Hi Tparys
Sorry for the last reply, it has been a couple of busy days.
> If they are exactly the same software, it sounds like a hardware issue.
Yes that was my initial thought, and therefore I validated with the HardKernel images on one of broken nodes and since the PWM fan was a normal. It seems to be a software problem instead.
> If the HardKernel images works as expected, perhaps you've updated all 3, but not rebooted the working one yet?
After the second node broke have a turn all devices off each night and the healthy node has worked every day.
> Can you post logs of both working and not working boards?
Node 1 (Healthy): https://paste.armbian.com/ibofokalis
Node 2 (Unhealthy): https://paste.armbian.com/ifihodukoj
I am reinstalled armbian 26.2.1 Noble and here is the PWM not working. I am capable of setting a PWM but it doesn't respond to it.
It was on this node I have tested the HardKernel Image
Node 3 (Unhealthy): https://paste.armbian.com/kemesojuva
I have done some additional debug on this node.
The hwmon2/pwm1_enable is set to 1 for manual mode and pwm1 is zero even if the fan is speeding at full speed.
If I disable the fancontrol service and manually control the pwm1, it is possible to set the pwm to a different speed and the fan will respond but after a split sensor would the value of pwm1 be reset to 0 instead of the assigned value.
