piglet
  1. Hi, I have a board Orange Pi Zero with modified PAs for power of WiFi module from PA20 to PA02, by soldering a connection on board. This is done to allow connection of I2C DAC. I see that board definition in 'u-boot/configs/orangepi_zero_defconfig' It uses dts definition of: 'arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts' I need to modify one section of this dts file from: reg_vcc_wifi: reg_vcc_wifi { compatible = "regulator-fixed"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-wifi"; enable-active-high; gpio = <&pio 0 20 GPIO_ACTIVE_HIGH>; to: reg_vcc_wifi: reg_vcc_wifi { compatible = "regulator-fixed"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-wifi"; enable-active-high; gpio = <&pio 0 2 GPIO_ACTIVE_HIGH>; How can I do this and use armbian build script: compile.sh Thanks, Michal
