sbcidiot
  1. Nevermind, magically it's working again.
  2. I screwed up another card, this time the green light does not come on. However, I can stick it in my computer and everything comes up. Is there a way to recover this drive (since I'm assuming u-boot or something of the sort is messed up) without starting all over?
  3. Got a different card, everything's been working OK since. Sorry for the stupid question.
  4. It used to function fine, however after not using it for awhile it has quit working. It starts booting normally, then hangs with what's visible on the screen being a bunch of systemd messages, with the last being either something about system variables or mounting FUSE file filesystem, when it's the latter it's followed up with a kernel panic. I've reflashed several times using both the server and desktop images freshly downloaded, no difference. The power supply I'm using worked before, as did the SD card. Unfortunately I have no way of showing you system logs or such for the time being. Any help would be appreciated.
