Need help with custom DTS file
You were correct - putting the dts file in that magic folder seems to have fixed it. I'm not sure where that would be documented, I wasn't able to find much about adding DTS files and what not. I'm also super new at this level of Linux, though I've been using it for 15 years as a developer.
- Need help with custom DTS file
Ok, that helped some. It's at least picking up the patches now, but it's throwing an error trying to apply them. The patch file was generated immediately before the run using the compile.sh kernel-patch command, and copied to userpatches/kernel/archive/rockchip64-6.18 from the output/patch directory. I'm not entirely sure what the error is, or why a generated patch file would have the problem, but here's the error:
I'm not sure which one is going to be the most useful, so here's everything in the outut/log folder summary-docker-5be2103c-d2b7-414e-ba03-19e87beec54b.md log-docker-5be2103c-d2b7-414e-ba03-19e87beec54b.log.ans summary-build-5be2103c-d2b7-414e-ba03-19e87beec54b.md log-build-5be2103c-d2b7-414e-ba03-19e87beec54b.log log-build-5be2103c-d2b7-414e-ba03-19e87beec54b.log.ans
I'm trying to use Armbian to flash my Lincstation E1 (great hardware, horrible software). I am trying to add a custom DTS file for the board (it's available in a few linux-related repos), but I can't get it to show up in the u-boot folder of the output image. I used kernel-patch and u-boot-patch to generate the patches, copied them from the output/patch folder to userpatches. I've attached the patch files, just in case that helps someone. I'm really confused why the patches aren't getting picked up and new .dtb file isn't in the final image. config-lincstation.conf add-lincstation-dtb.patch u-boot-rockchip64-current.patch
David Harris
