gabmert
  1. Thank you @Revellion I just did ``` sudo apt-mark unhold armbian-firmware sudo rm -rf /lib/firmware/qcom/sm8550/ayn/ sudo apt update && sudo apt upgrade ``` and it worked fine
  2. Yesterday I flashed a new sd card (more space) for my rockpi-4b but after switching to the stable channel `armbian-config --cmd STABLE` the update keeps failing: $ sudo apt update Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org trixie-security InRelease Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB] Hit:4 http://deb.debian.org/debian trixie-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Get:6 http://armbian.lv.auroradev.org/apt trixie InRelease [39.4 kB] Get:7 http://armbian.lv.auroradev.org/apt trixie/trixie-utils arm64 Packages [21.4 kB] Get:8 http://armbian.lv.auroradev.org/apt trixie/trixie-desktop arm64 Packages [68 33 B] Fetched 115 kB in 2s (69.5 kB/s) 1 package can be upgraded. Run 'apt list --upgradable' to see it. $ sudo dpkg --configure -a $ sudo apt --fix-broken install Summary: Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 1 $ sudo apt upgrade Upgrading: armbian-firmware Summary: Upgrading: 1, Installing: 0, Removing: 0, Not Upgrading: 0 Download size: 0 B / 141 MB Space needed: 99.3 MB / 59.9 GB available Continue? [Y/n] y (Reading database ... 26869 files and directories currently installed.) Preparing to unpack .../armbian-firmware_26.2.1_all.deb ... Unpacking armbian-firmware (26.2.1) over (26.2.0-trunk.703) ... dpkg: error processing archive /var/cache/apt/archives/armbian-firmware_26.2.1_all.deb (--unpack): unable to open '/lib/firmware/qcom/sm8550/ayn/odin2mini/a740_zap.mbn.dpkg-new': No such file or directory Errors were encountered while processing: /var/cache/apt/archives/armbian-firmware_26.2.1_all.deb Error: Sub-process /usr/bin/dpkg returned an error code (1) For now I am doing `sudo apt-mark hold armbian-firmware`. Switching to rolling, updating there works (26.2.0-trunk.722). But the issue persists when switching back to stable. As there have been recent changes https://github.com/armbian/firmware/pull/117 and https://github.com/armbian/firmware/pull/119 and I couldn't find other error reports on the forum, I guess this is an issue of the image packaging. I also plugged back in the old sd card and that system updated without issues.
