craesz
craesz's Achievements
  1. How do I do that when the NAS is not connected to the internet??
  2. 1 2 ### lsusb: 3 4 Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 5 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 6 Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 7 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 8 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 9 10 /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M 11 /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M 12 /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M 13 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M 14 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M 15 16 ### lspci: 17 18 19 ### Installed packages: 20 21 ii armbian-config 5.91 all Armbian configuration utility 22 ii armbian-firmware 5.91 all Linux firmware 23 ii armbian-tools-stretch 5.91 armhf Armbian tools, Cubie bt utils 24 ii hostapd 3:2.7-99~armbian5.86+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator 25 ii linux-base 4.5 all Linux image base package 26 ii linux-dtb-mvebu 5.91 armhf Linux DTB, version 4.14.135-mvebu 27 ii linux-image-mvebu 5.91 armhf Linux kernel, version 4.14.135-mvebu 28 ii linux-libc-dev 5.70 armhf Linux support headers for userspace development 29 ii linux-stretch-root-helios4 5.91 armhf Armbian tweaks for stretch on helios4 (default branch) 30 ii linux-u-boot-helios4-default 5.91 armhf Uboot loader 2018.11 31 ii sunxi-tools 1.4.2-2~armbian5.86+1 armhf tools for working with Allwinner (sunxi) ARM processors 32 33 ### Loaded modules: 34 35 Module Size Used by 36 lz4hc 16384 2 37 lz4hc_compress 24576 1 lz4hc 38 zram 20480 2 39 zsmalloc 20480 1 zram 40 orion_wdt 16384 0 41 pwm_fan 16384 0 42 lm75 20480 0 43 marvell_cesa 28672 0 44 ip_tables 20480 0 45 x_tables 20480 1 ip_tables 46 raid456 102400 0 47 async_raid6_recov 16384 1 raid456 48 async_memcpy 16384 2 raid456,async_raid6_recov 49 async_pq 16384 2 raid456,async_raid6_recov 50 async_xor 16384 3 async_pq,raid456,async_raid6_recov 51 async_tx 16384 5 async_xor,async_pq,raid456,async_memcpy,async_raid6_recov 52 raid1 32768 0 53 raid0 20480 0 54 raid10 45056 1 55 md_mod 98304 5 raid1,raid10,raid0,raid456 56 57 ### Current system health: 58 59 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 60 22:28:13: --- 0.00 1% 0% 0% 0% 0% 1% 53.2°C 0/0 61 22:28:14: --- 0.00 5% 5% 0% 0% 0% 0% 50.8°C 0/0 62 22:28:14: --- 0.00 8% 7% 0% 1% 0% 0% 50.4°C 0/0 63 22:28:14: --- 0.00 7% 5% 0% 1% 0% 0% 49.9°C 0/0 64 22:28:15: --- 0.00 5% 5% 0% 0% 0% 0% 50.8°C 0/0 65 22:28:16: --- 0.00 1% 0% 0% 0% 0% 1% 56.5°C 0/0 66 22:28:17: --- 0.24 100% 0% 100% 0% 0% 0% 58.0°C 0/0 67 22:28:18: --- 0.24 91% 0% 91% 0% 0% 0% 53.7°C 0/0 68 22:28:19: --- 0.24 8% 7% 0% 1% 0% 0% 51.3°C 0/0 69 22:28:19: --- 0.24 5% 5% 0% 0% 0% 0% 51.3°C 0/0 70 71 ### resolv.conf 72 73 -rw-r--r-- 1 root root 72 Feb 20 03:07 /etc/resolv.conf 74 # Generated by NetworkManager 75 nameserver XXX.XXX.8.8 76 nameserver XXX.XXX.0.1 77 78 ### Current sysinfo: 79 80 Linux 4.14.135-mvebu (helios4) 07/20/21 _armv7l_ (2 CPU) 81 82 avg-cpu: %user %nice %system %iowait %steal %idle 83 0.02 0.00 1.80 0.00 0.00 98.18 84 85 Device: tps kB_read/s kB_wrtn/s kB_read kB_wrtn 86 mmcblk0 0.00 0.01 0.23 93625 3033460 87 mmcblk0p1 0.00 0.01 0.23 90501 3033460 88 sda 8.40 87.60 0.01 1176984692 86060 89 sdb 8.40 87.60 0.01 1176983800 86060 90 sdc 8.43 87.60 0.01 1176985004 86056 91 sdd 8.45 87.60 0.01 1176983232 86056 92 md0 0.00 0.00 0.00 6029 4 93 zram0 0.09 0.00 0.34 780 4599692 94 zram1 0.00 0.00 0.00 1196 4 95 zram2 0.00 0.00 0.00 0 0 96 97 procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- 98 r b swpd free buff cache si so bi bo in cs us sy id wa st 99 0 0 0 1701924 39736 163956 0 0 0 0 0 1 0 2 98 0 0 100 101 total used free shared buff/cache available 102 Mem: 2.0G 157M 1.6G 24M 