1) Language.
Either I expressed myself incorrectly or I was misunderstood, but my communication on this forum will most likely proceed as follows:
My message in Russian -> Translator -> My message in English
And the same in reverse order.
2) A little information about me.
I'm a school student, so I'm unlikely to understand any of the high-tech terms.
3) AI
If it helps, here's the most productive thread of conversation with Deepseek:
https://chat.deepseek.com/share/20dl6vpqy97gpu4et4
4) DTBO and DTS
Thanks to AI, almost every new version of dts had a new name, but they all seemed to compile to dtbo with the same name. I'm thinking of finding one that can produce a gradient, but I haven't succeeded yet, and I haven't tried everything. I don't know what color it should be, but mine was a white-to-black gradient. I'll also attach a Python script for it. I didn't create it separately, but wrote it directly into the SSH console (as far as I understand).
5) Raspberry Pi
I have a primary 32 GB SD card, which I've been using since installing Klipper on my 3D printer. I also have a spare 64 GB SD card, which I installed MainsailOS, KlipperScreen, and added printer.cfg to. Initially, when I tried using ready-made libraries, I used the primary card, and even used it for a few attempts with AI. But then I switched to a second (spare) card, so that if I messed up the firmware or made any irreparable changes, I could reinstall the OS, reset it to its original state (as mentioned at the beginning), and then repeat all the necessary operations from the beginning.
It's probably best to record all your steps somewhere so that after successfully setting up the screen on the spare card, you can repeat the necessary steps on the main card.
Just in case, I'll save the current config.txt and all created dts files on my PC.
6) Display
I'm attaching a photo of my display and another from the product page on AliExpress. I already have it soldered into the Raspberry Pi. During my attempts, I soldered from spi1 to spi0 and back maybe five times. But I'm tired of this and want to stick with the current pinout with spi1, since I have two more accelerometers on spi0, which I desoldered while setting up the display.
7) Display nuance
During the first connection, I slightly damaged the solder mask of the ground plane near the positive contact of the display with a soldering iron and shorted it out with solder. I thought something on the display was broken, so I desoldered and checked some components (the microcircuit, capacitors, and resistor), but they were intact. It was only later that I discovered the real problem.
After solving the problem, I connected the 5-volt power supply, but after a couple of hours, I decided to switch it to 3.3 volts just in case. I can switch it back to 5 volts if necessary.
I hope this short-circuit situation didn't affect the operation in any way.
If this is helpful, I've attached all the DTS versions I currently have; they can be opened in Notepad++. When I find the one that produces the gradient, I'll edit this post or write a new one.
test_display.txt
ili9488-debug.dts
ili9488-fixed.dtbo
ili9488-fixed.dts
ili9488-fixed-gpio.dts
ili9488-full-init.dts
ili9488-priority.dts
ili9488-test.dts
ili9488-test-18bit.dts
ili9488-test-bgr.dts
ili9488-test-reg36.dts
ili9488-test-rotate.dts
ili9488-working.dts
ili9488-xpt2046.dts
ili9488-64bit.dts
ili9488-correct-horizontal.dts
