sbecue
sbecue's Achievements
  1. Ok it's work yesterday night my hostapd.conf needed bridge=br0 instruction I don't saw you configuration exmple in /etc/. I saw in /etc/hostapd, is empty Thank you for your work and your help Sébastien
  2. OK thank you I tested with Cubietruck_Debian_3.8_wheezy_3.4.107.raw with ssh connection , I moved resolution and execute mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr upgraded system network config ip_forwarding install dhcp-serveur I see my ssid since my wifi client But not connetced, i think is not hard , i find it. Thank-you for your help I find my problem and I write a article for hel in french see you and thank's
  3. when the message is : Cannot Display This video mode connect with ssh edit /boot/boot.cmd change resolution in ligne : setenv bootargs console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1024x768p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 execute mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr reboot an is OK. If not ok, move the resolution : 1024x768p60 by less
  4. Hi, thank for your work i need to make a hotspot with cubietruck I test all debian images for cubietruck but impossible Configuration - connexion VGA - ethernet connected - microsdcard 16G sandisk ou 32 g - clavier with doogle usb all image is dowload today ** Cubietruck_Debian_3.7_jessie_4.0.3 last message Welcom to Debian GNU/Linux 8 (jessie)! [TIME] Timed ou waiting for device dev-ttyS0.device. [DEPEND] Dependency failed for serial Getty on ttyS0. ** Cubietruck_Debian_3.7_jessie_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.7_wheezy_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.7_wheezy_4.0.3.raw ... failed to bring up eth0 ... [OK] Restarting OpenBSD Secure Shell Server : sshd 15 minutes rient tentative de connexion a ssh KO ** Cubietruck_Debian_3.8_jessie_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.8_jessie_4.0.4.raw Welcom to Debian GNU/Linux 8 (jessie)! [TIME] Timed ou waiting for device dev-ttyS0.device. [DEPEND] Dependency failed for serial Getty on ttyS0. ** Cubietruck_Debian_3.8_wheezy_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.8_wheezy_4.0.4.raw ... failed to bring up eth0 ... [OK] Restarting OpenBSD Secure Shell Server : sshd 15 minutes rient tentative de connexion a ssh KO ** Cubietruck_Debian_3.6_jessie_3.4.107.raw : old image , not download today boot: OK update : OK but wifi en mode hotspot don't work if I write in /etc/modules file bcmdhd : I can't see my SSID with my wifi device or bcmdhd op_mode=2 : dont load the module If the bcmdhd module is not load and I execute the commande "modprobe bcmdhd op_mode=2" and start hostapd, I can see my ssid with my wifi device ** Cubietruck_Ubuntu_3.8_trusty_4.0.4.raw [3.628018] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code ~3 minutes ... ... ssh start/running, process961 wait and nothing Have you a solution for me please ? I'm sorry my english is bad, My Linux is better, but not excelent!!!
