lmirel
lmirel's Achievements
  1. I couldn't get any of the builds to boot the board. I used the usual approach with the BootcardMaker from @mlogic. it boots fine with the Android bootloader.img and the one I built from the @mlogic buildroot.
  2. thanks! I'll take a closer look at 'aml_autoscript' upon my return.
  3. the regular use case for when the eMMC fails on these boards (this is the one requiring intervention) is that we end up with an empty flash, unable to boot. the preloader is looking for boot code on SD, USB device and serial. the SD script would have to be prepared in such a way that it sets-up the bootloader to boot from SD each of the OSs: armbian, lakka.tv and LibreELEC. Armbian uses 'aml_autoscript' and 's805_autoscript' but I didn't observe these to be executed at all. this is the case where we can't rely on the existing Android system to help us boot from SD (since the eMMC is broken).
  4. thanks very much. I hope is not urgent as I'm travelling for the next couple weeks and can't try them yet. have you any experience with the bootloader script for AMLogic? I used the following scripts to boot: - armbiansetenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0"setenv bootargs "root=LABEL=ROOTFS rootflags=data=writeback rw ${condev} fsck.repair=yes net.ifnames=0 mac=${mac}"setenv kernel_loadaddr "0x14000000"setenv dtb_loadaddr "0x11800000"setenv initrd_loadaddr "0x15000000"setenv boot_start bootm ${kernel_loadaddr} ${initrd_loadaddr} ${dtb_loadaddr}mmcinfofatload mmc 0 ${initrd_loadaddr} uInitrdfatload mmc 0 ${kernel_loadaddr} uImagefatload mmc 0 ${dtb_loadaddr} dtb/meson8_k200b_2G_emmc_sdhc.dtbrun boot_start- lakka.tv and LibreELEC.tvsetenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0"setenv bootargs "${condev} bootfromsd"mmcinfofatload mmc 0 ${loadaddr} kernelbootm I'm thinking these could be used to prep the script for booting from SD. thanks again!
  5. thanks took a stab at running kodi mirel@vegas812:~$ kodi /usr/lib/arm-linux-gnueabihf/kodi/kodi-xrandr: Failed to get size of gamma for output default libEGL warning: DRI2: failed to authenticate Segmentation fault Crash report available at /home/mirel/kodi_crashlog-20170405_050451.log it reports some errors and it doesn't start 05:04:50 T:2942435936 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'OnLowBattery' 05:04:51 T:2942435936 ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:33, error_code:5, request_code:18 minor_code:0 05:04:51 T:2942435936 WARNING: Visual 0x21 of the SDL window is not suitable, looking for another one... 05:04:51 T:2942435936 ERROR: Failed to determine egl config for visual info 05:04:51 T:2942435936 ERROR: Previous line repeats 236 times. 05:04:51 T:2942435936 ERROR: EGL/GLX Error: vInfo is NULL! looks like it is missing some things. I'm running Armbian_5.27_S812_Ubuntu_xenial_3.10.99_mate_20170322.img
  6. after I RTFM I managed to log in tried to boot the xfce image with no luck. anyway, life it is already better now
  7. so after I replaced the bootloader on the Armbian_5.27_S812_Ubuntu_xenial_3.10.99_server_20170322.img with the one I built, I managed to boot the system with Linux. -- Ubuntu 16.04.2 LTS vegas812 ttyS0 vegas812 login: -- what's the user/pass? now if I'll only manage to run an image with a desktop..
  8. scratch that. it seems the u-boot is fine. managed to start the board with it EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I400000004294enter usb bootA1A13697EEEE I3000000032940xdd00000103974545EEEE I600000006294No boot up devic5 no sdio debug board detected TE : 472102 BT : 19:06:30 Apr 4 2017 PMU:rn5t618 DC01 v:1100, 0x[36]: 18 -> 28 DC02 v:1150, 0x[37]: 18 -> 2c DC03 v:1500, 0x[38]: 38 -> 48 LDO01 v:2900, 0x[4c]: 4e -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12123 us HHH 0x0000008d check SD_boot_type:0x1 card_type:0x1 ucl decompress...pass 0x12345678 Boot from external device TE : 805512 System Started U-boot(m8_k200_v1@) (Apr 04 2017 - 19:06:21) clr h-ram DRAM: 2 GiB -- so, u-boot seems fine there. there's still a long way to having a system up and running (with XBMC, for example) so I'm still hoping you could help. let me know if you need any info . cheers
  9. thank you, sir! I've tried building this one http://openlinux.amlogic.com/wiki/index.php/Arm/Buildroot/buildroot-3.10/buildroot-2015-01-20 after building u-boot (used make meson8_k200b_release_defconfig) and tried it, interestingly enough I've got the same error: EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I400000004294enter usb bootA1A13697EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I5 ----------------------------------------------------------------------- * Welcome to Hardkernel's ODROID-C... (Built at 19:33:00 Dec 8 2014) * ----------------------------------------------------------------------- CPU : AMLogic S805 MEM : 1024MB (DDR3@792MHz) so, I'm back to square 1
  10. any of them for this matter. my board is unusable as of right now. so I'll take anything you'd recommend. thanks!
  11. hi guys, I have a Minix X8-H with a broken emmc and I'm in need of a Linux image that I can boot and run from SDcard. can you please point me in the right direction? I tried Armbian_5.27_S812_Ubuntu_xenial_3.10.99_server_20170322.img.xz but it doesn't seem to work, it gets stuck on u-boot after the Hardkernel banner. EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000126B22525 ----------------------------------------------------------------------- * Welcome to Hardkernel's ODROID-C... (Built at 19:33:00 Dec 8 2014) * ----------------------------------------------------------------------- CPU : AMLogic S805 MEM : 1024MB (DDR3@792MHz) I think this is an S802 or similar: [ 0.000000@0] Machine: Amlogic Meson8 platform, model: AMLOGIC [ 0.000000@0] Total memory is 2048 MiB I have access to UART console and I have a working U-boot for it. I tried LibrELEC but after loading the kernel it gets stuck on unable to mount /dev/system because it seems it is trying to mount the broken flash. thanks in advance
