Hello, I am investigating a Bluetooth SCO audio issue on the Orange Pi Zero 2W running Armbian. Environment: Chipset: UNISOC UWE5622 Firmware: MARLIN3_19B_W21.05.3 Kernel: 6.18.63-current-sunxi64 BlueZ: 5.82 Driver: sprdbt_tty Test device: Redmi Buds 6 Pro A2DP playback works, and HFP/eSCO connections are successfully established using CVSD. However, during a 20-second audio test, 5,334 SCO TX packets were submitted, while no SCO RX packets were observed at either the SDIO or HCI level. Testing g_sys_sco_transmit_mode with both values (0 and 1) did not resolve the issue. Could you please clarify: Does the current UWE5622 Linux driver support bidirectional SCO audio? Is there any known limitation in the SCO receive path? Has SCO audio been validated with an earlier kernel or driver version? Is there a known working firmware and driver combination? I can provide btmon traces, driver instrumentation and reproducible test results to assist the investigation. Thank you for your support. Best regards, Oualid Alami
