rootfs image as initramfs... [ 0.849450] kvm [1]: nv: 554 coarse grained trap handlers [ 0.850093] kvm [1]: IPA Size Limit: 40 bits [ 0.850147] kvm [1]: GICv3: no GICV resource entry [ 0.850160] kvm [1]: disabling GICv2 emulation [ 0.850210] kvm [1]: GIC system register CPU interface enabled [ 0.850255] kvm [1]: vgic interrupt IRQ9 [ 0.850315] kvm [1]: VHE mode initialized successfully [ 0.853418] Initialise system trusted keyrings [ 0.853509] Key type blacklist registered [ 0.853934] workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 0.854016] zbud: loaded [ 0.854816] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.855484] fuse: init (API version 7.41) [ 0.858338] integrity: Platform Keyring initialized [ 0.932593] xor: measuring software checksum speed [ 0.934529] 8regs : 1719 MB/sec [ 0.936661] 32regs : 1553 MB/sec [ 0.938577] arm64_neon : 1726 MB/sec [ 0.938588] xor: using function: arm64_neon (1726 MB/sec) [ 0.938609] Key type asymmetric registered [ 0.938621] Asymmetric key parser 'x509' registered [ 0.938818] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.939252] io scheduler mq-deadline registered [ 0.939271] io scheduler kyber registered [ 0.939348] io scheduler bfq registered [ 2.140739] Freeing initrd memory: 20564K [ 2.152225] ledtrig-cpu: registered to indicate activity on CPUs [ 2.162563] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.162593] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.165930] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.165958] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.169241] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 2.175501] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 25, base_baud = 1500000) is a 16550A [ 2.176112] serial serial0: tty port ttyS1 registered [ 2.177966] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 26, base_baud = 1500000) is a 16550A [ 2.178226] printk: legacy console [ttyS2] enabled [ 2.179993] Serial: AMBA driver [ 2.193516] loop: module loaded [ 2.195458] Key type psk registered [ 2.201340] thunder_xcv, ver 1.0 [ 2.201425] thunder_bgx, ver 1.0 [ 2.201493] nicpf, ver 1.0 [ 2.212937] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.212991] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 2.213204] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 2.213222] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 2.213303] xhci-hcd xhci-hcd.0.auto: irq 30, io mem 0xfcc00000 [ 2.213819] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.213843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.213858] usb usb1: Product: xHCI Host Controller [ 2.213870] usb usb1: Manufacturer: Linux 6.12.57-current-rockchip64 xhci-hcd [ 2.213882] usb usb1: SerialNumber: xhci-hcd.0.auto [ 2.214743] hub 1-0:1.0: USB hub found [ 2.214812] hub 1-0:1.0: 1 port detected [ 2.215548] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.215587] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 2.215779] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 2.215851] xhci-hcd xhci-hcd.1.auto: irq 31, io mem 0xfd000000 [ 2.216153] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.216182] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3 [ 2.216206] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 2.216505] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.216528] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.216543] usb usb2: Product: xHCI Host Controller [ 2.216555] usb usb2: Manufacturer: Linux 6.12.57-current-rockchip64 xhci-hcd [ 2.216567] usb usb2: SerialNumber: xhci-hcd.1.auto [ 2.217325] hub 2-0:1.0: USB hub found [ 2.217394] hub 2-0:1.0: 1 port detected [ 2.218015] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.218264] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12 [ 2.218287] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.218302] usb usb3: Product: xHCI Host Controller [ 2.218314] usb usb3: Manufacturer: Linux 6.12.57-current-rockchip64 xhci-hcd [ 2.218326] usb usb3: SerialNumber: xhci-hcd.1.auto [ 2.219048] hub 3-0:1.0: USB hub found [ 2.219130] hub 3-0:1.0: 1 port detected [ 2.219836] usbcore: registered new interface driver usb-storage [ 2.222714] mousedev: PS/2 mouse device common for all mice [ 2.223443] i2c_dev: i2c /dev entries driver [ 2.229358] rockchip-thermal fe710000.tsadc: Missing tshut mode property, using default (gpio) [ 2.229390] rockchip-thermal fe710000.tsadc: Missing tshut-polarity property, using default (low) [ 2.233395] sdhci: Secure Digital Host Controller Interface driver [ 2.233419] sdhci: Copyright(c) Pierre Ossman [ 2.233468] Synopsys Designware Multimedia Card Interface Driver [ 2.234545] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.237311] arm-scmi arm-scmi.2.auto: Using scmi_smc_transport [ 2.237337] arm-scmi arm-scmi.2.auto: SCMI max-rx-timeout: 30ms [ 2.237556] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 2.237954] arm-scmi arm-scmi.2.auto: SCMI Notifications - Core Enabled. [ 2.238043] arm-scmi arm-scmi.2.