nffs
nffs's Achievements
  1. Thank You for your time and help. It works with latest dev kernel.
  2. I've replaced HDMI720P_60 mode with my configurations. This is my script.fex and kernel patch
  3. Hi, I'm trying to set up my Orange PI 2 with very specific resolution. I tried a lot of advices from this forum but still can't force it to work. I've used jernej's U-Boot to see correct parameters for monitor and then recompiled kernel with these params. There is U-Boot output: hdmi_core.c line: {MODE_XXX, 0, 297000000, 0, 2160, 1200, 2266, 46, 40, 20, 1464, 234, 28, 2, 0, 0, 0, 0, 0} hdmi_bsp_sun8iw7.c line: {YYY, 1, 0, 0, 8, 2, 4, 0, 28, 0, 0, 112, 106, 40, 20, 176, 264, 1, 1} script.bin setting: pll_video = 297 My monitor is connected by HDMI cable, I set my mode using "h3disp -m" command and also I tried different params in "[hdmi_para]" section in script.bin, no result. the best result I have now is that I see the image only while U-Boot is working and then blank screen. Also I've tried Odroid-C2(boot.ini custombuilt resolution) and Odroid-XU4(Xrandr custom resolution) no result, only blank screen. There is my kern.log:
