Lorenzo
  1. Hi guys, thanks in advance for helping. I flashed a usb (32G Lexar) with the image Armbian_20.10_Arm-64_buster_current_5.9.0.img.xz Next I booted up via the "Update&Backup" on a T95K Pro based on Amlogic S912 with 16G of internal storage and 2G of ram. After apt-get update and apt-get upgrade I decided to move Armbian from the USB to the internal storage (emmc) So I ran the file "install-aml.sh" getting this output: Start script create MBR and filesystem /dev/mmcblk0 Start backup u-boot default 4+0 records in 4+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 4.45454 s, 942 kB/s Start create MBR and partittion Start restore u-boot 442+0 records in 442+0 records out 442 bytes copied, 0.00476152 s, 92.8 kB/s 8191+0 records in 8191+0 records out 4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.177546 s, 23.6 MB/s Done Start copy system for eMMC. Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24) done. Cppying BOOT...cp: error writing '/ddbr/install/zImage': No space left on device done. Edit init config...sed: couldn't flush /ddbr/install/extlinux/sedVudiPh: No space left on device done. done. Formatting ROOT partition... /dev/mmcblk0p2 contains a ext4 file system labelled 'ROOT_EMMC' last mounted on /ddbr/install on Sun Jul 4 17:10:59 2021 e2fsck 1.44.5 (15-Dec-2018) ROOT_EMMC: clean, 11/863264 files, 80826/3447552 blocks done. Copying ROOTFS. Copy BIN Create DEV Copy ETC Copy HOME Copy LIB Copy LIB64 Create MEDIA Create MNT Copy OPT Create PROC Copy ROOT Create RUN Copy SBIN Copy SELINUX Copy SRV Create SYS Create TMP Copy USR Copy VAR Copy fstab ******************************************* Complete copy OS to eMMC ******************************************* This is the output of lsdisk after running the script root@armbian:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 1 29.8G 0 disk |-sda1 8:1 1 512M 0 part /boot `-sda2 8:2 1 29G 0 part / mmcblk0 179:0 0 14.6G 0 disk |-mmcblk0p1 179:1 0 488M 0 part `-mmcblk0p2 179:2 0 13.2G 0 part mmcblk0boot0 179:32 0 4M 1 disk mmcblk0boot1 179:64 0 4M 1 disk zram0 254:0 0 50M 0 disk /var/log zram1 254:1 0 929.2M 0 disk [SWAP] However, after shutdown system and powered it up without the usb I get the following output: U-Boot 2020.07-dirty (Jul 26 2020 - 13:24:26 +0200) hexdump-gxl Model: hexdump usbkbd/hdmi u-boot gxl SoC: Amlogic Meson GXM (S912) Revision 22:a (82:2) Net: eth0 ethernet@c9410000 