chairman
  1. Yeah, I’ve looked into the patch file. It doesn’t work with latest u-boot at all. It looks for dtb file, whereas latest u-boot includes mostly dtbi files. I think I’ll have to look into slightly newer than 2020.07 u-boot. I’m guessing it would be easier to port that patch.
  2. This one. The patch from “/build-u-boot/“ directory. That contains mentioned readme.txt. Tried to build u-boot with that patch and newer binaries of u-boot. It failed though. I’m going to try with older version maybe later. As long as Armbian boots from SD card, I’m fine. Justwas curious about it, when it failed to flash into emmc.
  3. Hello, I’ve got the same issue with s905x. After going through this topic, I’ve compiled u-boot with newer sources, and it seems not resolving this at all. There was patch mentioned. Do I use it to compile u-boot (instead of the one provided in the u-boot repo) ?
