Hello everyone,
I have installed a new mainline armbian-server on my BPiR1 and i want to configure the switch in exact this behavior. (LAN and WAN-Ports should be interconnected with each other and together with the internal Ethernet-adapter of the BananaPi). I thought that therefore no configuration is needed. But when i start the freshly installed armbian 5.25-mainline-image, then the external Ethernet-ports are not interconnected. So i can connect from all ports to the BPiR1 but not between two devices attached to the BPiR1.
On startup i got this:
[ 4.200897] libphy: stmmac: probed
[ 4.200930] mdio_bus stmmac-0:1e: mdio_device_register
[ 4.201677] b53_common: found switch: BCM53125, rev 4
[ 4.201755] bcm53xx stmmac-0:1e: failed to register switch: -517
The configuration-scipt by dumischbaenger (postet on April 6th) does work for me, but as i understand it correctly this isn't a true hardware-based unmanaged switch-mode, isn't it? As i understand it correctly the script is creating 5 VLANs, one for each Ethernet-Port, and then bridge them together.... Does someone know a way to setup the switch in fully unmanaged mode?
Best regards,
flashbanger
System:
Hello everyone,