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 2.239622] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 2.239958] hid: raw HID events driver (C) Jiri Kosina [ 2.240590] usbcore: registered new interface driver usbhid [ 2.240605] usbhid: USB HID core driver [ 2.242290] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x8, channels: 1 [ 2.244433] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available [ 2.246189] NET: Registered PF_INET6 protocol family [ 2.307474] Segment Routing with IPv6 [ 2.307622] In-situ OAM (IOAM) with IPv6 [ 2.307751] NET: Registered PF_PACKET protocol family [ 2.307832] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.308191] Key type dns_resolver registered [ 2.322627] registered taskstats version 1 [ 2.323107] Loading compiled-in X.509 certificates [ 2.342427] zswap: loaded using pool zstd/zbud [ 2.342962] Demotion targets for Node 0: null [ 2.343508] Key type .fscrypt registered [ 2.343523] Key type fscrypt-provisioning registered [ 2.348171] Btrfs loaded, zoned=yes, fsverity=yes [ 2.348460] Key type encrypted registered [ 2.348484] AppArmor: AppArmor sha256 policy hashing enabled [ 2.391112] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [ 2.505752] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [ 2.505841] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [ 2.505859] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [ 2.505923] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo [ 2.506096] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 2.506167] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 2.506186] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 2.506263] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo [ 2.508493] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO [ 2.509670] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq [ 2.509699] mmc_host mmc2: card is non-removable. [ 2.520556] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.524818] WCN: marlin_init entry! [ 2.525509] of_cfs_init [ 2.525576] of_cfs_init: OK [ 2.544299] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [ 2.576559] clk: Disabling unused clocks [ 2.577449] PM: genpd: Disabling unused power domains [ 2.626663] mmc1: new HS200 MMC card at address 0001 [ 2.627719] mmcblk1: mmc1:0001 032G74 29.1 GiB [ 2.632265] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.633175] mmcblk1: p1 [ 2.634102] mmcblk1boot0: mmc1:0001 032G74 4.00 MiB [ 2.636494] mmcblk1boot1: mmc1:0001 032G74 4.00 MiB [ 2.638579] mmcblk1rpmb: mmc1:0001 032G74 4.00 MiB, chardev (243:0) [ 2.647995] Freeing unused kernel memory: 5248K [ 2.648340] Run /init as init process [ 2.648354] with arguments: [ 2.648364] /init [ 2.648374] with environment: [ 2.648382] HOME=/ [ 2.648391] TERM=linux [ 2.648399] splash=verbose [ 2.648407] ubootpart=981ba9e7-9a6c-4e13-8b12-c3374087ba24 [ 2.648417] cgroup_enable=memory [ 2.648426] cgroup_memory=1 [ 2.665863] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0) [ 2.840151] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 173 [ 2.843621] mmc2: new ultra high speed SDR50 SDIO card at address 390b [ 3.208313] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd [ 3.225766] usb 3-1: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=31.04 [ 3.225806] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 3.225821] usb 3-1: Product: USB 10/100/1G/2.5G LAN [ 3.225833] usb 3-1: Manufacturer: Realtek [ 3.225844] usb 3-1: SerialNumber: 4013000001 [ 3.386799] usbcore: registered new device driver r8152-cfgselector [ 3.592883] r8152-cfgselector 3-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 3.720274] r8152 3-1:1.0 eth0: v1.12.13 [ 3.720479] usbcore: registered new interface driver r8152 [ 3.724881] usbcore: registered new interface driver cdc_ether [ 3.727119] usbcore: registered new interface driver cdc_ncm [ 3.814188] rockchip-vop2 fe040000.vop: Adding to iommu group 0 [ 3.830334] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) [ 3.837545] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.845616] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 3.846347] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) [ 3.847804] rk808-rtc rk808-rtc.6.auto: registered as rtc0 [ 3.849294] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 [ 3.849556] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 3.849713] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 3.851651] rk808-rtc rk808-rtc.6.auto: setting system clock to 2025-11-11T14:23:04 UTC (1762870984) [ 3.914828] dwmac_rk: unknown parameter 'phy_addr' ignored [ 3.916833] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 3.916867] rk_gmac-dwmac fe010000.ethernet: IRQ sfty not found [ 3.926725] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 3.926762] rk_gmac-dwmac fe010000.ethernet: TX delay(0x41). [ 3.926780] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2e). [ 3.926807] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 3.926882] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 3.932126] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 3.932639] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 3.932676] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 3.932692] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 3.932704] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 3.932715] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 3.932724] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 3.932884] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 3.932903] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.932918] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 3.932931] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 3.932943] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.004256] i2c i2c-7: Not I2C compliant: can't read SDA [ 4.004288] i2c i2c-7: Not I2C compliant: can't read SCL [ 4.004299] i2c i2c-7: Bus may be unreliable [ 4.004314] i2c-gpio i2c-aux-display: using lines 12 (SDA) and 11 (SCL, no clock