klmasc5
  1. Hello, I guess this is the right forum for my topic: I have got a T95zplus H618 TVBox with AW869A. People having this box may know, there exist an armbian image by LYU4662 at github: https://github.com/LYU4662/t95zplus-h618-build However, after installing it, there is no wifi. I did some analysis with claude, it concluded that there are only some small changes necessary in the dtb and the wifi is working. These are claude's words: " T95ZPLUS (AW869A / AIC8800) with LYU’s image: fix for mmc1: error -110 whilst initialising SDIO card Box: T95ZPLUS, H618, AW869A (SDIO 5449:0145, detected as AIC8801). Image: LYU4662’s Armbian build, 6.7.12-edge-sunxi64, with his aic8800 DKMS driver. Symptom: aic modules load, but modprobe aic8800_fdrv gives “No such device”, /sys/bus/sdio/devices/ is empty, dmesg shows the CIS tuple being read and then mmc1: error -110 whilst initialising SDIO card / Failed to initialize a non-removable card. I compared LYU’s DTB with the live Android DT. Pins, supplies and power sequence already match (SMHC1 on PG0–PG5, vmmc = DLDO1 3.3 V, vqmmc = ALDO1 1.8 V, 32 kHz clock out on PG10 via &rtc 1, reset PG18 active low). So it’s not a pinning problem. What fixed it, in the mmc@4021000 node: max-frequency: 50 MHz -> 25 MHz removed: cap-sd-highspeed, cap-mmc-highspeed, mmc-ddr-3_3v, mmc-ddr-1_8v wifi_pwrseq: added post-power-on-delay-ms = <200> After that both SDIO functions enumerate, firmware loads, wlan0 shows up, nmcli connects, and it comes back after a reboot without the Ethernet cable. I changed these together and didn’t test them individually, so I don’t know which one is essential. Only tested on this image/kernel and one box; Bluetooth untested. Newer revisions with other chips (e.g. YC8800D) are a different case. If you use LYU’s image, replacing /boot/dtb/allwinner/T95zPlus-H618.dtb wt95zplus-aw869a-wifi-fix.zipith the patched one and rebooting should be all that’s needed. Happy to share the DTB/DTS if anyone wants it." I tested it at my t95zplus, wifi is working. I attach the dtb and dts claude found out. Simply replace the DTB in /boot/dtb/allwiner/T95zPlus-H618.dtb by the dtb of the zip file: Flash the image at an SD card unzip the attached file in ~/Downloads find your SD card sdX1 with lsblk (typically sdX1 is sda1 or sdb1) then: sudo mkdir -p /mnt/sd sudo mount /dev/sdX1 /mnt/sd ls /mnt/sd/boot/dtb/allwinner/ | grep T95 sudo cp /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb.stock sudo cp ~/Downloads/T95zPlus-H618.dtb /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb sha256sum ~/Downloads//T95zPlus-H618.dtb /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb sync sudo umount /mnt/sd Start your t95zplus and do the armbian installation. Then you can initilize wifi on the box: # 1. Hold kernel packages sudo apt-mark hold linux-dtb-edge-sunxi64 linux-image-edge-sunxi64 linux-u-boot-t95zplus-h618-edge apt-mark showhold # 2. Optional: back up /boot sudo cp -a /boot ~/boot-backup-$(date +%F) # 3. Check WiFi state (rfkill needs sudo) sudo rfkill list sudo rfkill unblock wifi # 4. Enable WiFi and scan sudo nmcli radio wifi on sudo nmcli device wifi rescan sleep 5 nmcli device wifi list # 5. Connect WiFi sudo nmcli device wifi connect 'YOUR_WIFI_NAME' password 'YOUR_PASSWORD' # 6. Verify ip -br addr ping -c3 -I wlan0 1.1.1.1 # 7. Test auto-connect (unplug the LAN cable first) nmcli connection show sudo reboot t95zplus-aw869a-wifi-fix.zip
