tvs
4 -
I'll have a look. As written previously, I would gladly help if I can. You're saying that the problem was recognized. Is there some doc somewhere? U-Boot 2020.10-armbian (Jul 17 2021 - 06:11:38 +0000) Allwinner Technology Yet, runs I made ended at "Starting kernel ..." and the current start went further, but "Oops - undefined instruction: 0 [#1] SMP THUMB2" Thus my previous questions: if it's related to a branch of the kernel, I can try others -- I tried with linux-4.19.201 in previous tests of which I posted the logs.. Cheers.
I dd Armbian_21.05.1_Bananapi_buster_current_5.10.34_minimal.img then u-boot-sunxi-with-spl.bin (checkout of v2020.10). BPI boots and things seem to proceed well but then, no signal on the screen -- boot with/without a keyboard is the same. Since logs are only printed on the screen, I only have the following until 'Starting kernel ...'. Yet, after some time letting the unit proceed, I rebooted and got a OOPS given below. -- For Werner, as written in my previous post, I tried the Armbian_21.08.0-trunk.110_Bananapi_hirsute_edge_5.13.7.img without result. Any idea why the screen goes in stanby, printing 'no signal'? (and some configuration modification to have logs printed on serial as well?) Found U-Boot script /boot/boot.scr 3967 bytes read in 4 ms (967.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 154 bytes read in 4 ms (37.1 KiB/s) 8968888 bytes read in 592 ms (14.4 MiB/s) 7973464 bytes read in 472 ms (16.1 MiB/s) Found mainline kernel configuration 43645 bytes read in 15 ms (2.8 MiB/s) 5532 bytes read in 14 ms (385.7 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 45000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 8968824 Bytes = 8.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 49772000, end 49fffa78 ... OK Loading Device Tree to 496fe000, end 49771fff ... OK [ 12.819493] Internal error: Oops: 805 [#1] SMP THUMB2 [ 12.866952] Modules linked in: axp20x_adc evdev lima gpu_sched sun4i_gpadc_iio sun4i_ts sunxi_cir sunxi_cedrus(C) v4l2_k [ 12.928746] CPU: 1 PID: 445 Comm: rsync Tainted: G WC 5.10.34-sunxi #21.05.1 [ 12.947387] Hardware name: Allwinner sun7i (A20) Family [ 12.963021] PC is at ext4_llseek+0xa2/0x100 [ 12.977450] LR is at sys_llseek+0x69/0xfc [ 12.991520] pc : [<c030682e>] lr : [<c02739d9>] psr: 400e0033 [ 13.007968] sp : c2ff7f30 ip : 00000000 fp : 000e7bc4 [ 13.023397] r10: 00000000 r9 : c9ab5408 r8 : c2d183c0 [ 13.038833] r7 : 00000000 r6 : 000e7bc4 r5 : 00000fff r4 : fffff000 [ 13.055621] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 000e86dc [ 13.072268] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none [ 13.089691] Control: 50c5387d Table: 42e3c06a DAC: 00000051 [ 13.105570] Process rsync (pid: 445, stack limit = 0x27f33ead) [ 13.121615] Stack: (0xc2ff7f30 to 0xc2ff8000) [ 13.136208] 7f20: 00000000 00000000 00000000 00000000 [ 13.154860] 7f40: 00000000 00000000 c0f04fc8 c2d183c0 c030678d c2d183c0 00000000 beb5e5b0 [ 13.173580] 7f60: 00000000 c02739d9 00000000 00000035 beb5f1e8 c0274fc9 000e6e91 2a3d352b [ 13.192276] 7f80: b6f69978 00000000 000e7bc4 00000003 0000008c c0100284 c2ff6000 0000008c [ 13.210932] 7fa0: beb5f1e8 c0100061 00000000 000e7bc4 00000003 00000000 000e7bc4 beb5e5b0 [ 13.229644] 7fc0: 00000000 000e7bc4 00000003 0000008c 00000003 beb5f1dc 00000000 beb5f1e8 [ 13.248346] 7fe0: 0000008c beb5e5a8 b6f51a55 b6f50fc6 400e0030 00000003 00000000 00000000 [ 13.267081] [<c030682e>] (ext4_llseek) from [<c02739d9>] (sys_llseek+0x69/0xfc) [ 13.285003] [<c02739d9>] (sys_llseek) from [<c0100061>] (ret_fast_syscall+0x1/0x62) [ 13.303344] Exception stack(0xc2ff7fa8 to 0xc2ff7ff0) [ 13.319145] 7fa0: 00000000 000e7bc4 00000003 00000000 000e7bc4 beb5e5b0 [ 13.338220] 7fc0: 00000000 000e7bc4 00000003 0000008c 00000003 beb5f1dc 00000000 beb5f1e8 [ 13.357216] 7fe0: 0000008c beb5e5a8 b6f51a55 b6f50fc6 [ 13.373046] Code: f3bf 8f5b f8d9 2080 (429a) d1f1 [ 13.388839] ---[ end trace d728074366bef4bf ]--- [ 13.845445] systemd[1]: Started Armbian memory supported logging. [ 13.882704] systemd[1]: Starting Journal Service... [ 14.223207] systemd[1]: Started Journal Service. [ 14.356481] systemd-journald[470]: Received request to flush runtime journal from PID 1
