Getting the 2ed NIC to work
deleted my patch file in userpatches cp output/patch/kernel-rockchip64-current.patch patch/kernel/archive/rockchip64-6.18/rk3588-1300-arm64-dts-rock5t-eth-reset.patch definitely saw the patch get applied during the build ./compile.sh BOARD=rock-5t BRANCH=current RELEASE=trixie kernel-dtb # cat output/logs/log-kernel-dtb-cd035955-4094-4e6f-b86d-89fe0287a2ce.log.ans |grep eth-reset patch/kernel/archive/rockchip64-6.18/rk3588-1300-arm64-dts-rock5t-eth-reset.patch -> 223/230: rk3588-1300-arm64-dts-rock5t-eth-reset(:1) (+20/-0)[1M] {rk3588-rock-5t.dts} โ rk3588-1300-arm64-dts-rock5t-eth-reset copied the rk3588-rock-5t.dtb over to my Rock5t's /boot/dtb/rockchip/ folder, rebooted it and ..... it didn't work # dmesg |grep -e 'r8169\|RTL8125B' [ 2.286822] r8169 0003:31:00.0: enabling device (0000 -> 0003) [ 2.314767] r8169 0003:31:00.0 eth0: RTL8125B, 00:48:54:20:XX:XX, XID 641, IRQ 123 [ 2.314803] r8169 0003:31:00.0 eth0: jumbo features [frames: 16362 bytes, tx checksumming: ko] [ 2.347904] r8169 0003:31:00.0 enP3p49s0: renamed from eth0 [ 5.367059] Realtek Internal NBASE-T PHY r8169-3-3100:00: attached PHY driver (mii_bus:phy_addr=r8169-3-3100:00, irq=MAC) [ 5.560727] r8169 0003:31:00.0 enP3p49s0: Link is Down [ 7.870963] r8169 0003:31:00.0 enP3p49s0: Link is Up - 1Gbps/Full - flow control rx/tx So either I'm doing something wrong, 1st time building something on this build framework, or this patch just doesn't work on my Rock5t. Ethernet should be the same on the consumer and industrial boards right?
ok so here's what I did: git clone https://github.com/armbian/build cd build ./compile.sh BOARD=rock-5t BRANCH=current kernel-patch edited build/cache/sources/linux-kernel-worktree/6.18__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-rock-5t.dts ended up with: /home/marv/rock5t/build/output/patch/kernel-rockchip64-current.patch cp output/patch/kernel-rockchip64-current.patch userpatches/kernel/rockchip64-current/ ./compile.sh BOARD=rock-5t BRANCH=current RELEASE=trixie kernel-dtb copied the new cache/sources/linux-kernel-worktree/6.18__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-rock-5t.dtb over to my Rock5t /boot/dtb/rockchip/ folder, rebooted it, nothing changed, no 2ed nic. https://paste.armbian.com/muwoxuqoza kernel-rockchip64-current.patch
- Getting the 2ed NIC to work
https://github.com/siderolabs/sbc-rockchip/issues/103 I'm trying to apply this patch, but I think i'm doing something wrong it doesn't seem to be working. I'm getting the same behavior. [ 1.369895] rockchip-dw-pcie a41000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G [ 2.224201] r8169 0003:31:00.0 eth0: jumbo features [frames: 16362 bytes, tx checksumming: ko] [ 1.504906] rockchip-dw-pcie a40800000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G I tried putting the patch in: build/userpatches/kernel/rockchip64-current/ Then I tried it in: build/userpatches/kernel/archive/rockchip64-6.18/ because of this output: [๐ฑ] User patches directory for kernel [ /home/marv/rock5t/build/userpatches/kernel/archive/rockchip64-6.18 ] Doesn't seem to get applied, when I transfer the 'new' rk3588-rock-5t.dtb file to my device, the 2ed interface doesn't turn on. What am i doing wrong?
marv
