Chris Jackson
  1. Sorry to bug you guys, but I just wanted to let you guys know about something I found in testing. I only have an orange pi zero, so I can't attest for other models, which I know is H2+ not H3, but the script mostly works. I only say mostly, since the fex setting for dram works and the fex settings for corekeeper work. However, for some reason, the userspace change for dram doesn't work on the pi zero. It just throws an I/O error. Having said so, with the script both changing fex and putting the userspace echo for dram in the rc.local, it causes rc.local to fail before it hits the core deactivation. I would have never noticed if I wasn't testing both core deactivation and dram settings. Quick fix, to just comment out the dram setting in rc.local, but I figured I'd just mention it. If you guys want, you can throw that in an FAQ or have the script check to see if it's on a pi zero, and not perform the rc.local portion of dram settings update. On a happier topic, great work! I love you guy's dedication, and hard work on the OS. I really appreciate everything you guys do!