I digged a bit in the forums, and it seems that the loop thing happens to several boards. I saw the commit in August 03 to go back to u-boot tag2020:10 (https://github.com/armbian/build/pull/2963). This being said, I made a few additionnal tests, since it seems to me that there might be more than u-boot due to OUPS and kernel panics I have been issuing. Context: BPI is connected via serial but has also a screen, connected to network, nothing plugged in USB. ** Armbian_20.11.6_Bananapi_buster_current_5.10.4_minimal.img + kernel 5.10.55: Pb 'Unable to handle kernel paging request at virtual address 816ba440' at least, startup log is here: https://postit.ilinux.fr/?da42320bdeeb734d#FUNpSTD5ogvCc57S84ZfYRLYTUMmXhmSHpxHXhcTNspu (I checked because I didn't read the commit yet) ** Armbian_21.05.1_Bananapi_buster_current_5.10.34_minimal.img Here too, startups may be different. Always have a no signal on the screen. Kernel Panic. Log is here: https://postit.ilinux.fr/?52b0500d4a5d0741#BhCykEPZsg9Co9kL84rLJ3hikdtimN1fvedqsLK7iH4B ** Armbian_21.08.0-trunk.110_Bananapi_hirsute_edge_5.13.7.img, checked just in case, but startup ends at 'Starting kernel ...' (nothing happened during at least 5min). Again, no signal on the screen. ** I tried the very last version of u-boot, but like for one week or so, doing so lead me to the following, without anything happening next... U-Boot SPL 2021.10-rc1-00240-gab97eb341c (Aug 05 2021 - 19:23:48 +0200) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 ** Armbian_21.05.1_Bananapi_buster_current_5.10.34_minimal.img + Kernel-5.10.55, the idea here is to check both u-boot and the last kernel. Got some starts ending with 'Starting kernel ...', other with a kernel panic 'not syncing: stack-protector' Log is here: https://postit.ilinux.fr/?0ddea25565f1695c#BXCFHWP2W5U3R2A89YsHmJfou8Num5oEgoNibzjD5q6W ** Armbian_21.05.1_Bananapi_buster_current_5.10.34_minimal.img + Kernel-4.19.201 I made 2 execs, both results in a no signal for the screen. The 1st makes a re-mounted-ro of /, and writes Failed to start Armbian-ZRAM config. Log is here: https://postit.ilinux.fr/?7a95b34eb3fd27c6#8wwMV4q1ezMBEisLtJNezBAC6eZQ2p2ukaKHTQZat4tt 2nd exec went further, I don't know how ARMBian first boot may have impacted this 2nd exec. Still error ans script (ZRAM config and ntp). Exec seems to achieve something, but no login (serial) and no signal on screen either. Log is https://postit.ilinux.fr/?ab16234f6bf18104#H6vUrPcuCmsR3ox57SW7ocDgwSBkC4vgNQx925bg8xe5 Note that kernels have been compiled with the sunxi_defconfig configuration. I had to change a bit what is in /boot to make things work, like adding a script.bin generated from sunxi-tools, and used the boot.cmd taken from ArchLinux https://wiki.archlinux.org/title/Banana_Pi (using ARMbian lead to errors, maybe initram :? I'm more than willing to help further if instructed what to do... Cheers.
Hi, Same issue than Rein on my BananaPi with Armbian_21.05.1_Bananapi_buster_current_5.10.34_minimal.img. Thought it might be related to the SDCard health, but F3probe says it's ok. Some startups achieve to go further on, but ends with a kernel panic, beginning with: [ 12.539309] Internal error: Oops: 805 [#1] SMP THUMB2 The whole start log pasted from minicom can be found here: https://postit.ilinux.fr/?33cebd8991824eed#CvQVEzwarxRShDRzQewGRG8G1Hd4G8LMxYZgPRmLXpmZ (lifetime 1month). Cheers.