starting USB... Bus dwx3@c9000000: Register 3000140 NbrPorts 3 Starting the controller USB XHCI 1.00 scanning bus dwx3@c9000000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage device(s) found ## Error insterting "stdin" variable, errno=22 Card did not respond to voltage select! Card did not respond to voltage select! ** No partition table - mmc 1 ** ** No partition table - mmc 1 ** Hit any key to stop autoboot: [3-2-1-0] Card did not respond to voltage select! switch to partitions #0, OK mmc1 is current device ** No partition table - mmc 1 ** MMC Device 2 not found no mmc device at solt 2 Device 0: unknown device ethernet@c9410000 Waiting for PHY auto negotiation to complete........ TIMEOUT! Could not initialize PHY ethernet@c9410000 missing enviroment variable: pxeuuid missing enviroment variable: bootfile Retrieving file: pxelinux.cfg/00000000 *** COMMENT *** LOOPING OVER THESE 6 LINES TO INFINITY *** If I boot up with the usb inserted it goes fine, without it no. Output of ls -ls /dev/ root@armbian:/# ls dev -ls total 0 0 crw-r--r-- 1 root root 10, 235 Jul 4 17:41 autofs 0 drwxr-xr-x 2 root root 740 Jul 4 17:41 block 0 drwxr-xr-x 2 root root 60 Jan 1 1970 bsg 0 crw-rw---- 1 root disk 10, 234 Jul 4 17:41 btrfs-control 0 drwxr-xr-x 3 root root 60 Jan 1 1970 bus 0 crw-rw---- 1 root video 251, 0 Jul 4 17:41 cec0 0 crw-rw---- 1 root video 251, 1 Jul 4 17:41 cec1 0 drwxr-xr-x 2 root root 3620 Jul 4 17:42 char 0 crw------- 1 root root 5, 1 Jul 4 17:52 console 0 crw------- 1 root root 10, 60 Jul 4 17:41 cpu_dma_latency 0 crw------- 1 root root 10, 203 Jul 4 17:41 cuse 0 drwxr-xr-x 7 root root 140 Jan 1 1970 disk 0 drwxr-xr-x 2 root root 80 Jan 1 1970 dma_heap 0 drwxr-xr-x 3 root root 120 Jul 4 17:41 dri 0 crw-rw---- 1 root video 29, 0 Jul 4 17:41 fb0 0 crw-rw---- 1 root video 29, 1 Jul 4 17:41 fb1 0 lrwxrwxrwx 1 root root 13 Jan 1 1970 fd -> /proc/self/fd 0 crw-rw-rw- 1 root root 1, 7 Jul 4 17:41 full 0 crw-rw-rw- 1 root root 10, 229 Jul 4 17:41 fuse 0 crw------- 1 root root 254, 0 Jul 4 17:41 gpiochip0 0 crw------- 1 root root 254, 1 Jul 4 17:41 gpiochip1 0 drwxr-xr-x 2 root root 0 Feb 14 2019 hugepages 0 crw------- 1 root root 10, 183 Jul 4 17:41 hwrng 0 crw------- 1 root root 89, 0 Jul 4 17:41 i2c-0 0 crw------- 1 root root 89, 1 Jul 4 17:41 i2c-1 0 crw------- 1 root root 248, 0 Jul 4 17:41 iio:device0 0 lrwxrwxrwx 1 root root 12 Jul 4 17:41 initctl -> /run/initctl 0 