Crst
  1. UPDATE : Quickfix is working! I append your few lines and now the GUI is working again. Thanks Igor.
  2. I can only access via rdp and there is everything okay with the GUI. I actually have this in the /etc/X11/xorg.conf.d/01-armbian-defaults.conf file : Section "Monitor" Identifier "Monitor0" Option "DPMS" "false" EndSection Section "ServerFlags" Option "BlankTime" "0" Option "StandbyTime" "0" Option "SuspendTime" "0" Option "OffTime" "0" EndSection Do you mean replacing with your code? Do you have a plan when the update is ready?
  3. Armbian 5.90 stable Ubuntu bionic Orange Pi PC The Login Screen is very broken and after login, the Screen wents black and only the mouse Pointer is to see.
  4. Hey thanks, I added the rotation option to the X11 config but the problem still exists... Here a Screenshot what xrand say before and after turning the Screen off and on. Someone another solution ?
  5. INFOS: Armbian Bionic mainline kernel 4.19.20 System: OrangePi Pc Monitor, full HD (1920*1080), over HDMI. SOLUTION, ROTATE SCREEN: My rotation Settings that i try: 1. xrandr (not permanently, only for this session) 2. echo n > /sys/class/graphics/fbcon/rotate_all n=0,1,2,3 (permanently solution) See: http://linux-sunxi.org/Display <-Point:Rotation PROBLEM: Screen rotation problem: On every boot the rotation is correctly applied BUT: Turn Monitor off an then on again, the rotation is NOT applied. PROBLEM SINCE : Quarterly update cycle, until november 2018 everything works fine and i did not have this problem. QUESTION: Is this still the right way rotate the screen, or is there a different/new way. Whats happend, that the Screen is not rotated after switching on again, how to solve it?