198M 1.7G 103 Swap: 1.0G 0B 1.0G 104 105 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 106 /dev/zram0 50M 21.7M 2.4M 2.7M 2 /var/log 107 /dev/zram1 lzo 1009.2M 4K 81B 12K 2 [SWAP] 108 109 22:28:19 up 155 days, 12:11, 1 user, load average: 0.24, 0.05, 0.02 110 111 [ 1.418518] workingset: timestamp_bits=14 max_order=19 bucket_order=5 112 [ 1.420495] zbud: loaded 113 [ 1.421185] squashfs: version 4.0 (2009/01/31) Phillip Lougher 114 [ 1.421401] FS-Cache: Netfs 'nfs' registered for caching 115 [ 1.421580] NFS: Registering the id_resolver key type 116 [ 1.421591] Key type id_resolver registered 117 [ 1.421593] Key type id_legacy registered 118 [ 1.421599] nfs4filelayout_init: NFSv4 File Layout Driver Registering... 119 [ 1.421677] fuse init (API version 7.26) 120 [ 1.421939] aufs 4.14-20171218 121 [ 1.424123] bounce: pool size: 64 pages 122 [ 1.424156] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) 123 [ 1.424210] io scheduler noop registered 124 [ 1.424212] io scheduler deadline registered 125 [ 1.424287] io scheduler cfq registered (default) 126 [ 1.424289] io scheduler mq-deadline registered 127 [ 1.424291] io scheduler kyber registered 128 [ 1.424351] io scheduler bfq registered 129 [ 1.425009] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver 130 [ 1.426260] mv_xor f1060800.xor: Marvell shared XOR driver 131 [ 1.453583] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr ) 132 [ 1.453677] mv_xor f1060900.xor: Marvell shared XOR driver 133 [ 1.489572] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr ) 134 [ 1.504325] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled 135 [ 1.505222] console [ttyS0] disabled 136 [ 1.525285] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A 137 [ 1.525311] console [ttyS0] enabled 138 [ 1.527957] loop: module loaded 139 [ 1.528465] ahci-mvebu f10a8000.sata: masking port_map 0x3 -> 0x3 140 [ 1.528495] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode 141 [ 1.528500] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs 142 [ 1.529029] scsi host0: ahci-mvebu 143 [ 1.529218] scsi host1: ahci-mvebu 144 [ 1.529293] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 41 145 [ 1.529296] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 41 146 [ 1.529554] ahci-mvebu f10e0000.sata: masking port_map 0x3 -> 0x3 147 [ 1.529580] ahci-mvebu f10e0000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode 148 [ 1.529586] ahci-mvebu f10e0000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs 149 [ 1.530110] scsi host2: ahci-mvebu 150 [ 1.530251] scsi host3: ahci-mvebu 151 [ 1.530327] ata3: SATA max UDMA/133 mmio [mem 0xf10e0000-0xf10e1fff] port 0x100 irq 42 152 [ 1.530330] ata4: SATA max UDMA/133 mmio [mem 0xf10e0000-0xf10e1fff] port 0x180 irq 42 153 [ 1.530811] libphy: Fixed MDIO Bus: probed 154 [ 1.531069] libphy: orion_mdio_bus: probed 155 [ 1.534019] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled 156 [ 1.535436] mvneta f1070000.ethernet eth0: Using device tree mac address 0e:5a:0f:9d:78:b4 157 [ 1.535599] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 158 [ 1.535601] ehci-pci: EHCI PCI platform driver 159 [ 1.535631] ehci-orion: EHCI orion driver 160 [ 1.535712] orion-ehci f1058000.usb: EHCI Host Controller 161 [ 1.535729] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1 162 [ 1.535814] orion-ehci f1058000.usb: irq 37, io mem 0xf1058000 163 [ 1.549114] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00 164 [ 1.549216] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 165 [ 1.549220] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 166 [ 1.549223] usb usb1: Product: EHCI Host Controller 167 [ 1.549226] usb usb1: Manufacturer: Linux 4.14.135-mvebu ehci_hcd 168 [ 1.549229] usb usb1: SerialNumber: f1058000.usb 169 [ 1.549447] hub 1-0:1.0: USB hub found 170 [ 1.549469] hub 1-0:1.0: 1 port detected 171 [ 1.549826] xhci-hcd f10f0000.usb3: xHCI Host Controller 172 [ 1.549836] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2 173 [ 1.549957] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010 174 [ 1.549982] xhci-hcd f10f0000.usb3: irq 44, io mem 0xf10f0000 175 [ 1.550068] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 176 [ 1.550071] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 177 [ 1.550074] usb usb2: Product: xHCI Host Controller 178 [ 1.550077] usb usb2: Manufacturer: Linux 4.14.135-mvebu xhci-hcd 179 [ 1.550080] usb usb2: SerialNumber: f10f0000.usb3 180 [ 1.550265] hub 2-0:1.0: USB hub found 181 [ 1.550281] hub 2-0:1.0: 1 port detected 182 [ 1.550400] xhci-hcd f10f0000.usb3: xHCI Host Controller 183 [ 1.550407] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3 184 [ 1.550422] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed 185 [ 1.550455] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM. 186 [ 1.550512] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003 187 [ 1.550516] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 188 [ 1.550519] usb usb3: Product: xHCI Host Controller 189 [ 1.550521] usb usb3: Manufacturer: Linux 4.14.135-mvebu xhci-hcd 190 [ 1.550524] usb usb3: SerialNumber: f10f0000.usb3 191 [ 1.550690] hub 3-0:1.0: USB hub found 192 [ 1.550705] hub 3-0:1.0: 1 port detected 193 [ 1.550885] xhci-hcd f10f8000.usb3: xHCI Host Controller 194 [ 1.550895] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4 195 [ 1.551008] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010 196 [ 1.551030] xhci-hcd f10f8000.usb3: irq 45, io mem 0xf10f8000 197 [ 1.551108] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 198 [ 1.551112] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 199 [ 1.551114] usb usb4: Product: xHCI Host Controller 200 [ 1.551117] usb usb4: Manufacturer: Linux 4.14.135-mvebu xhci-hcd 201 [ 1.551120] usb usb4: SerialNumber: f10f8000.usb3 202 [ 1.551298] hub 4-0:1.0: USB hub found 203 [ 1.551313] hub 4-0:1.0: 1 port detected 204 [ 1.551443] xhci-hcd f10f8000.usb3: xHCI Host Controller 205 [ 1.551450] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5 206 [ 1.551459] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed 207 [ 1.551491] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM. 208 [ 1.551546] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003 209 [ 1.551550] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 210 [ 1.551553] usb usb5: Product: xHCI Host Controller 211 [ 1.551556] usb usb5: Manufacturer: Linux 4.14.135-mvebu xhci-hcd 212 [ 1.551558] usb usb5: SerialNumber: f10f8000.usb3 213 [ 1.551722] hub 5-0:1.0: USB hub found 214 [ 1.551736] hub 5-0:1.0: 1 port detected 215 [ 1.551963] usbcore: registered new interface driver usb-storage 216 [ 1.552066] mousedev: PS/2 mouse device common for all mice 217 [ 1.552525] armada38x-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0 218 [ 1.552631] i2c /dev entries driver 219 [ 1.552926] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator 220 [ 1.555283] GPIO line 496 (board-rev-0) hogged as input 221 [ 1.555477] GPIO line 497 (board-rev-1) hogged as input 222 [ 1.555671] GPIO line 501 (usb-overcurrent-status) hogged as input 223 [ 1.556378] armada_thermal f10e4078.thermal: res size = 8 224 [ 1.557174] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info(). 225 [ 1.557432] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com 226 [ 1.557743] cpu cpu1: opp_list_debug_create_link: Failed to create link 227 [ 1.557747] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12) 228 [ 1.557882] sdhci: Secure Digital Host Controller Interface driver 229 [ 1.557884] sdhci: Copyright(c) Pierre Ossman 230 [ 1.558051] sdhci-pxav3 f10d8000.sdhci: Got CD GPIO 231 [ 1.612167] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA 232 [ 1.612335] sdhci-pltfm: SDHCI platform and OF driver helper 233 [ 1.613179] ledtrig-cpu: registered to indicate activity on CPUs 234 [ 1.613226] hidraw: raw HID events driver (C) Jiri Kosina 235 [ 1.613307] usbcore: registered new interface driver usbhid 236 [ 1.613309] usbhid: USB HID core driver 237 [ 1.613630] ipip: IPv4 and MPLS over IPv4 tunneling driver 238 [ 1.613942] Initializing XFRM netlink socket 239 [ 1.614382] NET: Registered protocol family 10 240 [ 1.626622] Segment Routing with IPv6 241 [ 1.626688] NET: Registered protocol family 17 242 [ 1.626704] NET: Registered protocol family 15 243 [ 1.626734] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. 244 [ 1.626773] 8021q: 802.1Q VLAN Support v1.8 245 [ 1.626797] Key type dns_resolver registered 246 [ 1.626967] ThumbEE CPU extension supported. 247 [ 1.626975] Registering SWP/SWPB emulation handler 248 [ 1.627743] registered taskstats version 1 249 [ 1.627772] zswap: loaded using pool lzo/zbud 250 [ 1.628412] Btrfs loaded, crc32c=crc32c-generic 251 [ 1.631419] Key type encrypted registered 252 [ 1.632304] USB-PWR: supplied by power_brick_12V 253 [ 1.632738] input: gpio-keys as /devices/platform/gpio-keys/input/input0 254 [ 1.654360] mmc0: new high speed SDHC card at address aaaa 255 [ 1.654759] mmcblk0: mmc0:aaaa SP32G 29.7 GiB 256 [ 1.655695] mmcblk0: p1 257 [ 2.011871] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) 258 [ 2.011891] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) 259 [ 2.011910] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) 260 [ 2.011925] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) 261 [ 2.012374] ata3.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133 262 [ 2.012381] ata3.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32) 263 [ 2.012417] ata4.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133 264 [ 2.012421] ata1.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133 265 [ 2.012427] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32) 266 [ 2.012432] ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32) 267 [ 2.012455] ata2.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133 268 [ 2.012461] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32) 269 [ 2.012856] ata3.00: configured for UDMA/133 270 [ 2.012894] ata4.00: configured for UDMA/133 271 [ 2.012914] ata1.00: configured for UDMA/133 272 [ 2.012938] ata2.00: configured for UDMA/133 273 [ 2.013301] scsi 0:0:0:0: Direct-Access ATA WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5 274 [ 2.013800] sd 0:0:0:0: Attached scsi generic sg0 type 0 275 [ 2.013843] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) sysctl: permission denied on key 'vm.mmap_rnd_bits' sysctl: permission denied on key 'vm.stat_refresh' 276 [ 2.013850] sd 0:0:0:0: [sda] 4096-byte physical blocks 277 [ 2.013891] sd 0:0:0:0: [sda] Write Protect is off 278 [ 2.013899] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 279 [ 2.014209] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA 280 [ 2.014226] scsi 1:0:0:0: Direct-Access ATA WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5 281 [ 2.014716] sd 1:0:0:0: Attached scsi generic sg1 type 0 282 [ 2.015145] scsi 2:0:0:0: Direct-Access ATA WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5 283 [ 2.015263] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) 284 [ 2.015271] sd 1:0:0:0: [sdb] 4096-byte physical blocks 285 [ 2.015304] sd 1:0:0:0: [sdb] Write Protect is off 286 [ 2.015311] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 287 [ 2.015366] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA 288 [ 2.015633] sd 2:0:0:0: Attached scsi generic sg2 type 0 289 [ 2.016068] scsi 3:0:0:0: Direct-Access ATA WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5 290 [ 2.016305] sd 0:0:0:0: [sda] Attached SCSI removable disk 291 [ 2.016516] sd 3:0:0:0: Attached scsi generic sg3 type 0 292 [ 2.016604] sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) 293 [ 2.016611] sd 3:0:0:0: [sdd] 4096-byte physical blocks 294 [ 2.016721] sd 3:0:0:0: [sdd] Write Protect is off 295 [ 2.016728] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00 296 [ 2.016792] sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) 297 [ 2.016799] sd 2:0:0:0: [sdc] 4096-byte physical blocks 298 [ 2.016834] sd 2:0:0:0: [sdc] Write Protect is off 299 [ 2.016841] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00 300 [ 2.016852] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA 301 [ 2.016896] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA 302 [ 2.018324] sd 1:0:0:0: [sdb] Attached SCSI removable disk 303 [ 2.018776] sd 2:0:0:0: [sdc] Attached SCSI removable disk 304 [ 2.019033] sd 3:0:0:0: [sdd] Attached SCSI removable disk 305 [ 2.019971] Freeing unused kernel memory: 1024K 306 [ 2.066014] random: systemd-udevd: uninitialized urandom read (16 bytes read) 307 [ 2.066285] random: systemd-udevd: uninitialized urandom read (16 bytes read) 308 [ 2.066330] random: systemd-udevd: uninitialized urandom read (16 bytes read) 309 [ 2.363490] md/raid10:md0: active with 4 out of 4 devices 310 [ 2.393322] random: fast init done 311 [ 2.486500] md0: detected capacity change from 0 to 4000529252352 312 [ 2.821801] async_tx: api initialized (async) 313 [ 3.248590] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 314 [ 3.339212] random: crng init done 315 [ 3.339218] random: 7 urandom warning(s) missed due to ratelimiting 316 [ 3.689317] systemd[1]: System time before build time, advancing clock. 317 [ 3.703082] ip_tables: (C) 2000-2006 Netfilter Core Team 318 [ 3.727753] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) 319 [ 3.727941] systemd[1]: Detected architecture arm. 320 [ 3.754664] systemd[1]: Set hostname to <helios4>. 321 [ 4.045470] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. 322 [ 4.065388] systemd[1]: Listening on Journal Socket. 323 [ 4.077320] systemd[1]: Listening on Journal Audit Socket. 324 [ 4.091507] systemd[1]: Listening on Journal Socket (/dev/log). 325 [ 4.107500] systemd[1]: Listening on udev Control Socket. 326 [ 4.123405] systemd[1]: Reached target Remote File Systems. 327 [ 4.139565] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 328 [ 4.394086] marvell-cesa f1090000.crypto: CESA device successfully registered 329 [ 4.396646] lm75 0-004c: hwmon2: sensor 'lm75' 330 [ 4.443766] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 331 [ 4.866967] systemd-journald[235]: Received request to flush runtime journal from PID 1 332 [ 5.245518] orion_wdt: Initial timeout 171 sec 333 [ 5.388607] zram: Added device: zram0 334 [ 5.388807] zram: Added device: zram1 335 [ 5.389730] zram: Added device: zram2 336 [ 5.545296] zram1: detected capacity change from 0 to 1058217984 337 [ 5.631424] Adding 1033412k swap on /dev/zram1. Priority:5 extents:1 across:1033412k SSFS 338 [ 5.909965] zram0: detected capacity change from 0 to 52428800 339 [ 6.521216] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 340 [ 7.067054] EXT4-fs (md0): recovery complete 341 [ 7.067065] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: discard 342 [ 9.414066] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready 343 [ 9.431147] nr_pdflush_threads exported in /proc is scheduled for removal 344 [ 9.490185] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready 345 [ 11.613505] mvneta f1070000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx 346 [ 11.613523] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready 347 [404999.141602] mvneta f1070000.ethernet eth0: Link is Down 348 [406195.088570] mvneta f1070000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx 349 [1694283.900809] md: data-check