drwxr-xr-x 3 root root 140 Jul 4 17:41 input 0 crw-r--r-- 1 root root 1, 11 Jul 4 17:41 kmsg 0 crw-rw---- 1 root video 238, 0 Jul 4 17:41 lirc0 0 lrwxrwxrwx 1 root root 28 Feb 14 2019 log -> /run/systemd/journal/dev-log 0 crw-rw---- 1 root disk 10, 237 Jul 4 17:41 loop-control 0 brw-rw---- 1 root disk 7, 0 Jul 4 17:41 loop0 0 brw-rw---- 1 root disk 7, 1 Jul 4 17:41 loop1 0 brw-rw---- 1 root disk 7, 2 Jul 4 17:41 loop2 0 brw-rw---- 1 root disk 7, 3 Jul 4 17:41 loop3 0 brw-rw---- 1 root disk 7, 4 Jul 4 17:41 loop4 0 brw-rw---- 1 root disk 7, 5 Jul 4 17:41 loop5 0 brw-rw---- 1 root disk 7, 6 Jul 4 17:41 loop6 0 brw-rw---- 1 root disk 7, 7 Jul 4 17:41 loop7 0 drwxr-xr-x 2 root root 60 Jul 4 17:41 mapper 0 crw-r----- 1 root kmem 1, 1 Jul 4 17:41 mem 0 brw-rw---- 1 root disk 179, 0 Jul 4 17:41 mmcblk0 0 brw-rw---- 1 root disk 179, 32 Jul 4 17:41 mmcblk0boot0 0 brw-rw---- 1 root disk 179, 64 Jul 4 17:41 mmcblk0boot1 0 brw-rw---- 1 root disk 179, 1 Jul 4 17:41 mmcblk0p1 0 brw-rw---- 1 root disk 179, 2 Jul 4 17:41 mmcblk0p2 0 crw------- 1 root root 241, 0 Jul 4 17:41 mmcblk0rpmb 0 drwxrwxrwt 2 root root 40 Jan 1 1970 mqueue 0 drwxr-xr-x 2 root root 60 Jul 4 17:41 net 0 crw-rw-rw- 1 root root 1, 3 Jul 4 17:41 null 0 crw------- 1 root root 10, 62 Jul 4 17:41 nvme-fabrics 0 crw-r----- 1 root kmem 1, 4 Jul 4 17:41 port 0 crw------- 1 root root 108, 0 Jul 4 17:41 ppp 0 crw-rw-rw- 1 root tty 5, 2 Jul 4 17:54 ptmx 0 drwxr-xr-x 2 root root 0 Jan 1 1970 pts 0 crw------- 1 root root 2, 0 Jul 4 17:41 ptyp0 0 crw------- 1 root root 2, 1 Jul 4 17:41 ptyp1 0 crw------- 1 root root 2, 2 Jul 4 17:41 ptyp2 0 crw------- 1 root root 2, 3 Jul 4 17:41 ptyp3 0 crw------- 1 root root 2, 4 Jul 4 17:41 ptyp4 0 crw------- 1 root root 2, 5 Jul 4 17:41 ptyp5 0 crw------- 1 root root 2, 6 Jul 4 17:41 ptyp6 0 crw------- 1 root root 2, 7 Jul 4 17:41 ptyp7 0 crw------- 1 root root 2, 8 Jul 4 17:41 ptyp8 0 crw------- 1 root root 2, 9 Jul 4 17:41 ptyp9 0 crw------- 1 root root 2, 10 Jul 4 17:41 ptypa 0 crw------- 1 root root 2, 11 Jul 4 17:41 ptypb 0 crw------- 1 root root 2, 12 Jul 4 17:41 ptypc 0 crw------- 1 root root 2, 13 Jul 4 17:41 ptypd 0 crw------- 1 root root 2, 14 Jul 4 17:41 ptype 0 crw------- 1 root root 2, 15 Jul 4 17:41 ptypf 0 brw-rw---- 1 root disk 1, 0 Jul 4 17:41 ram0 0 brw-rw---- 1 root disk 1, 1 Jul 4 17:41 ram1 0 brw-rw---- 1 root disk 1, 10 Jul 4 17:41 ram10 0 brw-rw---- 1 root disk 1, 11 Jul 4 17:41 ram11 0 brw-rw---- 1 root disk 1, 12 Jul 4 17:41 ram12 0 brw-rw---- 1 root disk 1, 13 Jul 4 17:41 ram13 0 brw-rw---- 1 root disk 1, 14 Jul 4 17:41 ram14 0 brw-rw---- 1 root disk 1, 15 Jul 4 17:41 ram15 0 brw-rw---- 1 root disk 1, 2 Jul 4 17:41 ram2 0 brw-rw---- 1 root disk 1, 3 Jul 4 17:41 ram3 0 brw-rw---- 1 root disk 1, 4 Jul 4 17:41 ram4 0 brw-rw---- 1 root disk 1, 5 Jul 4 17:41 ram5 0 brw-rw---- 1 root disk 1, 6 Jul 4 17:41 ram6 0 brw-rw---- 1 root disk 1, 7 Jul 4 17:41 ram7 0 brw-rw---- 1 root disk 1, 8 Jul 4 17:41 ram8 0 brw-rw---- 1 root disk 1, 9 Jul 4 17:41 ram9 0 crw-rw-rw- 1 root root 1, 8 Jul 4 17:41 random 0 drwxr-xr-x 2 root root 60 Jan 1 1970 raw 0 crw-rw-r-- 1 root netdev 10, 242 Jul 4 17:42 rfkill 0 brw-rw---- 1 root disk 8, 0 Jul 4 17:41 sda 0 brw-rw---- 1 root disk 8, 1 Jul 4 17:41 sda1 0 brw-rw---- 1 root disk 8, 2 Jul 4 17:41 sda2 0 crw-rw---- 1 root disk 21, 0 Jul 4 17:41 sg0 0 drwxrwxrwt 2 root root 40 Feb 14 2019 shm 0 crw------- 1 root root 10, 231 Jul 4 17:41 snapshot 0 drwxr-xr-x 3 root root 140 Jul 4 17:41 snd 0 lrwxrwxrwx 1 root root 15 Jan 1 1970 stderr -> /proc/self/fd/2 0 lrwxrwxrwx 1 root root 15 Jan 1 1970 stdin -> /proc/self/fd/0 0 lrwxrwxrwx 1 root root 15 Jan 1 1970 stdout -> /proc/self/fd/1 0 crw-rw-rw- 1 root tty 5, 0 Jul 4 17:41 tty 0 crw--w---- 1 root tty 4, 0 Jul 4 17:41 tty0 0 crw--w---- 1 root tty 4, 1 Jul 4 17:52 tty1 0 crw--w---- 1 root tty 4, 10 Jul 4 17:41 tty10 0 crw--w---- 1 root tty 4, 11 Jul 4 17:41 tty11 0 crw--w---- 1 root tty 4, 12 Jul 4 17:41 tty12 0 crw--w---- 1 root tty 4, 13 Jul 4 17:41 tty13 0 crw--w---- 1 root tty 4, 14 Jul 4 17:41 tty14 0 crw--w---- 1 root tty 4, 15 Jul 4 17:41 tty15 0 crw--w---- 1 root tty 4, 16 Jul 4 17:41 tty16 0 crw--w---- 1 root tty 4, 17 Jul 4 17:41 tty17 0 crw--w---- 1 root tty 4, 18 Jul 4 17:41 tty18 0 crw--w---- 1 root tty 4, 19 Jul 4 17:41 tty19 0 crw--w---- 1 root tty 4, 2 Jul 4 17:41 tty2 0 crw--w---- 1 root tty 4, 20 Jul 4 17:41 tty20 0 crw--w---- 1 root tty 4, 21 Jul 4 17:41 tty21 0 crw--w---- 1 root tty 4, 22 Jul 4 17:41 tty22 0 crw--w---- 1 root tty 4, 23 Jul 4 17:41 tty23 0 crw--w---- 1 root tty 4, 24 Jul 4 17:41 tty24 0 crw--w---- 1 root tty 4, 25 Jul 4 17:41 tty25 0 crw--w---- 1 root tty 4, 26 Jul 4 17:41 tty26 0 crw--w---- 1 root tty 4, 27 Jul 4 17:41 tty27 0 crw--w---- 1 root tty 4, 28 Jul 4 17:41 tty28 0 crw--w---- 1 root tty 4, 29 Jul 4 17:41 tty29 0 crw--w---- 