stretching) [ 4.044582] r8152 3-1:1.0 enx00e04c1800a5: renamed from eth0 [ 4.258180] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 4.424695] r8152-cfgselector 3-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 4.540302] r8152 3-1:1.0 eth0: v1.12.13 [ 4.634763] r8152 3-1:1.0 enx00e04c1800a5: renamed from eth0 [ 4.790481] EXT4-fs (mmcblk1p1): mounted filesystem 02d6f139-439e-4f03-b522-ea8c640bdf2c ro with writeback data mode. Quota mode: none. [ 5.297007] systemd[1]: Inserted module 'autofs4' [ 5.355293] systemd[1]: systemd 257.8-1~deb13u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 5.355403] systemd[1]: Detected architecture arm64. [ 5.364981] systemd[1]: Hostname set to <h96-tvbox-3566>. [ 5.876905] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported. [ 5.991722] dw-apb-uart fe660000.serial: forbid DMA for kernel console [ 6.773136] systemd[1]: Queued start job for default target graphical.target. [ 6.826887] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [ 6.831223] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ 6.835310] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 6.838382] systemd[1]: Created slice user.slice - User and Session Slice. [ 6.839385] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch. [ 6.840277] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ 6.841981] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [ 6.842539] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2... [ 6.843079] systemd[1]: Reached target paths.target - Path Units. [ 6.843532] systemd[1]: Reached target remote-fs.target - Remote File Systems. [ 6.843941] systemd[1]: Reached target slices.target - Slice Units. [ 6.844476] systemd[1]: Reached target swap.target - Swaps. [ 6.845734] systemd[1]: Listening on syslog.socket - Syslog Socket. [ 6.853290] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption. [ 6.854452] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 6.855496] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ 6.856831] systemd[1]: Listening on systemd-journald.socket - Journal Sockets. [ 6.858261] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket. [ 6.858829] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 6.858989] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 6.859788] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ 6.860809] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 6.868820] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System... [ 6.875789] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 6.883809] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock... [ 6.891566] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 6.909632] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System... [ 6.925815] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 6.970432] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... [ 6.989909] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... [ 6.999439] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... [ 7.016730] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 7.037942] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 7.059514] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... [ 7.060409] systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl). [ 7.060997] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 7.113475] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 7.129285] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line... [ 7.132663] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.133330] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.153188] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials... [ 7.164339] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 7.208461] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ 7.209936] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 7.211358] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ 7.221176] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 7.222703] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 7.228820] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 7.246829] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 7.250903] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 7.253861] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.255423] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 7.270398] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.272244] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 7.275573] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.277399] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 7.280512] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.282574] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 7.293411] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 7.320774] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 7.321188] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 7.345629] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 7.361655] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully... [ 7.373739] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 7.388633] systemd[1]: Finished systemd-network-generator.service - Generate network units from Kernel command line. [ 7.412625] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials. [ 7.425447] systemd[1]: Reached target network-pre.target - Preparation for Network. [ 7.455126] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 7.477400] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 