k8n
  1. I now found a workaround, basically adding the following to the top of /boot/boot.cmd setenv usbstoragequirks "0x2537:0x1066:u,0x2537:0x1068:u" and running mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr (as shown at the bottom of /boot/boot.cmd However this is not sustainable, and it would still be preferable if the inclusion of armbianEnv.txt could be fixed, ESPECIALLY considering that the download page https://www.armbian.com/odroid-n2/ gives the following (useless due to this issue) advise: On modern kernels adding “video=HDMI-A-1:1920x1080M@60D” to boot /boot/armbianEnv.txt (extraargs=) should force HDMI to 1080p instead of the 4K native resolution.
  2. Hi, It seems that the Odroid N2 armbian builds do not support using armbianEnv.txt AT ALL. See this forum entry from 2021: I am facing the same issue with Armbian 26.2.1 Minimal dmesg shows the following: [ 0.000000] Kernel command line: root=UUID=c8906fe5-129c-4388-840c-58c43c541176 rootwait rootfstype=ext4 splash=verbose console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart=001c9d62-01 libata.force=noncq usb-storage.quirks= cgroup_enable=memory with the following in /boot/armbianEnv.txt: verbosity=1 console=both overlay_prefix=meson rootdev=UUID=c8906fe5-129c-4388-840c-58c43c541176 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u I also tried adding extraargs= but nothing ends up in the command line. The old forum entry does mention editing the boot.ini to manually append it to bootargs, however I am not sure where that is located in the image and how to modify it. I tried both booting with petitboot and without, both show the same issue.
