papasmurfster
  1. I chose mainline on the first screen and wheezy on the 2nd (u can chose any really on the second screen).
  2. I dont think the PCTV 292e is supported in the 3.4 kernek http://www.linuxtv.org/wiki/index.php/PCTV_Systems_tripleStick_T2_(292e)
  3. Well I got round to building the new Image last night. All I can say is thank you. The kernel so far at least is working perfect. its found all 4 devices PCTV 461 PCTV 292e PCTV 290e DVbSky 960 I used the following firmware commands sudo wget https://github.com/OpenELEC/dvb-firmware/blob/master/firmware/dvb-demod-si2168-02.fw?raw=true-O /lib/firmware/dvb-demod-si2168-02.fw sudo wget https://github.com/OpenELEC/dvb-firmware/blob/master/firmware/dvb-demod-si2168-b40-01.fw?raw=true-O /lib/firmware/dvb-demod-si2168-b40-01.fw sudo wget https://github.com/OpenELEC/dvb-firmware/blob/master/firmware/dvb-demod-m88ds3103.fw?raw=true-O /lib/firmware/dvb-demod-m88ds3103.fw I'll try and post some more details on the results after I've tried it for a week or 2. Thanks again
  4. Hi Azreal, I'm in a similar situation, I have a Banana Pi. I'm using Igors Jessie Image with kernel 4.1.2 and I cant seem to see any of my usb dvb devices (one of which is Triplestick 292e). Could you details what exactly you did, I've tried the the cross compiler with the menuconfig option enabled. I just cant see to see what features need to be enabled in the config. Regards Steve