7.523185] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 7.563259] EXT4-fs (mmcblk1p1): re-mounted 02d6f139-439e-4f03-b522-ea8c640bdf2c r/w. [ 7.572446] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 7.575034] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 7.575497] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 7.586713] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed... [ 7.587098] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.619384] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully. [ 7.621241] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 7.638610] systemd[1]: Starting systemd-timesyncd.service - Network Time Synchronization... [ 7.646668] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 7.651899] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 7.688863] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 7.716572] systemd[1]: Starting systemd-resolved.service - Network Name Resolution... [ 7.791053] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ 7.794063] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ 7.845106] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... [ 8.169507] systemd[1]: Started systemd-timesyncd.service - Network Time Synchronization. [ 8.170957] systemd[1]: Reached target time-set.target - System Time Set. [ 8.225270] systemd[1]: Mounting tmp.mount - /tmp... [ 8.387879] systemd[1]: Mounted tmp.mount - /tmp. [ 8.389334] systemd[1]: Reached target local-fs.target - Local File Systems. [ 8.398427] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management. [ 8.406047] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 8.421472] systemd[1]: Starting console-setup.service - Set console font and keymap... [ 8.454177] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats... [ 8.529036] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ 8.597230] systemd[1]: Starting systemd-networkd.service - Network Configuration... [ 8.673984] systemd[1]: Finished console-setup.service - Set console font and keymap. [ 8.677763] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 8.718705] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 263 (systemd-binfmt) [ 8.728692] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System... [ 8.871880] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System. [ 8.894538] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats. [ 9.541067] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 9.590243] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 9.591405] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 9.628819] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2. [ 9.946399] systemd[1]: Started systemd-networkd.service - Network Configuration. [ 9.972186] systemd[1]: Starting systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd... [ 9.983471] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 10.008535] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL) [ 10.030686] zram: Added device: zram0 [ 10.033372] zram: Added device: zram1 [ 10.155162] zram: Added device: zram2 [ 10.158668] r8152 3-1:1.0 enx00e04c1800a5: carrier on [ 10.292232] r8152 3-1:1.0 enx00e04c1800a5: Stop submitting intr, status -108 [ 10.331582] zram0: detected capacity change from 0 to 4012512 [ 10.393579] mc: Linux media interface: v0.10 [ 10.470481] panfrost fde60000.gpu: clock rate = 594000000 [ 10.470515] panfrost fde60000.gpu: bus_clock rate = 500000000 [ 10.489544] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0 [ 10.489565] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400 [ 10.489574] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7 [ 10.489582] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1 [ 10.490260] videodev: Linux video capture interface: v2.00 [ 10.577203] [drm] Initialized panfrost 1.2.0 for fde60000.gpu on minor 1 [ 10.591955] rockchip-rga fdeb0000.rga: HW Version: 0x03.02 [ 10.596084] random: crng init done [ 10.601538] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0 [ 10.618482] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed. [ 10.619483] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 10.619710] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 10.640697] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey.5.auto/input/input0 [ 10.652485] rockchip_vdec2: module is from the staging directory, the quality is unknown, you have been warned. [ 10.694123] hantro-vpu fdea0000.video-codec: Adding to iommu group 1 [ 10.696776] hantro-vpu fdea0000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2 [ 10.714076] rk2-crypto fe380000.crypto: will run requests pump with realtime priority [ 10.714157] rk2-crypto fe380000.crypto: Registers crypto algos [ 10.714166] rk2-crypto fe380000.crypto: Register ecb(aes) as ecb-aes-rk2 [ 10.714231] rk2-crypto fe380000.crypto: Register cbc(aes) as cbc-aes-rk2 [ 10.714252] rk2-crypto fe380000.crypto: Register xts(aes) as xts-aes-rk2 [ 10.714267] rk2-crypto fe380000.crypto: Register md5 as rk2-md5 3 [ 10.714284] rk2-crypto fe380000.crypto: Register sha1 as rk2-sha1 4 [ 10.714302] rk2-crypto fe380000.crypto: Register sha256 as rk2-sha256 5 [ 10.714318] rk2-crypto fe380000.crypto: Register sha384 as rk2-sha384 6 [ 10.714333] rk2-crypto fe380000.crypto: Register sha512 as rk2-sha512 7 [ 10.714535] rk2-crypto fe380000.crypto: Register sm3 as rk2-sm3 8 [ 10.751177] Adding 2006252k swap on /dev/zram0. Priority:5 extents:1 across:2006252k SS [ 10.808239] hantro-vpu fdee0000.video-codec: Adding to iommu