ecod
ecod's Achievements
  1. Hi Igor it is strange a bit: the current boot.cmd is: setenv bootargs console=tty1 root=/dev/mmcblk0p1 rootwait sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=EDID:1280x720p60 panic=10 consoleblank=0 and: if I set only wifi as client, I can not connect to the device BUT: if I enable eth0 AND wifi too, both can be used this is weird
  2. Hi Igor based on your comment I made another test: - the fix eth0 was still working, only the wifi gave up - the HDMI output is not working, last msg is shown: "starting kernel" or similar - I will check further on, what happened tnx
  3. Hi Igor, i installed the new linux-jessie-root-cubietruck_3.8_armhf.deb pkg on CT3.6 (jessie) I shortly see the device is booting but blank screen comes afterwards. network (wifi) does not work either. any hint? thanks so far br ecod
