- Nanopi M5 UFS boot issues on 26.8.1
Well, after many hours testing I am still stuck. 1) flashing Armbian to an SD-card, whether through armbian-imager or balena-etcher obviously poses no problem 2) when booting Amrbian from SD in an Friendlyelec NanoPi R3S, armbian-install allows for easy flashing of the eMMC memory and thereafter the R3S boots from eMMC. Perfect ! 3) a NanoPi M5 boots from SD-card without any problem and then recogises the UFS memory (/dev/sda 239 Gb). Unfortunately amrbian-install does not recogise this, or at least does not offer the option to transfer the image onto UFS 4) installing a Friendlyelec Ubuntu image is fairly simple : flash a so-called ¨eFlasher¨ version of the Ubuntu image from their site to SD-card, boot from SD and the NanoPi M5 will auto-run Eflasher which puts the image on UFS. Remove the SD-card and then the NanoPi M5 boots from UFS. As simple as that. Thing is, I haven´t got a clue what the Friendlyelec eFlasher does precisely. I did observe that the partition table thus created is very different from Armbian : it creates /dev/sda1 - sda9, sdb, sdc, sdd (and m..... I also tried the Friendlyelec / vicharack (Github) Linux ¨Upgrade_Tool¨. Radxa for example claim that you should also be able to flash Armbian to RK35xx using armbian-imager via USB to UFS. Friendlyelec also claim that installation via USB should be possible, but in their WiKi instructions for Linux to do so are missing completely .... Windows only ! (I banned Windows from my home 20 years ago ...) 4) when booting the NanoPi M5 in MASKROM mode and connecting it to my Linux NUC, it is recognised : - via lsusb - via sudo ./upgrade_tool ld without any problem, 5) as in the past I already installed a Friendlyelec Ubuntu image on the UFS, I erased the UFS to avoid any conflicts : sudo ./upgrade_tool ef 6) my understanding is that if the SPI NOR is empty, the boot priority is 1) SSD-card 2) UFS. Although Frienlyelec mention this is optional, I erased the SPI NOR anyway by : sudo ./upgrade_tool DB MiniLoaderAll.bin sudo ./upgrade_tool SSD # Select 5, SPINOR sudo dd if=/dev/zero of=zero.img bs=1M count=16 sudo upgrade_tool WL 0 zero.img to avoid any ambiguity in terms of booting : in absence of an SD-card, booting should be from UFS .... (note : with Friendlyelec the loader binary is unfortunately always called MiniLoaderAll.bin, irrespective of the architecture, e.g. RK 3399, RK 3576, RK 3588, etc. So you have to make sure to download the correct one from https://downloads.friendlyelec.com/tools/ ) 7) Flashing Armbian to UFS as per vicharack Github instructions - I re-flashed the loader binary : sudo ./upgrade_tool db MiniLoaderAll.bin - I flashed Armbian : sudo ./upgrade_tool wl 0 Armbian_26.8.1_Nanopi-m5-resolute_current_6.1.115_gnome_desktop.img which seemed to all go OK, except ........ the NanoPi M5 still won´t boot from UFS (that is : red power LED goes on, and then .... nothing) 8) I came across various instructions on the web manually copying files using ¨dd¨ commands, but as I am not sure I understand what the problem is, I stayed away from these. So I ended up back to square one and somewhat frustrated : re-installing the Friendlyelec Ubuntu Gnome image on UFS, and Armbian on SD-card .... Now, where does this leave me ? In absence of any feed-back from the developers it seems that either I : 1) am stuck with the manufacturer´s image (and thus : exit Armbian) or : 2) have to look for an alternative board with eMMC, instead of UFS Neither of these options are very attractive, as I had thought to have found the perfect combination for my needs in Friendlyelec + RK3576/UFS + Armbian .....
Anybody ??? One thing is sure : what @Superkali wrote is not entirely correct : because : - UFS does not appear as an option - the physical switch only has 2 positions : 1) spi 2) ufs/sd so if you try to boot from an SD card, the switch must already be on ufs/sd otherwise the system simply won´t boot, i.e. you cannot ¨switch the physical switch to UFS¨ thereafter ........ (at least, that is how it is with my NanoPi M5 and how it shows in all Friendlyelec documentation)
After diving into this some more - including looking at Friendlyelec´s eFlasher - I fear I must conclude that this is definitely over my head. That´s sad, because after earlier poor experience with another SBC (poor housing / cooling problems + AMLogic failing to provide the necessary hooks for Linux upgrades, etc) I choose Friendlyelec NanoPi M5, which seemed the perfect choice : low energy RK 3576, powerful enough, still reasonably affordable, good metal housing (no heating whatsoever), etc, plus I did not want to be depending on manufacturer Linux images, so Armbian´s Platinum support seemed like a major advantage ... ! But I never realised that there is such a major difference between eMMC and UFS ...... The Armbian blog of last 27 May suggested that full UFS boot was (almost) there and even showed a picture of armbian-config (or armbian-install ?) with the option ¨Boot from UFS - system on UFS (sda + idblock on sdb)¨ for ¨the next release¨. I don´t recall what the then current release was, and I can wait of course, but does somebody know what ¨the next release¨ means ? Given that the current release is 26.8.1 does his mean 26.8.2, or 26.9, or 27.0 ? I would be grateful if somebody could shed some light on the timeline / estimate ?
Dear @eselarm, Thank you for thinking along. First, I would like to mention that I date from before MS-DOS 1.0, therefore my somewhat rusty brain has an older model CPU (no cores, or if you like, 1 core A-1 running at a clock frequency of max 1200 Hz), and that all this tends to go a little bit over my head, even though over the many years I did encounter quite a few Unix, Linux and other systems .... 1. my reference to SATA was merely related to the mention of SATA in the Armbian blog post of last May 27; armbian-config and armbian-install only refer to SD, eMMC, NVMe, SATA and USB, but not to UFS or SCSI at all (?), 2. the script you refer to is from someone who had a problem installing on a btrfs file system, but I understand that btrfs is not supported (at least not for the boot partition ...). This may be a separate problem ? In any case, I do not have such advanced needs, am happy to stick with ext4 and would like to keep btrfs issues separate, 3. I now realize that in my original post I should have provided more information : a) UFS not virgin : I previously installed a standard Ubuntu Gnome image from Friendlyelec (some time ago, do not recall how but it must have been one of the procedures mentioned in their Wiki}. This works : using the Friendlyelec image, system boots from UFS and appears to work fine (and still does; so far I can run Armbian from SD only). I do not know whether their procedure (their ¨USB-images¨, integrated with their eFlasher, etc) may have any effect on partitions etc ? b) what is sure from a) above is that UFS is there and works. Also if I go to : b1) Apps --> System --> Disks, I get : 256 Gb Disk Btwin <some-long-number> SD card reader SDABC 17 Mb Block Device /dev/mbdblock0 (I guess this must be the on-board SPI ?) b2) if in a terminal I go to /dev/disk I get output similar to yours. b3) in armbian-config or armbian-install I get : sda /dev/sda 239 Gb <some-long-number> sdb /dev/sdb 4.0 Mb <some-long-number> sdc /dev/sdc 4.0 Mb <some-long-number> sdd /dev/sdd 8.0 Mb <some-long-number> Bottom line is that I am still a bit lost ?
Same problem here ... NanoPi M5, Armbian 26.8.1 Gnome Installed Armbian on SD-card; NanPi boots fine (with hardware switch on UFS/SD) Opened a terminal and ran armbian-install : 2 options : - Install Armbian to a disk (SD/eMMc/NVMe/Sata/USB) - Flash / update the bootloader (u-boot) only First option gives a choice of sda, sdb, sdc, sdd sda results in above error message : “No bootable install method is available for /dev/sda on this system (no EFI firmware, no GRUB, and no board u-boot support).” (also, there is no mention of UFS anywhere, but from the Blog/Newsletter I understood that this may be related to Rockwell, who still refers to it as SATA ?)
