I am compiling H5 boards, Nano Pi Neo 2 (wip) and Nano Pi Neo Plus 2 (disabled board) and getting errors building u-boot.
[ o.k. ] Compiling u-boot [ 1.0.0 ]
[ o.k. ] Compiler version [ aarch64-linux-gnu-gcc 7.1.1 ]
[ .... ] Checking out sources
[ o.k. ] Started patching process for [ u-boot sun50iw2-nanopineo2-dev ]
[ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-sun50i-dev ]
[ warn ] ... [l][c] add-FIT-config-name-match-function.patch [ failed ]
[ warn ] ... [l][c] add-FIT-support-A64-spl.patch [ failed ]
[ warn ] ... [l][c] add-FIT-support-H5-spl.patch [ failed ]
[ warn ] ... [l][c] add-disp2-video-driver-jernej.patch [ failed ]
[ o.k. ] ... [l][c] add-nanopineo2.patch [ succeeded ]
[ warn ] ... [l][c] add-opiprime-to-u-boot-sun50i-h5.patch [ failed ]
[ warn ] ... [l][c] add-opiwinplus-to-u-boot-sun50i-a64.patch [ failed ]
[ warn ] ... [l][c] add-opizeroplus-to-u-boot-sun50i-h5.patch [ failed ]
[ warn ] ... [l][c] add-spl-switch-H5.patch [ failed ]
[ warn ] ... [l][c] add-sy8106a.patch [ failed ]
[ warn ] ... [l][c] badd-nanopim1plus2.patch [ failed ]
[ warn ] ... [l][c] disable-usb-keyboards.patch [ failed ]
[ warn ] ... [l][c] enable-DT-overlays-support.patch [ failed ]
[ warn ] ... [l][c] fix-fdt-print-endianness.patch [ failed ]
[ warn ] ... [l][c] pll1-clock-fix-h5.patch [ failed ]
[ warn ] ... [l][c] refactor-FIT-loading.patch [ failed ]
[ warn ] ... [l][c] sunxi-boot-splash.patch [ failed ]
'/home/a/armbian-ref/.tmp/atf-sun50iw2-nanopineo2-dev/bl31.bin' -> './bl31.bin'
make -C u-boot clean
make[1]: *** No rule to make target 'clean'. Stop.
make[1]: Entering directory '/home/a/armbian-ref/cache/sources/u-boot-sun50i/master/u-boot'
make[1]: Leaving directory '/home/a/armbian-ref/cache/sources/u-boot-sun50i/master/u-boot'
make: *** [u_boot_h5] Error 2
Makefile:19: recipe for target 'u_boot_h5' failed
[ error ] ERROR in function compile_uboot [ compilation.sh:177 ]
[ error ] U-boot file not found [ u-boot-sunxi-with-spl.bin ]
[ o.k. ] Process terminated
Looking further I noticed cache/sources/u-boot-sun50i/master/.gitmodules is points to a missing git repo
[submodule "u-boot"]
path = u-boot
url = https://github.com/apritzel/u-boot.git
branch = h5
I don't see h5 brnach in that repo.
config/sources/sunxi64_common.inc has this line
BOOTSOURCE='https://github.com/zador-blood-stained/u-boot-sun50i.git'
https://github.com/armbian/u-boot-sun50i/blob/master/.gitmodules points to missing repository.
points missing repo.
Can someone share a copy of https://github.com/apritzel/u-boot.git h5 via github? or know a replacement repository for this? I thought getting a copy would be a quick fix for me, since these boards are not supported. A proper fix could take a while. I tried u-boot-sunxi and patches does not seems apply.
thanks,
-antony