of RAID array md0 350 [1713878.962099] md: md0: data-check done. 351 [4113309.689665] md: data-check of RAID array md0 352 [4132908.488867] md: md0: data-check done. 353 [6532336.261381] md: data-check of RAID array md0 354 [6551934.240206] md: md0: data-check done. 355 [7636727.092602] mvneta f1070000.ethernet eth0: Link is Down 356 [7636728.109759] mvneta f1070000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx 357 [9556119.551723] md: data-check of RAID array md0 358 [9575714.138632] md: md0: data-check done. 359 [11975146.058893] md: data-check of RAID array md0 360 [11994739.680076] md: md0: data-check done. 361 362 363 vm.admin_reserve_kbytes = 8192 364 vm.block_dump = 0 365 vm.compact_unevictable_allowed = 1 366 vm.dirty_background_bytes = 0 367 vm.dirty_background_ratio = 10 368 vm.dirty_bytes = 0 369 vm.dirty_expire_centisecs = 3000 370 vm.dirty_ratio = 20 371 vm.dirty_writeback_centisecs = 500 372 vm.dirtytime_expire_seconds = 43200 373 vm.drop_caches = 0 374 vm.extfrag_threshold = 500 375 vm.highmem_is_dirtyable = 0 376 vm.laptop_mode = 0 377 vm.legacy_va_layout = 0 378 vm.lowmem_reserve_ratio = 32 32 379 vm.max_map_count = 65530 380 vm.min_free_kbytes = 3463 381 vm.mmap_min_addr = 4096 382 vm.nr_pdflush_threads = 0 383 vm.oom_dump_tasks = 1 384 vm.oom_kill_allocating_task = 0 385 vm.overcommit_kbytes = 0 386 vm.overcommit_memory = 0 387 vm.overcommit_ratio = 50 388 vm.page-cluster = 0 389 vm.panic_on_oom = 0 390 vm.percpu_pagelist_fraction = 0 391 vm.stat_interval = 1 392 vm.swappiness = 100 393 vm.user_reserve_kbytes = 64331 394 vm.vfs_cache_pressure = 100 395 vm.watermark_scale_factor = 10 396 397 ### interrupts: 398 CPU0 CPU1 399 17: 2900226778 3397521340 GIC-0 29 Edge twd 400 18: 0 0 MPIC 5 Level armada_370_xp_per_cpu_tick 401 19: 0 0 MPIC 3 Level arm-pmu 402 20: 211 0 GIC-0 34 Level mv64xxx_i2c 403 21: 0 0 GIC-0 35 Level mv64xxx_i2c 404 22: 762 0 GIC-0 44 Level ttyS0 405 36: 6693030 4165444 MPIC 8 Level eth0 406 37: 0 0 GIC-0 50 Level ehci_hcd:usb1 407 38: 0 0 GIC-0 51 Level f1090000.crypto 408 39: 0 0 GIC-0 52 Level f1090000.crypto 409 40: 0 0 GIC-0 53 Level f10a3800.rtc 410 41: 225226275 0 GIC-0 58 Level ahci-mvebu[f10a8000.sata] 411 42: 226148189 0 GIC-0 60 Level ahci-mvebu[f10e0000.sata] 412 43: 153044 0 GIC-0 57 Level mmc0 413 44: 0 0 GIC-0 48 Level xhci-hcd:usb2 414 45: 0 0 GIC-0 49 Level xhci-hcd:usb4 415 46: 2 0 GIC-0 54 Level f1060800.xor 416 47: 2 0 GIC-0 97 Level f1060900.xor 417 48: 0 0 f1018100.gpio 23 Level 0-0020 418 49: 1 0 f1018100.gpio 20 Edge f10d8000.sdhci cd 419 50: 6 0 f1018100.gpio 18 Edge Wake-On-LAN 420 IPI0: 0 1 CPU wakeup interrupts 421 IPI1: 0 0 Timer broadcast interrupts 422 IPI2: 203285205 32150280 Rescheduling interrupts 423 IPI3: 3140055 1275471 Function call interrupts 424 IPI4: 0 0 CPU stop interrupts 425 IPI5: 23062240 23212920 IRQ work interrupts 426 IPI6: 0 0 completion interrupts 427 Err: 0
  3. I had to reinstall on my Linux desktop due to a hard drive failure. I copied the mounting language in my /etc/fstab file and now it times out on mounting. This is my mounting entry which worked fine before 192.168.0.123:/mnt/md0 /mnt/RAID nfs rw,_netdev,hard,intr,rsize=8192,wsize=8192,timeo=14,user 0 0 That used to work. I made no changes to my Helios4. When I try to mount it manually, this is what I get: mount -av mount.nfs: timeout set for Fri Jul 23 07:26:16 2021 mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2' mount.nfs: mount(2): Connection refused mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: portmap query retrying: RPC: Unable to receive mount.nfs: prog 100003, trying vers=3, prot=17 mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused mount.nfs: Connection timed out I have no idea why the Helios4 is refusing the connection when it worked fine before. Any help would greatly be appreciated.
