Pingbo
Pingbo's Achievements
  1. sorry for the late test. As expected i get the same error again. Here two "screenshots" First run: http://fs2.directupload.net/images/150731/jc6hlost.jpg After the Reboot and the Login: http://fs1.directupload.net/images/150731/d4coj3wm.jpg
  2. thanks will test the way with the rootfs. I think the sd card is ok, because other images running fine. ok, let me test it. Will inform you with the results tommorrow
  3. yes, i was waiting for the first reboot, but i still get the error. So here the steps i did: 1. Flash image through the installer you provide 2. start the cubox 3. wait until the first reboot is done and the ssh key and so on are generated. 4. after the second boot login with the root account 5. get the screen to change the password 6. type in my new password and get the Authentication token manipulation error I also tried to reboot it again after the second boot, but it doesn't work Will try another image from you EDIT: Tried all latest images from you, wheezy, jessie and the ubuntu 14.04 image. I getting the same error on all images
  4. Hey, i'm getting the following error, when i try to login me as root: Authentication token manipulation error This error appears after i insert the first time the new password. I think this is an error in the Debian Image, isn't it ? Best Regards Pingbo
