pablo
pablo's Achievements
  1. Hi Igor As I was saying, I'm new to Linux. I made the changes you mentioned (CREATE_PATCHES = "yes") but I received an error stating that it was not possible to compile, I probably altered something that was not due. When the system is compiled one accesses to "/sys/class/graphic/fbcon/", in that directory are the "rotate" and "rotate_all" files, which are not editable (I tried changing permissions) either replaceable. To be able to change the value of these files (or another one that activates the rotation) Which file should I edit? Thanks again.
  2. Hi Igor I can build an image of armbian correctly, thanks. But I don't alter /sys/class/graphic/fbcon/rotate & rotate_all. I understand that after of build the kernel I need to modify this files to activate the screen rotation. I need activate the rotation from the kernel. I follow your link (https://docs.armbian.com/Developer-Guide_Build-Preparation/) and alter "compile.sh" for activate the personalization menu, then select rotation, but doesn't work. I explained well? PD: I attached the log. output.log
  3. Hi Igor Great job. Could you help me: I try to made a personaliced kernel image to activate the rotate of screen from the kernel, i found in sunxi a tutorial, but have many errors in the way. You have a more explained tutorial or web from i can get the steps. I'm new on linux, but i need this for job. Thansk so much. PD: exuce by my so bad english...
