larva
larva's Achievements
  1. Hi! I'm trying to use the image Cubietruck_Debian_3.8_jessie_4.0.4.raw with my CubieTruck, but run into problems when trying to use an external LUKS-disk which is encrypted using aes-xts-plain64. 'cryptsetup luksOpen' informs the following: device-mapper: reload ioctl on failed: No such file or directory Failed to setup dm-crypt key mapping for device /dev/disk/by-uuid/<xxxx>. Check that kernel supports aes-xts-plain64 cipher (check syslog for more info). 'cat /proc/crypto | grep name' lists only this, which seems kinda minimal: name : stdrng name : stdrng name : crc32c name : deflate name : ecb(arc4) name : arc4 name : aes name : des3_ede name : des name : sha224 name : sha256 name : sha1 name : md5 name : md4 Directory /lib/modules/4.0.4-cubietruck/kernel/crypto/ has these files: af_alg.ko algif_rng.ko async_tx ccm.ko crypto_null.ko ctr.ko fcrypt.ko gcm.ko gf128mul.ko ghash-generic.ko pcbc.ko seqiv.ko So, it seems that some crypto modules for the kernel are missing, but I don't know which ones are needed ('aes-xts' or similar, at least, maybe?). Any ideas on what to do? Do I need to compile the kernel to include the modules? Does the older 3.4.x(?) kernel have these included? Thanks.
