حمزة البقوم
  1. Hello everyone, I'm looking for the original stock firmware, a complete bootloader dump, or a working device with an identical motherboard to help recover my bricked Android TV Box. The device was sold as a Xiaomi TV Box S 3rd Gen, but it is actually a clone based on the Allwinner H618 chipset. Device SpecificationsSoC: Allwinner H618 PCB Revision: S3_V1.2 Board Identifier: FX2544 RAM: 2GB DDR3, 600MHz Storage: 32GB eMMC PMIC: AXP1530 Wi-Fi: Realtek RTL8822BS Original OS: Android 12 Platform: apollo_p7 Secure Boot: Enabled Device ROTPK ValueThe following ROTPK value was recorded from the device's original boot logs while the device was still working: 80 8E 47 E4 04 19 EA 34 F0 C9 E9 9B 92 33 9A A4 A2 A6 3B A6 8A 30 CD EE 4F 9F BB 70 91 0F CE 2CFull ROTPK (256-bit hexadecimal): 808E47E40419EA34F0C9E99B92339AA4A2A63BA68A30CDEE4F9FBB70910FCE2CCurrent Device ConditionThe device no longer boots, and the power LED does not turn on. However, it is still detected in Allwinner FEL mode: USB VID_1F3A / PID_EFE8 I have tried several firmware images using PhoenixSuit V1.19: DQ06 H618: Flashing fails at approximately 45%, during the Secure Boot1 stage. SlimBOX P7 H618: Same failure at approximately 45%. Lemon TV Mini H618: Stuck at 0%, after FES1 DRAM initialization transfer. iATV Q10 H618: Flashing completes successfully at 100%, including TOC0 and TOC1, but the device still does not boot. The Q10 image contains a valid-looking Secure Boot structure and matching basic DDR3 parameters, but its signing key has not yet been confirmed to match the device's original ROTPK. What I NeedI'm specifically looking for someone who has: An identical motherboard marked S3_V1.2 / FX2544. A working device from the same hardware production batch. Original manufacturer firmware signed for the same Secure Boot key. A backup of the original TOC0, TOC1, Boot0, or eMMC boot regions. A verified method to restore this particular motherboard through Allwinner FEL mode. If you own a working device with this motherboard, could you please share a clear motherboard photo and, if possible, a backup of its original bootloader or firmware? ROTPK compatibility is particularly important, because a firmware image that flashes successfully may still fail to boot if its signature is not accepted by the SoC. Any help, matching firmware links, hardware documentation, or contacts with the original board manufacturer would be greatly appreciated. Thank you!
