Aco Art
  1. @Rodrigo Campos In my case the U-Boot side is not just a generic version choice. That baseline carries the board-specific path I tested: the zero2w-based defconfig, mmc0 broken-CD handling, H616 EMAC1/RMII support, I2C3 enablement, the LAN preinit step, and the extra EMAC-related clock/register writes. Since the kernel LAN attach depends on the board already being prepared by U-Boot, I preferred to keep the bootloader side conservative. So the short answer is: it is pinned because it is the validated baseline, not because I know of a hard conflict with every newer release.
  2. I published my Vontar H618 bring-up patch set here: https://github.com/aco-art/vontar-h618-armbian-patche It includes the Armbian userpatches, U-Boot/kernel changes, and diagnostics tools I used for this box. Tested on my 4 GiB DDR3 Vontar H618 unit and shared in case it helps with similar H618/H616-class TV boxes. On my tested unit, Wi-Fi, Bluetooth, LAN, HDMI output, and the basic GPU/display path are working with this baseline.
