highend
  1. Thank you tkaiser! I've resized everything manually via gparted now but the next time I'll have to do this procedure (if ever...) I'll remove the /root/.rootfs_resize before I finally boot up the eMMC media at the end.
  2. Thanks Jerome! The eMMC media is booting correctly after following the procedure. But the automatic partition resizing doesn't seem to work? df -hm shows: /dev/mmcblk0p1 3703 1366 2267 38% / for a 16 GB eMMC media There is no /boot mount point entry as well... How can I resize the root partition correctly? This is what gparted shows when I plug in the cardreader on my notebook with gparted booted from a live CD: Partition File System Size Used Unused unallocated unallocated 4.00 MiB -- -- /dev/sdb1 ext4 3.70 GiB 1.44 GiB 2.27 GiB /dev/sdb2 unknown 10.82 GiB -- -- unallocated unallocated 150.28 MiB -- -- I've taken Jerome's description and put it into a section based form: 01. Download the Android-4.4.4... image https://dn.odroid.com/5422/ODROID-XU3/Android/4.4.4_Alpha_4.9_May-17-2017/android-4.4.4-alpha-4.9-sd2emmc_installer-odroidxu3-20170517.img.zip from https://forum.odroid.com/viewtopic.php?f=53&t=6173 02. Extract the .zip file 03. Attach the micro SD-Card to your computer and flash the image android-4.4.4-alpha-4.9-sd2emmc_installer-odroidxu3-20170517.img to it 04. Remove power from the XU4 Attach the micro SD-Card AND the eMMC media to the XU4 and put the boot mode selector switch into SD mode 05. Attach power to the XU4 Let it boot. The blue LED stays on for about a minute. When the blue LED goes off or the XU4 shuts itself down, remove power from the XU4 again. You won't see any output if you've connected a monitor via HDMI during this time! 06. Remove the micro SD-Card AND the eMMC media from the XU4 and attach the eMMC media to the computer again. Flash your preferred armbian image to the eMMC media. E.g. the openmediavault from https://sourceforge.net/projects/openmediavault/files/Odroid-XU3_XU4/OMV_3_0_76_Odroidxu4_4.9.28.7z/download 07. Attach the eMMC media to the XU4 again and put the boot mode selector switch into eMMC mode. Do not attach the micro SD-Card 08. Attach power to the XU4 and let it boot...
