Can not boot from SD card,something wrong from my SK-TDA4VM
I got something wrong while using armbian 26.11 minimal img。Here‘s the log output from the serial: U-Boot SPL 2026.01-00340-g2549829cc194 (Oct 17 2026 - 12:22:21 +0000) SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)') i2c_probe: pads on bus probably not configured (status=0x10) EEPROM not available at 0x50, trying to read at 0x51 i2c_probe: pads on bus probably not configured (status=0x10) Reading on-board EEPROM at 0x51 failed -121 __omap24_i2c_xfer_msg: pads on bus probably not configured (status=0x10) omap_i2c_xfer: errored out at msg 0: -121 read error from device: 41c86358 register: ?x! __omap24_i2c_xfer_msg: pads on bus probably not configured (status=0x10) omap_i2c_xfer: errored out at msg 0: -121 write error to device: 41c86358 register: ?x! esm_pmic esm: clearing ESM irqs failed: -5 ESM PMIC init failed: -5 Trying to boot from MMC2 __omap24_i2c_xfer_msg: pads on bus probably not configured (status=0x10) omap_i2c_xfer: errored out at msg 0: -121 read error from device: 41c86358 register: ?x! Loading Environment from nowhere... OK lpm will not be functional Cannot find valid LPM address range.. ti_sci system-controller@44083000: Message not acknowledged TIFS lpm save addr fail Starting ATF on ARM64 core... NOTICE: BL31: v2.14.0(release):armbian NOTICE: BL31: Built : 12:19:29, Oct 17 2026 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 991 INFO: SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)') INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 I/TC: I/TC: OP-TEE version: f2a7ad063 (gcc version 14.2.0 (Debian 14.2.0-19)) #1 Sat Oct 17 12:20:53 UTC 2026 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: GIC redistributor base address not provided I/TC: Assuming default GIC group status and modifier I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)') I/TC: Activated SA2UL device I/TC: Fixing background firewall owner I/TC: Enabled firewalls for SA2UL TRNG device I/TC: EIP76D TRNG initialized I/TC: SA2UL Drivers initialized I/TC: HUK Initialized I/TC: Disabling output console INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x80080000 INFO: SPSR = 0x3c9 U-Boot SPL 2026.01_armbian-2026.01-S2549-P0510-H32aa-V024c-Bb936-R448a (Oct 17 2026 - 12:23:13 +0000) Unable to shutdown MCU R5 core 1, -22 SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)') DM ABI: 3.0 (firmware ver 0x000b 'PSDK.11.02.00.07--v11.02.07' patch_ver: 7) EEPROM not available at 0x50, trying to read at 0x51 ti_i2c_eeprom_am6_parse_record: Ignoring record id 17 Trying to boot from MMC2 U-Boot 2026.01_armbian-2026.01-S2549-P0510-H32aa-V024c-Bb936-R448a (Oct 17 2026 - 12:23:13 +0000) SoC: J721E SR1.1 GP Model: Texas Instruments J721e EVM Board: J721EX-EAIK rev E2 DRAM: 2 GiB (total 4 GiB) __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register optee optee: OP-TEE: revision 4.9 (f2a7ad0638aeff52) Core: 153 devices, 39 uclasses, devicetree: separate Flash: 0 Bytes MMC: mmc@4f80000: 0, mmc@4fb0000: 1 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 am65_cpsw_nuss_port ethernet@46000000port@1: RGMII mode without internal TX delay unsupported; please fix your Device Tree eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 118 __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 75 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 75 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:1 Can't set block device WARNING: Initramfs not found, continuing without initramfs __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 ** Bad device specification mmc 1 ** Couldn't find partition mmc 1:2 Can't set block device libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning bootdev 'mmc@4fb0000.bootdev': __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 __omap24_i2c_xfer_msg: error waiting for ACK (status=0x116) omap_i2c_xfer: errored out at msg 0: -121 pca953x gpio@22: Error reading output register Card did not respond to voltage select! : -110 mmc_init: -95, time 76 Scanning bootdev 'mmc@4f80000.bootdev': Card did not respond to voltage select! : -110 mmc_init: -95, time 37 Card did not respond to voltage select! : -110 mmc_init: -95, time 36 Card did not respond to voltage select! : -110 mmc_init: -95, time 36 cdns-usb3-host usb@6400000: DRD version v1 (ID: 0004024e, rev: 00000200) Starting the controller USB XHCI 1.00 Bus usb@6400000: 2 USB Device(s) found Scanning bootdev 'port@1.bootdev': Scanning bootdev 'port@1.bootdev': k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 3 ethernet@46000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT ! am65_cpsw_nuss_port ethernet@46000000port@1: phy_startup failed am65_cpsw_nuss_port ethernet@46000000port@1: am65_cpsw_start end error BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 Retry time exceeded; starting again No more bootdevs --- ----------- ------ -------- ---- ------------------------ ---------------- (0 bootflows, 0 valid) => What should I do?
zarya
