How to install ARMBIAN on mxq pro 4K 5g with All Winner H3 processor
_ _ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| \__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, | |__/ v26.11 rolling for Tritium H3 running Armbian Linux 6.18.55-current-sunxi Packages: Debian stable (trixie) Updates: Kernel upgrade enabled and 6 packages available for upgrade Support: for advanced users (rolling release) IPv4: (LAN) 192.168.1.13 (WAN) XXX.XXX.X.XXX IPv6: (WAN) ---------------------------------------------- Performance: Load: 27% Uptime: 4h 10m Local users: 2 Memory usage: 61% of 991M Zram usage: 3% of 495M CPU temp: 40°C Usage of /: 25% of 15G Tips: Meet our new Armbian Imager 2.0 https://tinyurl.com/a7b2b4su Commands: Configuration: armbian-config Upgrade : armbian-upgrade Monitoring : htop Web console: https://mxqpro4k:9090/ or https://192.168.1.13:9090/ Last login: Wed Oct 14 17:44:48 2026 from ::ffff:192.168.1.20 diego@mxqpro4k:~$ finally a change the dtb because hdmi was buggy (white noise, random images). for the orangepi pc again (and works just fine). (i modd the cooler inside (removed) an just put a bigger one, touching ram modules also) still don't fix the driver for wifi, cpu usage is now installing klipper (it's feel slow... i have to do more test. this chips has to be very fast for instalation, so i have to check because is running over sd, typicaly i install over internal mmc, stil can't do it that in this box)
thanks, it works also. (with direct lan working, but the hdmi output stop after a while...i finish the instalation on ssh) just in case: i use this boxes to run linux but only for klipper, i find in local marketplace for less than 10 usd... and works flawless for Klipper.... (compared to the price of raspberry...is a good deal) so the real question is if this kernel really have problem with this chip (like you say "this box is weak...") but in documentation say direct this: use 6.x.x is problematic because dont have support and reported less performance... (i dont know for sure, but i install armbian in very different boxes and works flawless in all different chips, s905, rockchip, and now in allwinner h3... ) but need more time to speak about the performance of this specifically box.
hello there: with the exact same box, i have this problems (solved): first: the box is called (outside MXQpro 4k), inside is the board in shape of L, like in the pictures. all the images in this post DONT work to boot direct on linux., so with help of claude, i found the correct img to boot: Orange Pi Lite + DTB de Orange Pi PC the process is, burn with balena etcher the image "orange pi lite" from the official repo, (Armbian_community_26.11.0-trunk.83_Orangepilite_trixie_current_6.18.55_minimal.img) link: https://dl.armbian.com/orangepilite/Trixie_current_minimal with hdmi and rj45 connected. (no need to press the hide button) just burn the image into an sd, plug in the box, plug the power and that's it. that gonna boot into linux, but with no lan or network, so you need to edit the dtb to use orange pi pc: steps: nano edit /boot/armbianEnv.txt add this line: fdtfile=sun8i-h3-orangepi-pc.dtb press ctrl+X , save : YES, overwrite. reboot. now you have it with network. about wifi, the box have XR819 chip. so supposed to be "easy" to install. but dont have luck yet. hope this info work for somebody pd: sorry about my english, is not my first language.
Diego Moisés Llano Moraga