1 root tty 4, 3 Jul 4 17:41 tty3 0 crw--w---- 1 root tty 4, 30 Jul 4 17:41 tty30 0 crw--w---- 1 root tty 4, 31 Jul 4 17:41 tty31 0 crw--w---- 1 root tty 4, 32 Jul 4 17:41 tty32 0 crw--w---- 1 root tty 4, 33 Jul 4 17:41 tty33 0 crw--w---- 1 root tty 4, 34 Jul 4 17:41 tty34 0 crw--w---- 1 root tty 4, 35 Jul 4 17:41 tty35 0 crw--w---- 1 root tty 4, 36 Jul 4 17:41 tty36 0 crw--w---- 1 root tty 4, 37 Jul 4 17:41 tty37 0 crw--w---- 1 root tty 4, 38 Jul 4 17:41 tty38 0 crw--w---- 1 root tty 4, 39 Jul 4 17:41 tty39 0 crw--w---- 1 root tty 4, 4 Jul 4 17:41 tty4 0 crw--w---- 1 root tty 4, 40 Jul 4 17:41 tty40 0 crw--w---- 1 root tty 4, 41 Jul 4 17:41 tty41 0 crw--w---- 1 root tty 4, 42 Jul 4 17:41 tty42 0 crw--w---- 1 root tty 4, 43 Jul 4 17:41 tty43 0 crw--w---- 1 root tty 4, 44 Jul 4 17:41 tty44 0 crw--w---- 1 root tty 4, 45 Jul 4 17:41 tty45 0 crw--w---- 1 root tty 4, 46 Jul 4 17:41 tty46 0 crw--w---- 1 root tty 4, 47 Jul 4 17:41 tty47 0 crw--w---- 1 root tty 4, 48 Jul 4 17:41 tty48 0 crw--w---- 1 root tty 4, 49 Jul 4 17:41 tty49 0 crw--w---- 1 root tty 4, 5 Jul 4 17:41 tty5 0 crw--w---- 1 root tty 4, 50 Jul 4 17:41 tty50 0 crw--w---- 1 root tty 4, 51 Jul 4 17:41 tty51 0 crw--w---- 1 root tty 4, 52 Jul 4 17:41 tty52 0 crw--w---- 1 root tty 4, 53 Jul 4 17:41 tty53 0 crw--w---- 1 root tty 4, 54 Jul 4 17:41 tty54 0 crw--w---- 1 root tty 4, 55 Jul 4 17:41 tty55 0 crw--w---- 1 root tty 4, 56 Jul 4 17:41 tty56 0 crw--w---- 1 root tty 4, 57 Jul 4 17:41 tty57 0 crw--w---- 1 root tty 4, 58 Jul 4 17:41 tty58 0 crw--w---- 1 root tty 4, 59 Jul 4 17:41 tty59 0 crw--w---- 1 root tty 4, 6 Jul 4 17:41 tty6 0 crw--w---- 1 root tty 4, 60 Jul 4 17:41 tty60 0 crw--w---- 1 root tty 4, 61 Jul 4 17:41 tty61 0 crw--w---- 1 root tty 4, 62 Jul 4 17:41 tty62 0 crw--w---- 1 root tty 4, 63 Jul 4 17:41 tty63 0 crw--w---- 1 root tty 4, 7 Jul 4 17:41 tty7 0 crw--w---- 1 root tty 4, 8 Jul 4 17:41 tty8 0 crw--w---- 1 root tty 4, 9 Jul 4 17:41 tty9 0 crw--w---- 1 root tty 244, 0 Jul 4 17:52 ttyAML0 0 crw-rw---- 1 root dialout 4, 64 Jul 4 17:41 ttyS0 0 crw-rw---- 1 root dialout 4, 65 Jul 4 17:41 ttyS1 0 crw--w---- 1 root tty 4, 66 Jul 4 17:41 ttyS2 0 crw-rw---- 1 root dialout 4, 67 Jul 4 17:41 ttyS3 0 crw-rw---- 1 root dialout 4, 68 Jul 4 17:41 ttyS4 0 crw------- 1 root root 3, 0 Jul 4 17:41 ttyp0 0 crw------- 1 root root 3, 1 Jul 4 17:41 ttyp1 0 crw------- 1 root root 3, 2 Jul 4 17:41 ttyp2 0 crw------- 1 