Hello,
I try to setup my Orange Pi Lite with a thermal printer (http://www.ebay.de/itm/122418910118?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT). With my Arduino the printer works perfect, so it is actually ok. I just can't figure out how to use the ttl connection. I installed pyA20 and try to implement a kind of SoftwareSerial and it didn't worked really well:
#!/usr/bin/env python
"""Basic blinking led example.
The led on A20-OLinuXino-MICRO blinks with rate of 1Hz like "heartbeat".
import os
import sys
import time
if not os.getegid() == 0:
sys.exit('Script must be run as root')
from time import sleep
from pyA20.gpio import gpio
from pyA20.gpio import port
from pyA20.gpio import connector
tx = port.PA11
rx = port.PA12
baud = 1.0/9600.0
def sendTx(sendCharASCII):
sendByte = '{0:b}'.format(sendCharASCII).zfill(8)
sendByte = sendByte[::-1]
print(sendByte)
sendByteInt = [int(bit) for bit in sendByte]
gpio.output(tx,0)
time.sleep(baud)
for bit in sendByteInt:
#print('sending '+bit)
gpio.output(tx,bit)
time.sleep(baud)
gpio.output(tx,1)
time.sleep(0.01)
gpio.init()
gpio.setcfg(tx, gpio.OUTPUT)
gpio.setcfg(rx, gpio.OUTPUT)
gpio.output(tx,1)
gpio.output(rx,0)
sleep(1)
sendTx(ord('a'))
sendTx(ord('b'))
sendTx(ord('c'))
sendTx(ord('d'))
sendTx(ord('e'))
sendTx(ord('f'))
sendTx(ord('g'))
sendTx(ord('h'))
sendTx(ord('i'))
sendTx(ord('j'))
sendTx(ord('k'))
sendTx(ord('l'))
sendTx(ord('m'))
sendTx(ord('n'))
sendTx(ord('o'))
sendTx(ord('p'))
sendTx(ord('q'))
sendTx(ord('r'))
sendTx(ord('s'))
sendTx(ord('t'))
sendTx(ord('u'))
sendTx(ord('v'))
sendTx(ord('w'))
sendTx(ord('x'))
sendTx(ord('y'))
sendTx(ord('z'))
sendTx(10)
sendTx(10)
sendTx(10)
I printed out some cryptic signes. The cool thing is, that if i change the baud sleep time to something smaller, it actually prints sometimes the right letters. That means python is just too slow. Can anyone help to setup a ttl connection to the printer? I've googled alot, but I just can't find anything helpfull Currently I use pins PA11 and PA12, is this right?
Greets,
Chris