  2. Hello, I guess this is the right forum for my topic: I have got a T95zplus H618 TVBox with AW869A. People having this box may know, there exist an armbian image by LYU4662 at github: https://github.com/LYU4662/t95zplus-h618-build However, after installing it, there is no wifi. I did some analysis with claude, it concluded that there are only some small changes necessary in the dtb and the wifi is working. These are claude's words: " T95ZPLUS (AW869A / AIC8800) with LYU’s image: fix for mmc1: error -110 whilst initialising SDIO card Box: T95ZPLUS, H618, AW869A (SDIO 5449:0145, detected as AIC8801). Image: LYU4662’s Armbian build, 6.7.12-edge-sunxi64, with his aic8800 DKMS driver. Symptom: aic modules load, but modprobe aic8800_fdrv gives “No such device”, /sys/bus/sdio/devices/ is empty, dmesg shows the CIS tuple being read and then mmc1: error -110 whilst initialising SDIO card / Failed to initialize a non-removable card. I compared LYU’s DTB with the live Android DT. Pins, supplies and power sequence already match (SMHC1 on PG0–PG5, vmmc = DLDO1 3.3 V, vqmmc = ALDO1 1.8 V, 32 kHz clock out on PG10 via &rtc 1, reset PG18 active low). So it’s not a pinning problem. What fixed it, in the mmc@4021000 node: max-frequency: 50 MHz -> 25 MHz removed: cap-sd-highspeed, cap-mmc-highspeed, mmc-ddr-3_3v, mmc-ddr-1_8v wifi_pwrseq: added post-power-on-delay-ms = <200> After that both SDIO functions enumerate, firmware loads, wlan0 shows up, nmcli connects, and it comes back after a reboot without the Ethernet cable. I changed these together and didn’t test them individually, so I don’t know which one is essential. Only tested on this image/kernel and one box; Bluetooth untested. Newer revisions with other chips (e.g. YC8800D) are a different case. If you use LYU’s image, replacing /boot/dtb/allwinner/T95zPlus-H618.dtb wt95zplus-aw869a-wifi-fix.zipith the patched one and rebooting should be all that’s needed. Happy to share the DTB/DTS if anyone wants it." I tested it at my t95zplus, wifi is working. I attach the dtb and dts claude found out. Simply replace the DTB in /boot/dtb/allwiner/T95zPlus-H618.dtb by the dtb of the zip file. Here is an instruction according to Claude: I tested it at my t95zplus, wifi is working. I attach the dtb and dts claude found out. Simply replace the DTB in /boot/dtb/allwiner/T95zPlus-H618.dtb by the dtb of the zip file: Flash the image at an SD card unzip the attached file in ~/Downloads find your SD card sdX1 with lsblk (typically sdX1 is sda1 or sdb1) then: sudo mkdir -p /mnt/sd sudo mount /dev/sdX1 /mnt/sd ls /mnt/sd/boot/dtb/allwinner/ | grep T95 sudo cp /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb.stock sudo cp ~/Downloads/T95zPlus-H618.dtb /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb sha256sum ~/Downloads//T95zPlus-H618.dtb /mnt/sd/boot/dtb/allwinner/T95zPlus-H618.dtb sync sudo umount /mnt/sd Start your t95zplus and do the armbian installation. Then you can initilize wifi on the box: # 1. Hold kernel packages sudo apt-mark hold linux-dtb-edge-sunxi64 linux-image-edge-sunxi64 linux-u-boot-t95zplus-h618-edge apt-mark showhold # 2. Optional: back up /boot sudo cp -a /boot ~/boot-backup-$(date +%F) # 3. Check WiFi state (rfkill needs sudo) sudo rfkill list sudo rfkill unblock wifi # 4. Enable WiFi and scan sudo nmcli radio wifi on sudo nmcli device wifi rescan sleep 5 nmcli device wifi list # 5. Connect WiFi sudo nmcli device wifi connect 'YOUR_WIFI_NAME' password 'YOUR_PASSWORD' # 6. Verify ip -br addr ping -c3 -I wlan0 1.1.1.1 # 7. Test auto-connect (unplug the LAN cable first) nmcli connection show sudo reboot