group 2 [ 10.810297] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video3 [ 10.810421] zram1: detected capacity change from 0 to 102400 [ 10.820225] tm16xx 7-0024: Failed to count 'tm16xx,digits' property: -22 [ 10.820248] tm16xx 7-0024: Failed to parse device tree: -22 [ 10.820259] tm16xx 7-0024: probe with driver tm16xx failed with error -22 [ 10.846289] rc_core: IR keymap rc-h96-max-v56 not found [ 10.846313] Registered IR keymap rc-empty [ 10.851168] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0 [ 10.851434] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter [ 10.855121] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1 [ 10.926103] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ 10.936262] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... [ 10.954672] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 10.968325] Bluetooth: Core ver 2.22 [ 10.968448] NET: Registered PF_BLUETOOTH protocol family [ 10.968456] Bluetooth: HCI device and connection manager initialized [ 10.968474] Bluetooth: HCI socket layer initialized [ 10.968484] Bluetooth: L2CAP socket layer initialized [ 10.968503] Bluetooth: SCO socket layer initialized [ 11.012098] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 11.012123] rk_gmac-dwmac fe010000.ethernet end0: stmmac_hw_setup: DMA engine initialization failed [ 11.012131] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Hw setup failed [ 11.044607] Bluetooth: HCI UART driver ver 2.3 [ 11.044633] Bluetooth: HCI UART protocol H4 registered [ 11.044639] Bluetooth: HCI UART protocol BCSP registered [ 11.044779] Bluetooth: HCI UART protocol LL registered [ 11.044790] Bluetooth: HCI UART protocol ATH3K registered [ 11.044838] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 11.045063] Bluetooth: HCI UART protocol Intel registered [ 11.045309] Bluetooth: HCI UART protocol Broadcom registered [ 11.045367] Bluetooth: HCI UART protocol QCA registered [ 11.045374] Bluetooth: HCI UART protocol AG6XX registered [ 11.045522] Bluetooth: HCI UART protocol Marvell registered [ 11.095556] systemd[1]: Finished systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd. [ 11.100938] systemd[1]: Started systemd-resolved.service - Network Name Resolution. [ 11.101642] systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups. [ 11.105767] EXT4-fs (zram1): mounted filesystem d6c591d9-9d4c-4557-8ea0-5f3d92af56b4 r/w without journal. Quota mode: none. [ 11.171923] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 11.180756] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 11.181195] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 11.181653] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 11.182018] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 11.182142] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.182577] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 11.182735] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.182793] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.244673] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 11.245782] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 11.247146] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 11.251701] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 11.252756] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 11.290376] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status... [ 11.305084] systemd[1]: Reached target bluetooth.target - Bluetooth Support. [ 11.336641] r8152-cfgselector 3-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 11.375270] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status. [ 11.409769] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ 11.419266] systemd[1]: Starting systemd-journald.service - Journal Service... [ 11.450982] r8152 3-1:1.0 eth0: v1.12.13 [ 11.548954] systemd-journald[421]: Collecting audit messages is disabled. [ 11.554558] r8152 3-1:1.0 enx00e04c1800a5: renamed from eth0 [ 11.704869] systemd[1]: Started systemd-journald.service - Journal Service. [ 11.801857] systemd-journald[421]: Received client request to flush runtime journal. [ 11.811394] systemd-journald[421]: /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating. [ 11.811453] systemd-journald[421]: Rotating system journal. [ 12.560089] systemd-journald[421]: Received client request to relinquish /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6 access. [ 13.316103] Bluetooth: hci0: command 0xfc18 tx timeout [ 13.316164] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 13.316174] Bluetooth: hci0: Failed to set baudrate [ 14.381288] r8152 3-1:1.0 enx00e04c1800a5: carrier on [ 15.332133] Bluetooth: hci0: command 0xfc18 tx timeout [ 15.332199] Bluetooth: hci0: BCM: Reset failed (-110) [ 21.222972] platform spdif-sound: deferred probe pending: asoc-simple-card: parse error [ 21.223026] platform rk809-sound: deferred probe pending: asoc-simple-card: parse error [ 1238.828322] systemd-journald[421]: Received client request to flush runtime journal. [ 1238.872397] systemd-journald[421]: Received client request to relinquish /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6 access. [36038.097713] systemd-journald[421]: Received client request to flush runtime journal. [36038.152376] systemd-journald[421]: Received client request to relinquish /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6 access. Could you please tell me what's wrong with my device? It has no network adapter and no Bluetooth functionality.Thank you!