root root 3, 3 Jul 4 17:41 ttyp3 0 crw------- 1 root root 3, 4 Jul 4 17:41 ttyp4 0 crw------- 1 root root 3, 5 Jul 4 17:41 ttyp5 0 crw------- 1 root root 3, 6 Jul 4 17:41 ttyp6 0 crw------- 1 root root 3, 7 Jul 4 17:41 ttyp7 0 crw------- 1 root root 3, 8 Jul 4 17:41 ttyp8 0 crw------- 1 root root 3, 9 Jul 4 17:41 ttyp9 0 crw------- 1 root root 3, 10 Jul 4 17:41 ttypa 0 crw------- 1 root root 3, 11 Jul 4 17:41 ttypb 0 crw------- 1 root root 3, 12 Jul 4 17:41 ttypc 0 crw------- 1 root root 3, 13 Jul 4 17:41 ttypd 0 crw------- 1 root root 3, 14 Jul 4 17:41 ttype 0 crw------- 1 root root 3, 15 Jul 4 17:41 ttypf 0 crw------- 1 root root 10, 239 Jul 4 17:41 uhid 0 crw------- 1 root root 10, 223 Jul 4 17:41 uinput 0 crw------- 1 root root 10, 61 Jul 4 17:41 uleds 0 crw-rw-rw- 1 root root 1, 9 Jul 4 17:41 urandom 0 drwxr-xr-x 3 root root 60 Jul 4 17:41 v4l 0 crw-rw---- 1 root tty 7, 0 Jul 4 17:41 vcs 0 crw-rw---- 1 root tty 7, 1 Jul 4 17:41 vcs1 0 crw-rw---- 1 root tty 7, 2 Jul 4 17:41 vcs2 0 crw-rw---- 1 root tty 7, 3 Jul 4 17:41 vcs3 0 crw-rw---- 1 root tty 7, 4 Jul 4 17:41 vcs4 0 crw-rw---- 1 root tty 7, 5 Jul 4 17:41 vcs5 0 crw-rw---- 1 root tty 7, 6 Jul 4 17:41 vcs6 0 crw-rw---- 1 root tty 7, 128 Jul 4 17:41 vcsa 0 crw-rw---- 1 root tty 7, 129 Jul 4 17:41 vcsa1 0 crw-rw---- 1 root tty 7, 130 Jul 4 17:41 vcsa2 0 crw-rw---- 1 root tty 7, 131 Jul 4 17:41 vcsa3 0 crw-rw---- 1 root tty 7, 132 Jul 4 17:41 vcsa4 0 crw-rw---- 1 root tty 7, 133 Jul 4 17:41 vcsa5 0 crw-rw---- 1 root tty 7, 134 Jul 4 17:41 vcsa6 0 crw-rw---- 1 root tty 7, 64 Jul 4 17:41 vcsu 0 crw-rw---- 1 root tty 7, 65 Jul 4 17:41 vcsu1 0 crw-rw---- 1 root tty 7, 66 Jul 4 17:41 vcsu2 0 crw-rw---- 1 root tty 7, 67 Jul 4 17:41 vcsu3 0 crw-rw---- 1 root tty 7, 68 Jul 4 17:41 vcsu4 0 crw-rw---- 1 root tty 7, 69 Jul 4 17:41 vcsu5 0 crw-rw---- 1 root tty 7, 70 Jul 4 17:41 vcsu6 0 drwxr-xr-x 2 root root 60 Jan 1 1970 vfio 0 crw------- 1 root root 10, 63 Jul 4 17:41 vga_arbiter 0 crw------- 1 root root 10, 137 Jul 4 17:41 vhci 0 crw-rw---- 1 root video 81, 0 Jul 4 17:41 video0 0 crw------- 1 root root 10, 130 Jul 4 17:41 watchdog 0 crw------- 1 root root 246, 0 Jul 4 17:41 watchdog0 0 crw-rw-rw- 1 root root 1, 5 Jul 4 17:41 zero 0 brw-rw---- 1 root disk 254, 0 Jul 4 17:41 zram0 0 brw-rw---- 1 root disk 254, 1 Jul 4 17:41 zram1 0 brw-rw---- 1 root disk 254, 2 Jul 4 17:41 zram2 Any help is really appreciated. Lorenzo (Italy)
