N8cko
  1. I have a similar boot problem with one of my devices. I have 2 "Mortal T1" from aliexpress, technically 2G/8G each, bought almost at the same time a couple of years back. I managed to use Nick's 2025 image to boot via SD card into armbian, if anyone wants to try, I heavily recommend using an USB->ETH adapter, otherwise you are limited to UART connections for testing. My devices need the AIC modules for the wireless card, so it needs some changes there, but otherwise, I'm happy with it, although I had to disable firmware updates in armbian-update because it changed the DTB and had to reinstall from scratch. Now the issue. My second device (still works in Android ok) shows 1.5G in the UART Android Uboot startup log, but 2G in meminfo or free or other commands. When trying to boot Armbian (or any other distro mentioned here) the Uboot detects 2G but says (effective 0 bytes) an just hangs there, not even starts linux. U-Boot SPL 2025.01-armbian-2025.01-S6d41-P65b3-H8869-V98f7-Bb703-R448a-dirty (Feb 04 2026 - 12:15:34 +0000) DRAM:testing 32-bit width, rank = 2 DRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 10 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 15 rows DRAM:restoring cfg DRAM:end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.14(debug):armbian NOTICE: BL31: Built : 12:14:48, Feb 4 2026 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b1d00, model: hechuang,x96-q LPDDR3 v1.3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.01-armbian-2025.01-S6d41-P65b3-H8869-V98f7-Bb703-R448a-dirty (Feb 04 2026 - 12:15:34 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: hechuang,x96-q LPDDR3 v1.3 DRAM: 2 GiB (effective 0 Bytes) Same card in both devices, one works, the othe does not. Any ideas or suggestions ? Best regards
